Old 08-22-2006, 10:03 AM   #81
surferstyler's Avatar
1972 27' Overlander
San Juan Capistrano , California
The weight is an issue that has been in the back of mind the whole time that I have been working on this trailer. So far, things are just a bit heavier than they were originally. For the all the plywood wall panels that divide the rooms, and the cabinet sides, I used 1/2" material. That would pretty much double the weight of the original walnut laminate panels. However, that's not a lot of material, and has only added probably 200lbs including the maple face frames. If I were to make all of the drawers with baltic plywood, and all of the drawers and doors from solid ply materials, it would add a lot of weight I'm sure.
Since weight is a concern, I am considering wire baskets on tracks for several of the drawers with the exception of the drawers under the sink. Wire baskets from HD have smooth tracks they ride on, and are very light. I've been looking at them, and making measurements to include them where possible.
Just estimating, I would guess that after I build the dinette and table, I will be only about 500lbs over the previous weight of the trailer. This weight will work out fine as far as pulling the trailer.
Ron
surferstyler is offline   Reply With Quote
Old 08-25-2006, 11:15 AM   #82
1973 31' Sovereign
Portland , Oregon
Images: 22
Positive latching cabinet pulls...
I would like to weigh in on the topic of securing cabinet doors or drawers for on the road. Somewhere I have seen positive latching cabinet knobs for RV and marine use. I have not yet been able to locate what I remember seeing but here is one RV supply site that has a positive latching knob assembly.
https://www.rvpartsoutlet.com/newsto...inet%5Flatches
Unfortunately the photo does not give much detail. I have contacted these folks in the past though and had them furnish more detail about products.
What I remember seeing was a simple cabinet latch that has a push button in the middle of it. Has anyone else seen anything like this?
Also if someone wants to go really fancy I discovered that Rockler now sells an electric lock set that can lock up to 6 places from a central key. The system runs on 12volts too. Check it out:
http://www.rockler.com/product.cfm?page=10447
Malcolm
malconium is offline   Reply With Quote
Old 08-28-2006, 03:09 PM   #83
1972 27' Overlander
Update with photos
Well, we finished the counter tops over the weekend, and installed them with a new sink, faucet and the old stove. We wanted to keep something of the old, so the stove may be it. It just needs a severe polishing. We found a nice laminate that we like, and used contact cement to apply it to "light weight" melamine. Also, we found some realy nice aluminum trim for the edges. The sink, faucets and traps were from Ikea. We're also going to use something as a backsplash, but haven't yet decided upon what to use. Oh, we also added a new stereo and subwoofer. Bump, bump, bump.....
* Please note. If anyone is interested in the aluminum trim we used, we bought too much! We ordered a 12' strip of it, and the gal messed up and charged us, and sent us 12 of the 12' strips. Shipping was too much to send it back. So if anyone is interested, I'll be happy to send you a strip of the stuff. Say $2 per strip of 12' trim, plus the shipping.
Here are some pictures.
ID:	25313   Click image for larger version
ID:	25315   Click image for larger version
Old 08-28-2006, 03:38 PM   #84
1972 27' Overlander
Here's more info on the aluminum trim:
It was in 12' lengths and they cut it to 8' & 4' lengths to ship. It's 13/16" thick, so 3/4 mel plus laminate is great with a little extra reveal of the trim. It does have a slot edge on the back, which they suggest a 3/32" slot bit. That's what I used, but I think a 1/16" may have had a tighter fit.
Old 08-28-2006, 06:32 PM   #85
tphan's Avatar
1972 27' Overlander
Longmont , Colorado
Looking great!!
Ron- it is really shaping up now! I do like your countertop trim, it is a nice detail. It is a bit hard to see the color or pattern of your formica- can you post another pic of that? As far as the stove top goes, I also re-used it and getting it to look decent was a chore, as there was a fair amount of pitting. A combination of orbital sanding, sand-blasting (to get the old orange paint off), steel wool, stainless polish- just a heck of a lot of elbow grease and it certainly does not look anything like new but acceptable, with "character". I wonder if the whole thing could be chromed or something? But I like the 4-burner set-up, and it was "free". Will you put back the upper cabinets, or in some other way have lights over the sink and cooktop? Keep up the fantastic work- Tim
tphan is offline   Reply With Quote
Old 08-28-2006, 07:10 PM   #86
cameront120's Avatar
1972 25' Tradewind
The previous owner of my trailer had the stove top chromed. You might even look into enamelling it. Heat can be detrimental to chrome if it isn't done well.
North Vancouver, BC
Old 08-28-2006, 08:00 PM   #87
Remember, Safety Third
Jim & Susan's Avatar
Possum Trot , Georgia
Ron, just to echo what others have said, it really is lookin' great!
www.nesa.org
Air No. 6427
Jim & Susan is online now   Reply With Quote
Old 08-28-2006, 08:35 PM   #88
uwe
418
uwe's Avatar
2007 25' Safari FB SE
1958 22' Flying Cloud
1974 29' Ambassador
Yucca Valley , California
Images: 41
Ron,
I might be interested in some of the trim.
