Old 06-20-2010, 06:46 PM   #21
Registered User
Zeppelinium's Avatar
1973 23' Safari
1977 23' Safari
2014 25' Flying Cloud
Palmer Lake , Colorado
Bath mod
Russ, here's the photos of how I moved the bedroom back a foot.
First, cut the tub in "half." The tub is tight up against the FRP (the FRP is glued to the 1/2 birch partition with silicon. One of the edges is coming up slightly, but I am sure it will glue back down--when I get a round tuit.) and sealed with silicon. It's been a good seal for 8 years. (You have to get the cut almost perfectly planar and vertical. I lucked out with a saber saw! You can trim it with a rasp to get real close.) One day I'm going to tear out the sink surround and move the sink about 8" toward street side so I can have a full shower without that dreadful overhang with the handle.
Name:	P1000086 cut tub-s.jpg
Now your partions won't be opposite each other (see diagonal cut in the Pergo flooring--it's always good to provide segments in these floors so you don't have to remove all of it to get at something near one end. I have 4 segments in the Overlander. The other three are covered with an extrustion from HD that's designed to make a transition from carpet to hardwood.).
Name:	P1000082 door open-s.jpg
You can gain privacy in the bathroom by making a door inside a door. First photo is of the bath closet open wide and the "door inside a door" unfolded. The second photo shows the contraption in the correct position so that it provides a closed door to the bathroom.
Name:	P1000084 door example-s.jpg
ID:	105285 Click image for larger version
Name:	P1000085 door closed-s.jpg
Zep
Old 06-20-2010, 07:54 PM   #22
howco's Avatar
1970 27' Overlander
Sumner , Washington
Just to much time on your hands.....
Just kidding, nice work, good idea, I like a man that is a thinker.=.
Thank you.
Favorite Bumper sticker:
Yes, this is my truck...
No, I won't help you move....
howco is offline   Reply With Quote
Old 07-31-2010, 04:57 PM   #23
Registered User
1973 23' Safari
1977 23' Safari
Drawer Control
Thanks to a suggestion from FOILED AGAIN (thanks, Sister), I've adopted a drawer control method that is simple, cheap, and quick--use cutain spring rods between the floor and underside of the counter. Voila!
Name:	P1000385rods installed-s.jpg
ID:	107879 Click image for larger version
Name:	P1000384 forstner jig-s.jpg
I am a little leery of relying only on the friction from the spring force, so I decided to drill receiving holes for the ends of the rods. I hated to do it in the floor (the under counter holes aren normally "invisible"), but the simplicity of the solution convinced me it was worth it.
You need to make a small tool to guide the forstner bit. It will walk on the hard surface of any Pergo-like flooring and it's difficult to keep it from walking when you're drilling upside down on the counter top.
The holes in the floor need a coating of spar varnish to keep them water resistant.
If this was Thursday, I'd say I love my Airstream because it has 16 drawers--you just don't see the others.
Zep
Old 07-31-2010, 07:16 PM   #24
Registered User
1973 23' Safari
1977 23' Safari
I wish all my Airstreams had this feature. It's great to be able to reach in and grab tools, flashlights, extension cords, etc., without tracking crud inside.
Name:	P1000386 door drawers-s.jpg
ID:	107890 Click image for larger version
Name:	P1000387 door drawers open-s.jpg
Whew! It's only been 10 years and the front end is finally done.
Zep
Old 07-31-2010, 07:45 PM   #25
Jezibels's Avatar
1966 24' Tradewind
Chicago , Illinois
She sure is looking good Zep!
Love the wood cabs! Super job!
Happy Trails!
Jezibels is offline   Reply With Quote
Old 07-31-2010, 09:15 PM   #26
Dave Park's Avatar
2005 22' Safari
Hyde Park Place , Ohio
Is there not enough room to put an upright tool caddy in the upright behind space? Like the pantry can holders?
TX-16
Dave Park is offline   Reply With Quote
Old 07-31-2010, 09:38 PM   #27
Registered User
1973 23' Safari
1977 23' Safari
What a good idea. Guess I'll have to buy another one and get started on the mods. I guess I got carried away with storing the folding lounge chairs in that space on this one.
Zep
Old 07-31-2010, 09:54 PM   #28
Dave Park's Avatar
2005 22' Safari
You didn't build a storage bin into your floor? *gasp*
I got the idea from the stow and go seating in my old Town and Country. I'm working out how to implement it in an Airstream.
