Old 04-27-2011, 12:10 PM   #1
1970 27' Overlander
Santa Rosa , California
Help with installing light fixture
Hi....again,
I need help wiring this light fixture 12 Volt. The first attempt is making my circuits pop.
Which wires go with which (witchy wires!) Here are pics:
Name:	1st attempt.jpg
ID:	128351   Click image for larger version
ID:	128353   Click image for larger version
Name:	Wall Light socket.jpg
rverforlife is offline   Reply With Quote
Old 04-27-2011, 12:16 PM   #2
x
XXXX , XXXX
The light is 12VDC low voltage and from what I can see you are trying to connect it to a 110VAC circuit. No wonder the circuit popped.
wasagachris is offline   Reply With Quote
Old 04-27-2011, 01:06 PM   #3
Minno's Avatar
1972 31' Sovereign
Lexington , Minnesota
Exactly what is popping? A circuit breaker (110 VAC) or a fuse (12 VDC)?
I agree with Chris - looks like you're trying to wire a 12 volt light into a 110 VAC circuit.
Chris
Old 04-27-2011, 10:18 PM   #4
1970 27' Overlander
OK well when I saw that missing fixture, i thought i'd buy a nice sconce to cover it. I thought I had to use 12 volt. I'm so confused about this shuff!! So I can just buy a household sconce for that space?
Thank you both!
Old 04-28-2011, 06:31 AM   #5
Minno's Avatar
1972 31' Sovereign
Should be able to, yes. But first, do you have a multimeter? And do you know how to use it? It would be nice to verify that it's 110 VAC before you connect something to it. But be careful measuring the voltage across the black and white wires! You don't want to touch the bare wires, or have the black wire touch any metal in the trailer, including the ground connection in the box (where the bare wire and green screw are located).
A 110 VAC fixture would connect white to white, black to black, and the bare wire on the fixture connects to the ground connection in the box.
Chris
new light fix, wall socket
Tail Light Monitors? MDSilverado Lights - Interior & Exterior 3 10-19-2015 07:15 PM
How to Light the Pilot in the Oven lcurrie Stoves, Ovens & Microwaves 3 08-01-2011 07:16 PM
New Light for the cedar closet Dan@LED4RV Commercial Listings 6 04-07-2011 07:04 PM
Flash of Light !! donking General Repair Forum 8 01-24-2011 02:16 PM
Installing Propane light lucymcdog LP Gas, Piping, Tanks & Regulators 69 01-22-2011 11:12 PM
