Old 05-03-2021, 01:50 PM   #1
Watsonville , California
Rotten floor question
So it looks like the floor in my 2007 19’ is rotting out near the door and under the dinette. I pulled up the vinyl floor and it looks like it is in definite need of replacement.
Has anyone used Airstream for this repair? Thoughts/Experiences?
retrofireman is offline   Reply With Quote
Old 05-03-2021, 02:46 PM   #2
Rich W's Avatar
I'm In , Kentucky
I had a soft spot in the front center of my AS. I took it to Jackson Center to have it repaired. I had already removed the furniture and pulled back the vinyl flooring for about the front 25%. It looked to be stained in multiple areas but solid, except for the soft spot. I asked them about replacing the flooring and the tech said they would only do a "shell off" flooring replacement. At $120/hour I figured it wasn't worth it.
I have seen on the forum here where people have replaced the vinyl, even added carpet, in the walk areas. I have not attempted it.
After repairing the soft spot the tech bleached out the vinyl and it looked very good when he finished. If you have soft spots I would say to have them repaired, bleach the vinyl and make sure you have the leaks fixed.
-Rich
Rich & Yvonne
2006 Safari SE -Dora-
2004 4Runner SE 4.7L V8
Rich W is offline   Reply With Quote
Old 05-04-2021, 12:32 PM   #3
1969 18' Caravel
Greenville , whereEverIroam
Images: 20
This is probably the most common and annoying problems with all airstream trailers.
The good news is there are tons and tons of posts on this forum detailing different methods of replacing this section of the floor.
Search the forms using the term rotten floor, or browse the floor replacement subforum here, there are lots and lots of posts
You can replace the section of the floor without having to do a shell off restoration. You will have to determine whether or not you want to replace the floor with more plywood, which will rot out again in about 10 years, or to use more expensive composite material like Coosa board which will basically last forever.
skyguyscott is offline   Reply With Quote
Old 05-04-2021, 02:32 PM   #4
Lost in America
mojo's Avatar
2015 27' FB International
2004 19' International CCD
Santa Fe , New Mexico
Depends how deep the rot goes. If it goes all the way through, you may need to replace it. However, if it is only partially soft, you can let it dry and chisel out the soft stuff. Then apply a wood epoxy sealer to coat what's left and then fill the gaps with a wood epoxy filler.
This is the strangest life I've ever known - J. Morrison
2015 Airstream International Serenity 27FB
2017
Chevy Silverado 2500HD Duramax Diesel
mojo is offline   Reply With Quote
Old 05-04-2021, 02:34 PM   #5
2002 19' Bambi
Lafayette , California
If it is something you can't do yourself, I suggest contacting Vinnie's North Bay Airstream Repair (http://www.vinniesairstream.com/). Vinnie does excellent work.
He can also find the leaks that have caused the problem. Replacement plywood will last if it is not allowed to be repeatedly wet and dry.
Tim
Tim A. is offline   Reply With Quote
Old 05-04-2021, 05:29 PM   #6
Sag Harbor , New York
Per earlier good suggestions . . . some search results to check out leading only to posts here on AF:
Rotten plywood floor: https://www.google.com/search?q=rott...=airforums.com
WEST epoxy: https://www.google.com/search?q=WEST...=airforums.com
Threads:
https://www.airforums.com/forums/f36...xy-108608.html
https://www.airforums.com/forums/f44...fb-199869.html
https://www.airforums.com/forums/f46...er-212832.html
Floor repair forum: https://www.airforums.com/forums/f36/
PS -- Good short recent "small hole in subfloor" thread:
https://www.airforums.com/forums/f36...or-221144.html
Good luck,
Old 05-05-2021, 08:09 AM   #7
SuperTrouper's Avatar
2008 27' International FB
Petaluma , California
Tim
X2, Vinnie is great. If you do want to try the work yourself, check out this thread. Unfortunately, I was in the middle of the work when I met Vinnie for the first time. https://www.airforums.com/forums/f39...ml#post1262866 - Brad
SuperTrouper is offline   Reply With Quote
Old 05-09-2021, 09:16 PM   #8
Johnco's Avatar
2006 19' Safari
Irvine , California
Had the same experience with my 2006. Water was leaking out of the fresh water fill connection on the inside under the street side dinette seat and going under the flooring unnoticed. C & G did the repair (they are no longer in business). They removed both seats, peeled back the flooring and replaced all the rotted plywood. Repair is solid to this day. I would recommend Vinnie as well, have only heard positive things about his work. Best of luck!
Think like a Proton-Stay Positive!
Johnco is offline   Reply With Quote
Old 05-10-2021, 06:30 AM   #9
Welcome to the forum. Are you catching this good advice, almost a week later?
Newbie needs advice on fixing rotten floor Lyvettely Repairing/Replacing Floor &/or Frame 32 11-26-2014 02:48 PM
What to do about my rotten floor??? utahredrock Repairing/Replacing Floor &/or Frame 15 11-03-2011 01:38 PM
rotten floor by door colin57 Leaks - Weatherstrips, Gaskets, Caulks & Sealants 3 01-05-2008 10:17 AM
What to do? Rotten floor cbl3030 Repairing/Replacing Floor &/or Frame 13 08-24-2006 01:25 PM
Rotten floor BurnBound Repairing/Replacing Floor &/or Frame 16 02-05-2006 09:03 PM
