Old 07-21-2008, 12:37 PM   #141
amitchell's Avatar
1972 27' Overlander
Dallas , Texas
Hey Ron,
Wow, what a great job you are doing on the trailer! The photos and info are great inspiration! The zebra wood (one of my personal favorites) looks fantastic.
I am about to start renovating my own '72 Overlander, and I have a quick question for you. What is the flexible material you used around the walls, on the back side of the dinette? I saw the post about the quarter rounds, but I didn't see anything about the other material. Did you mill that yourself or did you find a resource for the flexible banding? Also, can you provide info on how you fastened the material to the walls, and also to the dinette frame?
I hope my question makes sense! Again, thanks for the inspiration!
Best regards
Allen Mitchell
amitchell is offline   Reply With Quote
Old 07-21-2008, 02:19 PM   #142
surferstyler's Avatar
1972 27' Overlander
San Juan Capistrano , California
Good afternoon Allen, thank you for your comments. And good luck with your trailer!
The flexible material you were asking about that supports the rear of the dinette is home made stuff. I used 3/4" Baltic birch plywood, cut in strips about an 1" wide by 36" long. Every inch or so I cut a groove with my table saw about 1/2" to 5/8" deep. By doing this, it allows the strip of wood to be flexible so you can curve it easily. I did this in a few other places around the A/S, and it really makes it easy to work with curves vs. shaping a piece of wood to the curve. Then, I used 1 1/4" flat head screws to fasten the strips to the aluminum wall. By using screws every 4-6"' it really add a lot of strength on the wall. I also used vertical pieces every once in a while for extra support since my son thinks the dinette is a great place for jumping.
Most of the other joinery on the dinette was all with pocket screws and a Kreg Jig. These make for very strong joints. If you would like to see some more detailed pictures up close, please let me know. Good luck!
Regards,
Ron Althouse
surferstyler is offline   Reply With Quote
Old 07-21-2008, 07:17 PM   #143
amitchell's Avatar
1972 27' Overlander
Dallas , Texas
Thank you, Ron, for the quick reply. In the past, I've made flexible wood panels (for home projects) using the same technique you described... allowing the wood to flex along the sawblade kerfs. I've also done that with drywall, but that was messy!
Your dinette looks rock solid... fantastic job!
The info/help is mucho appreciated.
Cheers
Allen
Old 11-13-2008, 11:17 PM   #144
buffaloman's Avatar
1978 Argosy 24
1977 Argosy 28
Darrington , Washington
well what has transpired since then? care to post pictures???
buffaloman is offline   Reply With Quote
Old 11-14-2008, 07:42 AM   #145
NorCal Bambi's Avatar
1963 16' Bambi
Yreka , California
Images: 21
Drywall can be soaked in water for a short period of time and then bent to curved shapes. I have done this to make arched door ways. Others might have comments on this technique.
Don
Cheers
Allen
NorCal Bambi is offline   Reply With Quote
Old 11-17-2008, 10:37 AM   #146
1972 27' Overlander
We were actually camping up at Refugio, north of Santa Barbara on Friday when you replied Buffaloman. We have done some more work lately, installed new curtains and blinds last week. We had to do some unusual type stuff, as usual. So I'll try to get some pictures going this week and post. Thanks for your reply!
Ron
Old 11-22-2008, 05:21 PM   #147
1977 31' Sovereign
Manchester , New Hampshire
Images: 33
That is not bad I had varmet infestation .
Originally Posted by DaisyandDave View Post
Hi and Congratulations,
We're in the same boat. Just bought a 71 Sovereign that we've gutted. Ours is in a lot worse shape than yours...structural problems with the rear bath floor. And yesterday, while I was hosing out the remaining goop I found hair and teeth. But that's all behind me now.
We have big plans too. My husband used to build boats and I upholster things...that don't have teeth.
If 'n you ever get discouraged just come here to the forum. The people here are really helpful.
I have no flor isues but wow i never knew how much a mouse can infest a trailer till I ripped out my bathroom . OMG wow.
I had nests everywhere.
1976 Airstream Sovereign International Landyacht (renovating)(found DOM plate said 1976)
1968 Airstream Caravel 17 footer
2004 Nissan Titan with BT package
K/N Cool intake air
Duel power exhaust
Mrcrowley is offline   Reply With Quote
Old 03-04-2009, 12:16 AM   #148
kennyp315's Avatar
1965 20' Globetrotter
Woodland Hills , California
Images: 8
New Restoration Project, '72 Overlander
Woow, What a great looking trailer. I have a '65 Globetroter that I did in birch and teak. It looks like a wooden sailboat inside. I am now thinking about getting another little larger (25 Tradewind). You and Kip are inspiring me. I am also a surfer. All the best, Kenny
kennyp315 is offline   Reply With Quote
Old 03-04-2009, 01:06 AM   #149
Brownsville , Texas
Can you put weights underneath the floor to balance both sides?
coltmccoy is offline   Reply With Quote
Old 03-14-2009, 07:37 PM   #150
Snellen 67's Avatar
1967 24' Tradewind
Long Beach , California
Smile Looks amazing!
Hey Ron,
It's Rob and Becki from Long Beach. We met at the San Clemente rally. Your trailer looks great. We are finally embarking on ours after getting the trailer hitch, trailer brakes and other "safety" issues resolved. Do you have more pictures with the cushions, curtains and other details? We would love to see them!
Aloha!
Snellen 67 is offline   Reply With Quote
Old 04-24-2009, 02:29 PM   #151
Dighton , Kansas
Hi Ron,
I am getting ready to start construction on my wrap around dinette and was hoping you would post or send me more detailed photos of how the frame was built and how you made the joints. Your project has turned out great, hope mine goes as well. I have been looking at the idea of using sheet aluminum to finish the dinette. Your ceiling turned out great. Thanks for the help.
