Refrigerator replacement
So, my 2014 16 ft sport had the Dometic gas/ 110 refrigerator (RM2351) which would not cool when the temperature outside was over 95°, the door opened many times while traveling and my wife did not like turning it off at gas stations. I installed a Dometic NRX 115S Compressor Refrigerator, which I purchased from Amazon (disclaimer; I received no funds from anybody for this post) I removed the old unit and the floor, capped the propane line under the trailer, rolled back the wiring and taped the ends. Ended up with 3 sets of wires rolled up under the sink. The wood panels under the stove above the old fridge were connected with green painter tape, which I replaced with foil duct tape( not the other duck tape). I cut the bottom front trim panel and moved to the top of the opening and then cut the opening wider. I moved the rubber seal forward about 4 inches, electrical came from the power distribution area under the dining seat and the drain tube used the old holes from the removed gas line. With the floor removed, spacer blocks were installed for the electrical to run underneath the new fridge. I installed a drip tray under the vents, draining outside and once the fridge was in place and fastened in the front, I fabricated a pair of L brackets to attach to the back and cabinet sides. The fridge worked great on our first trip out, has more room, the unit is very quiet and only used 14% of a 280 amp litime lithium battery in 8 hours.