TX-16
Old 07-21-2012, 04:16 PM   #29
Registered User
1973 23' Safari
1977 23' Safari
The Overlander is by no means done, but these two finishing touches are getting it closer. How many years is it that I've had wires hanging out of the wall where I removed the bed reading light and moved the partition back 10 inches? Well, the new reading light and small shelves are installed. The light is a SuperbrightLEDs WWHP10-DAC 12V bi-pin disk (warm white), which normally draws about 150 milliamps. I used a SPDT on-off-on switch to provide both a bright (full voltage) and very dim (560 ohm resistor in series for a current of 9.5 milliamps). The very dim setting is about half as bright as a night light.
Name:	DSCN0200 bed light-s.jpg
The inner shell wall slopes at roughly 12 degrees here, so the two shelves are installed at a slant so they are level when parked. The bottom of the cabinet is cut at 35 degrees to point the LED out from the wall and then the LED itself is mounted on a 25 degree wedge to point it more toward the lap of someone sitting on the bed to read. Looking at the installed cabinet, I now realized I could have achieved a better pointing angle if I had rotated that wedge just a little.
I also installed a light over the desk. It has a curved shade so that the light doesn't spill over to the bed, and also has two settings--full bright and low (a 270 ohm resistor in series cuts the current to 25 milliamps, which is enough light to see the keyboard for typing those pesky characters and numbers I never mastered).
Name:	DSCN0198 lamp guts-s.jpg
ID:	163597 Click image for larger version
Name:	DSCN0199 lamp installed-s.jpg
Zep
Old 10-31-2012, 09:31 AM   #30
Registered User
1973 23' Safari
1977 23' Safari
After a great 10 weeks in the Overlander and about 6,300 miles, it's time to dive into the remodel of the bathroom.
Name:	2012 summer map.jpg
The original plastic countertop and sink molding took too much room out of the shower (originally a tub, but cutting that in half was my very first modification). This area has always been the main source of road dust, coming up through the floor plumbing penetrations and into the rear of the trailer.
The first step will be to replace the over-sink vanity cabinet and mirror. Next, a new stainless sink and cabinet alongside the toilet. Last, lowering the tub to the floor and rerouting the drain lines. This might also include a small gray tank, just for the two sinks (kitchen and bath), about 8 gallons. That's enough to wash a couple meals of dishes and brush your teeth, so you're dribbling on the WallyMart parking lot during quick stops. I have to see what I can fit aft of the wheel well under the bed.
Name:	P1010988 toilet-s.jpg
Name:	P1010985 plumbing-s.jpg
Name:	P1010983 tub-s.jpg
Zep
Old 11-09-2012, 01:56 PM   #31
Registered User
1973 23' Safari
1977 23' Safari
OK, the tub is out. The objective is to install a shower pan on the floor to recover the 4 or so inches of height that the tub was off the floor. The battery box makes this a bit difficult, as it pushes the kitchen drain away from the wall. The PO had installed an alternate battery box on the street side, so I may remove this one to get the room for the shower pan.
You can see the hole where the J-trap was for the tub. I thought all the road dust was coming up through the floor around the dump valve, but it now appears that this is the real source.
Name:	DSCN0635 vents-s.jpg
Name:	DSCN0637vents labeled-s.jpg
Name:	DSCN0636 battery and drain-s.jpg
The main electrical area is just forward of where the tub was. I think I'll move the coverter to the forward part of this storage area, take the battery box out, and install a gray tank (for the sinks, only) here.
Name:	DSCN0638 battery box-s.jpg
Zep
Old 11-29-2012, 07:26 PM   #32
Registered User
1973 23' Safari
1977 23' Safari
Now that the old tub is out, I see opportunity. In order to place the new shower pan on directly on the floor, most of the bath plumbing needs to be rearranged, forcing the removal of the battery box (the PO happened to install another battery box on the other side--how serendipidous!).
It occurs to me that the space in the last photo in the previous post (the storage area aft of the wheel well under the bed) could hold an above-floor gray tank. A check of tanks from The Metal Company finds a big selection of tanks between 15 and 28 gallons that will fit. The twenty gallon size looks like the best bet, simply because it provides sufficient room to get hands into the space with the tank and get the in and out pipes connected.