Uwe
www.area63productions.com
Old 08-29-2006, 09:18 AM   #89
sequoiacoast's Avatar
1968 24' Tradewind
Eureka , California
I PM'd you, but just to be sure... I am interested in your left over trim. I need at least as much as you think you guys used.
Thanks for posting all the great photos of your work... it helps me feel like finishing it is actually possible. (My tradewind has been stuck at the plumber's house since July - he's helping us with plumbing and installing new axles... he's a friend... )
sequoiacoast is offline   Reply With Quote
Old 08-29-2006, 10:36 AM   #90
1972 27' Overlander
Tim, here is a picture of the laminate that we used for the counter tops, as well as swatches that we are using for the cushion fabrics in the kids room, and for the wrap around dinnette that we'll be making. With a piece of maple for contrast. Also, we have decided to replace just our awning fabric since the hardware is in good shape. At the top of the picture is a sample from Sunbrella of the fabric that we chose to tie in the colors. This should make a statement!
PS. Down to 3 of the 8' pieces and 10 of the 4' pieces of the aluminum trim now. If you're interested, let me know before it's gone.
Ron
Old 09-02-2006, 06:05 PM   #91
1972 27' Overlander
Farmington , Washington
we are just beginning
My husband and I just went to town and came home with a 72 outlander. It is pretty much gutted on the inside down the side that should have the refridgerator and closets. The sink and stove and bed frame (for a single however there are two identical mattresses) and the bathroom are still completely in tact. There is no structural damage or leaking or signs of mice entry. It cost us less than a large tent but I am sure the costs are sure to come!
I took so me pictures but am not sure how to include them. I am very new to this idea of a forum but could really use the help in the future. I will learn how to participate in the forum as we go. We are very new to airstreams let alone camper trailers!
April
pfaff is offline   Reply With Quote
Old 09-02-2006, 06:06 PM   #92
1972 27' Overlander
I meant an overlander. I told you we are very NEW to this Airstream concept!
April
Old 09-02-2006, 07:23 PM   #93
1972 27' Overlander
attempting to send pictures
I am going to attempt to send some pictures. I hope it works. I would like to know what you experts think!
Old 09-02-2006, 07:47 PM   #94
1972 27' Overlander
it says I have uploaded pics
It says I have uploaded pics and used up some space??? I will just attach one and see what happens.
Old 09-02-2006, 07:50 PM   #95
1972 27' Overlander
more of the new '72
Now, I am on a roll.
ID:	25511   Click image for larger version
Old 09-02-2006, 07:53 PM   #96
1972 27' Overlander
oops
It worked and then I deleted it. If you all still want to talk to me after this annoyance...I will finish up.
Geez!
Old 09-03-2006, 09:07 AM   #97
1972 27' Overlander
April,
Looks like my trailer did after we gutted it. As you'll see from the pictures above, and all over this website, there are a ton of things you can do to rebuild your A/S. When you get time, start yourself a thread with your name on it, and post all of your pictures, as well as your weekly, or daily updates. We'll all be looking forward to seeing what you do with it.
Good luck!
Ron
Old 09-03-2006, 09:38 AM   #98
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
really nice job ...makes me even more motivated. I sure did love the cork in my motorhome.This time around I went for the laminate, hope it will hold up as well.
1966 overlander..sold
AIR #005
OUR AIRSTREAM PASSION! BLOG
RESTORING AN AIRSTREAM
retired!
Old 10-09-2006, 10:36 AM   #99
1972 27' Overlander
Small progress
As usual, things have been progressing a bit slower than I would prefer at this stage. However I did manage to get some of the drawers made over the weekend. Using 1/2" Maple ply, since I have a ton left over, and a locking joint to secure the pieces together. 1/4" round over bit on the top to have nice edges too. I made the drawer fronts from 3/4" Maple Ply but didn't snap any photos yet, I'll be sure to take some when they're installed this week.
More to come..........
Ron
ID:	26768   Click image for larger version
Old 10-09-2006, 10:26 PM   #100
NorCal Bambi's Avatar
1963 16' Bambi
Yreka , California
Images: 21
suferstyler, very nice work, will be waiting to see the final product. I'm sure your work will outlast Airstreams.
Don
NorCal Bambi is offline   Reply With Quote
1970 rear bath restoration GTracer Sinks, Showers & Toilets 22 04-24-2007 07:45 PM
1966 Overlander International Double Tamara 1965 - 1969 Overlander 30 03-28-2006 02:55 PM
'58 Overlander in need ! scooter 1954 - 1959 Overlander 6 12-29-2002 10:21 AM
1976 Overlander davidz71 Our Community 2 09-24-2002 07:48 PM
2-door Overlander InsideOut 1960 - 1964 Overlander 0 08-30-2002 08:14 AM
