Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums > Argosy Motorhomes
Old 06-17-2019, 04:13 PM   #1621
Originally Posted by Isuzusweet View Post
How's that Coosa Kool-Aid Brad? Delicious isn't it.[emoji3]
As I've stated before....pricey, yes; but peace of mind is priceless.
Cheers
Sidekick Tony
Yeah, I'm happy I installed the Coosa board
It would have been so nice if Airstream had used a product like this from the git go. But with bean counters involved the product will never be as good as it could be.
1975 24' Argosy Motor Home
Old 07-08-2019, 12:34 PM   #1622
This weekend I finished the overhead platform for working on the roof of my Argosy as well as Peanut.
ID:	345813Click image for larger version
I know all the work can be done from ladders and walking on the roof, BTDT, but I never liked the idea of walking around up there trying to keep all of my weight on the ribs. Also, the ribs on a Classic are closer together so the weight distribution is better on a Classic than an Argosy.
Now to finish organizing the shop so I can fit an Argosy under the platform!
Old 07-08-2019, 01:02 PM   #1623
mayco's Avatar
1982 31' Airstream 310
champaign , Illinois
Nice job Brad. I really don't like working up on the roof either. The last time was several weeks ago replacing capacitors on the AC. I'm not as agile as I used to be and am constantly on guard when workin/moving around up there. It wears my butt out! Even the simplest jobs. That platform should be great!
Good work using through bolts, most folks would screw it off and call it good. Seems they don't consider the total weight of the lumber, the human, the tools, possibly an AC unit, etc
mayco is offline   Reply With Quote
Old 07-08-2019, 07:29 PM   #1624
dadstoy's Avatar
_ , _
I'm so jealous of your work shop Brad.
May a Firefly land upon your shoulder
and bring you good luck, good fortune, and abundance.
dadstoy is offline   Reply With Quote
Old 07-09-2019, 02:20 AM   #1625
Smartstream's Avatar
1982 28' Airstream 280
Port Angeles , Washington
What I want to know is do you have OSHA approval on the design?:
Cheers, Dan
~ Margaret Thatcher ~
Old 07-09-2019, 05:14 AM   #1626
Thanks! Getting old does have it's challenges doesn't it
I don't have much problem moving around on the roof but Ernie has had both knees replaced and he's going to be doing the roof work on Peanut along with painting the tops of both Argosies so hopefully the platform will make that easier.
As strong as the 3" drywall screws are it made me nervous to think they would be the only thing between me and the ground
Old 07-09-2019, 05:16 AM   #1627
Stay tuned for an upcoming picture later this week......
Old 07-09-2019, 05:21 AM   #1628
Per the Internet (everything you read on the Internet is true, right?!), "Please be advised that OSHA does not have any regulations that apply to residential properties."
Next question...
Old 07-09-2019, 05:43 AM   #1629
Dazed and Confused
Isuzusweet's Avatar
Hillsburgh , Ontario
I would have been more impressed if you had built the swinging mobile crane that hauled the disabled mechanic around in Mad Max 2. The mechanics assistant "Ernie" would raise him up and push him around.
In the clip below you see him being pushed into a bad guy.
Old 07-09-2019, 08:32 AM   #1630
Well....I do have the parts and materials to build a swinging crane, however building one is not on my radar. The last thing I need is to have Ernie swinging me around the shop!
Old 07-09-2019, 06:26 PM   #1631
i'm so jealous of your work shop brad.
Old 07-09-2019, 06:48 PM   #1632
dadstoy's Avatar
_ , _
Smiling!
Old 07-09-2019, 07:38 PM   #1633
Airstream Driver
PeterH-350LE's Avatar
1994 30' Excella
1992 35' Airstream 350
Images: 49
Next question...
You did forget the second part:
however, OSHA does have regulations that apply to the safety and health of employees while engaged in construction operations. ... These regulations apply to all construction operations, including residential construction
So in my case, I only build a non human type "swinging 2x4" to raise and lower AC's off the roof of Airstreams. It is very low tech, but very effective.
ID:	346007   Click image for larger version
AIR #13
PeterH-350LE is offline   Reply With Quote
Old 07-09-2019, 07:48 PM   #1634
mayco's Avatar
Osha!.........we dont need no stinkin osha!
Old 07-11-2019, 04:50 AM   #1635
I didn't forget, I just selectively edited.....
Fortunately Ernie is not an employee....
I like it! I've got an electric winch that I normally use but I hadn't thought of putting it on the end of a swinging beam, at least not in the fashion that you have set up.
Old 07-11-2019, 04:52 AM   #1636
Old 07-22-2019, 10:48 AM   #1637
My Argosy has been sitting on Peanut's old wheels for several years now but I still had the six wheels and tires that I removed from my Argosy laying around that needed to have the tires removed so they could be disposed of. This weekend I figured it was probably time to deal with that problem.
I don't know if I'm getting cheap in my old age or what but I figured I'd try and dismount the tires myself rather than pay $30 or more to have someone else do it. No matter what I still have pay disposal fees but I thought how hard can it be?......I figure if Dan (Smartstream) can dismount/mount tires on his 345 I should be able to deal with these smaller 16" tires, right?
I will say I learned a few things about tires along the way! It seems that a tire that has been mounted for at least 20 years or more is not likely to have the bead just pop off the rim.
The first two tires I attempted were were normal street tires and I was able to break the beads using my loader bucket relatively easily. Using tire irons the tire then popped of the rim rather quickly as well.
However, the four rear tires were mud and snow tires that were probably mounted back before the civil war and refused to budge no matter how hard I tried. I finally gave up with the loader bucket idea and ended up using a reciprocating saw to cut the tire on both sides until the rim with the safety bead came free. From there I had to use a dremel with a cutoff disc to carefully cut through the steel cords of the safety beads. While cutting the steel cords I could tell when I was getting close because I could hear the cords popping and the gap widening with each cord cut.
Bottom line is I spent 3 hours in 95 degree heat doing hard physical labor to save $30. Was it worth it, probably not but it was good exercise and a good learning experience
Old 07-22-2019, 11:00 AM   #1638
You know Brad there is a saying something to the effect of...Old age and treachery will always win over youth and ambition. Actually the big truck tires are easy to do by hand while the light vehicle tires not so much.
The old age teaches you that without needing to rely on the treachery part.
Cheers, Dan
Old 07-22-2019, 11:32 AM   #1639
I will say after that three hour stint I was feeling my age
Now I'm thinking about buying and mounting new tires myself! My biggest worry would be damaging the new aluminum rims.
Decisions decisions......
Old 07-27-2019, 10:33 PM   #1640
Dazed and Confused
Isuzusweet's Avatar
If I'm mistaken, there's a difference between a non safety bead tire, like the 19.5" and 16.5" tires and safety bead tires like the 16" you're mucking around with. The bead walls are considerably thicker and tougher to get past the rim than a non safety rim and tire.
I'd get a proper shop to mount and balance the 16's.
Cheers
Sidekick Tony
Entry steps on '77 Argosy motorhome WineStream Argosy Motorhomes 5 09-08-2013 11:16 PM
Argosy 20' motorhome 350 MPG and towing? ViewRVs Argosy Motorhomes 6 01-19-2012 08:13 PM
If you're looking for an Argosy Motorhome.... crazeevw Argosy Motorhomes 3 10-23-2011 08:09 AM
1977 Argosy Airstream Motorhome Rebuilt Engine, Trans, Headers. CLASSIC , Onan eBay Watch Airstreams on eBay 0 09-13-2011 09:00 PM