An above-floor gray tank can't do anything for the shower, but it allows use of both sinks (20 gallons ought to provide 3-5 days use). This will make the Balloon Fiesta a lot easier!
Obviously the floor needs to be repaired and the exterior skins need some work.
Name:	DSCN0709 open side-s.jpg
Name:	DSCN0710 battery hole-s.jpg
The fuse block and the Intellipower need to be relocated--not a big deal except the wires to the fuse block limit how far it can be easily moved. Maybe it can go under the shower seat and be accessed from the outside. Oops, new door? Hello, Kip!
Old 12-02-2012, 11:09 PM   #33
Registered User
1973 23' Safari
1977 23' Safari
Why do Airstream projects always wind up being several factors bigger than first planned?
The side wrap skin behind the wheels had been damaged a couple years ago by a blowout, so this was a great time to replace it. I also armored it. The one item I didn't have on hand was the edge trim, so I folded a piece of soft 0.032 over a piece of 1/8" plate. Once that was slipped over the edge of the skin, I used a wood block to flatten it, which made it relatively bendable.
Name:	DSCN0712 reinforced skin-s.jpg
ID:	173800 Click image for larger version
Name:	DSCN0715 soft edge-s.jpg
The banana wrap on this side is short, due to the space taken by the battery box. I've always been a little dismayed by the wrinkly edge of the banana wrap, so I made the underside triangle of skin and the banana wrap into one piece, including a strip of "L" channel as a stiffener. This one piece is a lot easier to install than the original two pieces.
Name:	DSCN0717 reinforced banana-s.jpg
The shell transitions from straight to curved right in the middle of the space previously occupied by the battery box. This presents a problem, in that the lower side wrap skin is a quarter tube and the aft end cannot be bent around to fair into the banana wrap. In order to get from the side wrap contour (straight tube) to the banana skin contour (compound curve), you need a short conic section. The joint between the shell skins immediately above is a good excuse to continue the joint down into the side wrap. The short piece of lower wrap that makes the connection between the two fits both skins nice and tight. I thought this would be a very subtle transition, but when you stand back and look at it, it's obvious it is cone-shaped. The longer banana wrap on the other side takes care of this transition from curved to straight.
Name:	DSCN0713 conic section-s.jpg
I fabricated a short rib section, which allows me to splice two skins to cover the remaining hole, and to continue to the apearance of the joint down to the lower trim belt. The C channel is curved by notching the inside flange and web.
Name:	DSCN0718 bottom done-s.jpg
ID:	173804 Click image for larger version
Name:	DSCN0719 cruved c-channel-s.jpg
Jeeze, another one-day job made into half a week!
Zep
Old 12-03-2012, 10:10 AM   #34
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
Zep
If you were paid for the job by the hour, this would be great.
Richard
azflycaster is online now   Reply With Quote
Old 12-29-2012, 09:35 PM   #35
DryFly's Avatar
1972 Argosy 20
Snoqualmie , Washington
I'm getting ready to install new counter tops in the kitchen and bathroom of my 73 Argosy 20'. How did you treat the transition from the counter top to the side wall - i.e. did you use a backsplash or did you find some type of aluminum transition strip?
DryFly is offline   Reply With Quote
Old 12-30-2012, 09:10 AM   #36
Registered User
1973 23' Safari
1977 23' Safari
I used a piece of 3/4" "L" channel (actually, two pieces, with a interlocking joint at the corner). I pop riveted it to the wall and used some acrylic bath caulk under the horizontal leg and the counter.
Zep
Overlander Land Yacht International :: 1964 Airstream Overlander Land Yacht Internati overlander64 Airstream Registry Discussions 2 01-27-2018 06:28 AM
Anybody used Zep floor finish on their aluminium body? marcosyh Clearcoat, Exterior Paint & Trim 2 10-29-2013 12:06 PM
RedMaxPro vs Zep is.chowa Land Yacht/Legacy Motorhomes 4 06-06-2013 12:03 PM
Overlander International :: 1973 Airstream Overlander rmoores Airstream Registry Discussions 0 01-31-2012 10:46 AM
Catarina 1963 Airstream Overlander :: 1963 Airstream Overlander utee94 Airstream Registry Discussions 0 08-19-2011 08:31 AM
