Old 08-06-2008, 04:00 PM   #581
Remember, Safety Third
Jim & Susan's Avatar
Catfish Corners , Georgia
Before and after looking forward
Name:	Looking Forward.jpg
ID:	65186   Click image for larger version
www.nesa.org
Air No. 6427
Old 08-06-2008, 05:45 PM   #582
Lothlorian's Avatar
Loganville , Georgia
Jim:
It is me SIU Bound (Brian) I changed my name on the forum. Trying to keep everybody off balance. No I wanted to include my wife since she has done as much work as I have.
Your AS looks great. Man you will have a new rig when you are finished. I was checking out Indian state park down by your neck of the woods. Looks like a great place.. I am amazed with the type of work and detail you put into that trailer. It is looking awesome.
Lothlorian
Formely SIU Bound
Brian
Brian & Adrienne
Lothlorian is offline   Reply With Quote
Old 08-06-2008, 06:07 PM   #583
Thanks, Brian. I saw your thread about the name change and I have you on my buddies list. Now I just need to rememebr who belongs to that new name. Just kidding.
www.nesa.org
Air No. 6427
Old 08-06-2008, 07:23 PM   #584
vhord's Avatar
Images: 96
Great!!!!!!!!!!!!
It looks fantastic! Reading your previous posts you mentioned that you rolled the primer. Did you also roll the finish. It looks as if it were sprayed but I don't see any maskings. Keep up the good guidance. I love it! I hope to be not too far behind you (maybe a few months however ).
vhord is offline   Reply With Quote
Old 08-06-2008, 07:46 PM   #585
Yep, rolled the whole thing. I'm very suprised how this looks. Do you have vinyl walls in your '70 model? I can't remember when Airstream switched to the vinyl.
www.nesa.org
Air No. 6427
Old 08-07-2008, 06:28 AM   #586
vhord's Avatar
Images: 96
Yes, mine has a vinyl coating. The PO painted most of the walls and I have no idea what prep if any they did. Therefore the first thing that I will need to do is strip it. We have been experimenting on some of the smaller pieces. It appears that my best bet will be using a water rinsible stripper and pressure washer.
My game plan is to strip and prime the sheets while they are out. I will put the final coat(s) on after installing them. I am very interested in your progresss and results.
Old 08-08-2008, 05:27 AM   #587
Addicted to Aluminum
A-Merry-Can's Avatar
1959 18' "Footer"
1964 24' Tradewind
1954 29' Liner
Woodstock , Georgia
Looking awesome, Jim! I can't wait to see it in person someday!
JP
there's always room for one more!
A-Merry-Can is offline   Reply With Quote
Old 08-08-2008, 08:16 AM   #588
Usually Sleepy
biggoofball's Avatar
East Haven , Connecticut
Images: 14
I love this picture:
"tools - check. chair - check. tv - check. waste basket - check. let's get working."
Oh!! almost forgot, I love the blue paint in the bedroom.
Skip
biggoofball is offline   Reply With Quote
Old 08-08-2008, 10:37 AM   #589
You left one item out...BEER!!!! Hey at my age, I take a lotta breaks.
www.nesa.org
Air No. 6427
Old 08-08-2008, 10:43 AM   #590
Usually Sleepy
Images: 14
I always forget something.
Skip
Old 08-09-2008, 12:42 PM   #591
Well, I need an idea. I'm trying to finish up the last bits of painting and the Sherwin-Williams products seem to be doing well. Take a look back at post 581 at the last two pictures. Specifically, the Tambour over the gaucho area. See how yellow it is? I need to paint that with something. I'm afraid that the primers and paints used on the walls won't work very well on the Tambour because it has to stay flexible in order to work properly. Anybody got an idea of what to use? Maybe a can of automotive spray paint for plastics?
Thanks in advance!
www.nesa.org
Air No. 6427
Old 08-09-2008, 01:40 PM   #592
Lothlorian's Avatar
I would use a spray primer and paint for that material. The sliding doors look like they should use an enamel paint. I would give it several light sprays. I would not spray it on to thick. I would finish the part that does not flex with an artist brush. It is hard for me to explain so I hope you understand what I am trying to get across.
Brian
Brian & Adrienne
Old 08-09-2008, 03:15 PM   #593
Usually Sleepy
Images: 14
How about something simple like that Krylon Fusion paint? It's a rattle can so you'll have to tape off well. I've used it successfully on several plastic products. The paint stays adhered when the plastic bends too.
Skip
Old 08-09-2008, 03:26 PM   #594
Good ideas, guys. I'll see what I can find tomorrow. Thanks for the tips!
www.nesa.org
Air No. 6427
Old 08-13-2008, 09:25 AM   #595
So, any updates on what you did for the tambour? I love watching the visible progress you're making right now.
Old 08-13-2008, 11:41 AM   #596
Not yet. I've been working on smaller stuff. It'll probably be some time next week before I get to that particular task. Other stuff keeps getting in the way.
www.nesa.org
Air No. 6427
Old 08-13-2008, 05:22 PM   #597
maccamper's Avatar
1974 29' Ambassador
1966 20' Globetrotter
Central , Illinois
paint for tambour
I used Krylon Fusion on the yellowed plastic tambour doors in the bath on our trailer and it is holding up very well so far(about 8 months).
maccamper is offline   Reply With Quote
Old 08-27-2008, 04:54 PM   #598
Here you go guys. I finally got the tambour and shelf completed. I did indeed use the Fusion paint and it looks really good. Thanks for the tip, folks. The tambour actually looks much better than in the pic. There are a couple of areas around the "handles" in the center that didn't take the paint very well. I'm guessing it's the fabric material on the backside having some kind of problem. Eric wants to make some kind of new handle out of wood to replace the first couple of inches from the center out toward the ends.
www.nesa.org
Air No. 6427
Old 08-27-2008, 05:00 PM   #599
And here's the shelf behind the tambour. This came out nice as well. As you can see, some knucklehead cut out the back of the shelf somewhere along the way. Gotta replace that as well. Will do that when I put the radio in (hopefully soon). This shelf is made of aluminum and was painted dark brown, much like the rest of the interior. I scuffed it with 200 grit sandpaper, cleaned, primed, then painted with the same Krylon. No more "cave" look there now.
www.nesa.org
Air No. 6427
Old 08-27-2008, 05:17 PM   #600
Also finally finished up the wheel wells. The wheel wells in this era Airstream have a heavy plastic black outer cover that is installed when the floor goes back in. Both had a hole punched in them up in the front, presumably from rocks kicked up by the tires. I patched these over with fiberglass mat and resin. Worked well. Then insulated with a thin layer of "pink stuff". Then riveted and screwed back on the inner cover (no pic of that, sorry). The inner cover is a little brittle in places, so I had to carefully drill new rivet holes in the wall attachment areas.
Before and after pics.
Name:	Wheel Well 1.jpg
ID:	66418   Click image for larger version
Name:	Wheel Well 2.jpg
www.nesa.org
Air No. 6427
Favorite Jerry-Rig? Dave Cole General Repair Forum 58 10-07-2013 09:50 AM
Part Time vs Full Time (Days/Year) InsideOut Community Polls 30 10-23-2005 09:43 AM
Full Time RVer's awsome site! Forrest Link Archive 1 02-10-2003 12:36 PM
Twin rear beds DClark General Interior Topics 15 11-24-2002 08:49 PM
Full timeing Airstreem T/T/ tec12 Our Community 7 11-13-2002 01:13 PM
