Look for a cutout in the floor under cabinets on the same side of the trailer where you fill the water tank. For a '72 Sovereign, that would be on the door side, and the cutout would be inside the kitchen cabinets. Down in there, you should find the drain valve for the fresh water tank.
Here's where I found mine on my 1970 Sovereign. It's under the sink to the right of the furnance. That white tabbed knob way down there is the drain. If you have trouble reaching it, make a notched stick to reach down with - works like a charm.
Hope this helps.
Bill
There are also 2 valves in the bathroom cabinet to drain the lines back there as well.
Don't forget to remove the plug or open the drain on the water heater.
There are a number of good threads here on various winterizing techniques.
My fresh water tank does not have a drain. It's emptied by running the 12 volt pump.
Click on the link to see a picture of the Sioux River falls near my home. https://visitsiouxfalls.com/assets/i...uxfalls-og.jpg
Good point.
Tom
Interesting. My 1974 Sov rear bath does, so I imagined that a 1972 would as well.
