09-27-2020, 07:41 PM
#21
1986 34' Limited
1975 27' Overlander
Conifer
Your high tech tracing tool is perfect. It will work almost every time.
I clean vinyl clad interior walls with "Krud Cutter". It is a bit stronger cleaner that works well for me. Scrub, scrub. Sometimes I get the green Scotch Brite pad out for tougher spots.
David
WBCCI #8607
VAC Region 11
See my 1969 Globetrotter 21' Renovation Project:
In Knowledge Base
See my 1966 Trade Wind 24' Reno Project:
In Knowledge Base
See my 1975 Overlander 27' Improvement Journal:
In Knowledge Base
See our 1976 Sovereign 31' Renovation Project:
In Knowledge Base
09-29-2020, 06:09 AM
#22
Usually Sleepy
East Haven
, Connecticut
How bad are the fumes/smells with the krud cutter? My wife is very sensitive to chemicals.
Skip
09-29-2020, 09:42 AM
#23
Always learning
1972 29' Ambassador
1962 19' Globetrotter
1951 21' Flying Cloud
Central
I also use Krud Kutter. It is an 'eco-friendly' cleaner/degreaser. It works very well on the interior walls of Airstreams. It has a very mild odor.
Lance
09-29-2020, 04:13 PM
#24
Usually Sleepy
East Haven
, Connecticut
Thank you.
Will a '76 Argosy Dinette for in a '73 Overlander?
It seems so ... with couple little tweeks.
Pre-fitting layout complete. Cleaning next.
Skip
10-10-2020, 09:05 AM
#25
Usually Sleepy
East Haven
, Connecticut
Got my tanks!! Perfect fit!
He put threaded fittings on instead of slip. I can make that work. All in all great quality tanks. If we were boondocking for two weeks they would not be enough. But should be able to make one week.
Polytech Manufactured Products
Terryville, CT.
They usually do plating tanks or other industrial, and often do holding tanks for boats.
Nice people Attachment 380445
Skip
10-10-2020, 07:09 PM
#26
1986 34' Limited
1975 27' Overlander
Conifer
Thanks for the reference to your tank maker. I assume they are welded up ABS tanks.
David
WBCCI #8607
VAC Region 11
In Knowledge Base
In Knowledge Base
In Knowledge Base
In Knowledge Base
10-11-2020, 09:08 AM
#27
Usually Sleepy
East Haven
, Connecticut
1/4 inch polypropylene
Skip
10-11-2020, 06:38 PM
#28
1986 34' Limited
1975 27' Overlander
Conifer
Oh goodness. They are built stout for sure. David
WBCCI #8607
VAC Region 11
In Knowledge Base
In Knowledge Base
In Knowledge Base
In Knowledge Base
10-12-2020, 05:36 AM
#29
Usually Sleepy
East Haven
, Connecticut
Yup. Beefy
Skip
10-12-2020, 06:56 PM
#30
1986 34' Limited
1975 27' Overlander
Conifer
Kinda like a brick outhouse. David
WBCCI #8607
VAC Region 11
In Knowledge Base
In Knowledge Base
In Knowledge Base
In Knowledge Base
10-27-2020, 11:01 AM
#31
Usually Sleepy
East Haven
, Connecticut
Minor progress. Valves installed and exit plumbing done.
That enabled me to put the belly pan back on.
Dropped her back on the tires and repositioned in the driver way to facilitate travel to and from the garage.
Skip