Mitch
arhuranna is offline   Reply With Quote
Old 10-17-2011, 03:48 PM   #152
Talent , Oregon
Originally Posted by surferstyler View Post
Well it's been a few weeks, but the plumbing is finished now. I installed all new pex plumbing lines, a new Shurflo wate filter and an Atwood water heater. Here are a few photos of what's going on. Next up, we plan to paint this inside this weekend, put up some recessed lights and replace the center ceiling panels with either Stainless sheeting or Aluminum. Should be a long weekend! By the way, the pex was easy to work with!
All these entries are great, lets see, some 5 years down the line. HOpe you have enjoyed the airstream. Were there any final pics?? CAn I contact you in regards to your efforts, as I am just about to that re-plumbing stage. LEt me know.
thanks,
Richard and Della
Della is offline   Reply With Quote
Old 10-18-2011, 09:56 AM   #153
1972 27' Overlander
Good morning Richard & Della, thank you for your comments. Everything has worked out really well. Just a few small updates in the past couple years, but that's about it. We go camping about once every month or two, I just haven't had to do anything new that has really been worth updating the website for. If you have any questions regarding the Pex, feel free to contact me anytime!
Regards,
Ron
thanks,
Richard and Della
Old 04-09-2012, 11:42 AM   #154
1972 27' Overlander
The Colony , Texas
Images: 11
We started the dinette project today. Can you tell me how much fabric I need for the cushions?
sbooth88 is offline   Reply With Quote
Old 04-16-2012, 08:25 AM   #155
kennyp315's Avatar
Images: 8
Great job. Your wood work is very nice. One word of caution, watch the weight that you are putting in your trailer. I am waiting for my new 6000 lb axle to come in, before my trip to Yosemite in four weeks. When I built my trailer, we ended up adding about 1000 extra pounds. My trailer came out beautiful, but as had towing/tire wear issues for a long time. I finally took it to the scales and weighed it. I then realized the new 4200 lb axle was not going to work on my '65 Globetrotter. Just a word of caution.
Old 04-16-2012, 01:48 PM   #156
kennyp315's Avatar
Images: 8
The under cushion storage is way cleaner look without drawer fronts spoiling your beautiful work. Your wrap around booth, in the front, is almost identical to mine. Clean nice lines like a beautiful wooden sailboat.
Old 04-16-2012, 05:54 PM   #157
Sodbust's Avatar
1972 27' Overlander
Penokee , Kansas
72 Overlander here also.. Been watching from a distance your project and work and looking great..
We lucked out or paid that extra few grand to get ours with everything inside in good stock condition.. Just a good cleaning and its on the road..
In a way I wish now I had gotten a re builder as I would sure have opened up the cabin area more than stock and I sure wanted a rear bedroom.. But that would be a much more of a job to redo all the holding tanks..
Keep up the good work,, and enjoy watching from a safe distance,
Sodbust
2012 Ram 1500 Tradesman Hemi, 4x4, 6 speed
20mpg empty, 14 mpg with 27' Overlander.
Today is the first day of the rest of your life!
Sodbust is offline   Reply With Quote
Old 07-31-2012, 11:47 PM   #158
IowaNewbies's Avatar
1972 27' Overlander
Blue Grass , Iowa
We just brought ours home. your posts are a great reference, please keep it up.
Ozzie
The world is changed. I feel it in the water. I feel it in the earth. I smell it in the air. Much that once was, is lost, for none now live who remember it.
IowaNewbies is offline   Reply With Quote
Old 08-25-2012, 01:48 AM   #159
agdadof4's Avatar
1972 27' Overlander
College Station , Texas
Do you have any photos of what the area under the original twin beds looked like when you pulled them out? I pulled ours out tonight and I am wondering what is original. Thanks and we love everything you have done.
agdadof4 is offline   Reply With Quote
Old 08-25-2012, 03:08 AM   #160
Mulligan's Avatar
kettering , northants
Hi All, after seeing Ron's brilliant rebuild of his 72 Overlander i felt that i had to post some pics of my own refurb on my 73, i imported in to the UK in sept 2010 and it took me about 14months to complete in my spare time.
I completely gutted her so i could rewire to 240v (UK voltage) but i kept a 110v ring for the A/c and the Progressive Dynamics Intelli charger, all pex water lines, i use a eberspacher (i think you call it Webasto ? ) for heating and hot water with a 40ltr twin coil horizontal water tank, so i have a wet central heating system. i replaced all internal skins with Alumininum, I put a fixed bed in the rear and replaced the front gauho with the wrap around diner which like Ron's converts to a queen size bed, room for 2 and a Bernese mountain Dog !!!!.
We are pleased with her but as with all Vintage Airstreams its still work in progress
Cheers
Tim
ID:	166691   Click image for larger version
ID:	166693   Click image for larger version
ID:	166695   Click image for larger version
ID:	166697   Click image for larger version
Mulligan is offline   Reply With Quote
1970 rear bath restoration GTracer Sinks, Showers & Toilets 22 04-24-2007 07:45 PM
1966 Overlander International Double Tamara 1965 - 1969 Overlander 30 03-28-2006 02:55 PM
'58 Overlander in need ! scooter 1954 - 1959 Overlander 6 12-29-2002 10:21 AM
1976 Overlander davidz71 Our Community 2 09-24-2002 07:48 PM
2-door Overlander InsideOut 1960 - 1964 Overlander 0 08-30-2002 08:14 AM
