12-30-2019, 08:01 AM
Sheridan
Picture Hanging in an Airstream
How do you hang prints on the aluminum skin of an Airstream? We have several unframed but matted prints hanging in our Sport. I used Command strips and they've stayed in place quite well. Now I'm considering having the prints framed ( the'yre getting dusty and frayed ) but that will add weight and there's a little gap between the back of the matt and the frame. The gap is a little thicker the Command strips.
Any suggestions?
12-30-2019, 08:14 AM
Sheridan
Here's a photo
12-30-2019, 08:30 AM
2012 25' FB International
Trent Woods
, North Carolina
We attach the Command Strips to the frame and it works fine
Larry
12-30-2019, 08:47 AM
2022 Atlas
Homosassa
Same here. We use the velcro command strips.
12-30-2019, 09:07 AM
2009 27' FB Classic
Sacramento
Picture hanging
If the gap is too large I glue a piece of cardboard to the back before applying the command strip. If the pierce is heavy I use more command strips.
12-30-2019, 09:20 AM
Married with Airstream
2004 25' International CCD
Vancouver Island
, British Columbia
Velco strips with plexiglass NOT glass in the frames
La Dolce Vita Brick & Mona
We're Married With Airstream dot com
2004 International 25CCD Registered Name "Blue Streak"
2013 F-150HD FX4 SuperCrew Lariart (MaxTow) "Red Dragon"
12-30-2019, 09:51 AM
2012 25' FB Eddie Bauer
2009 19' International
Aptos
We also hang framed pictures over the two tv screens in our 25’fb using inverted Command Strip hooks that fit over the tv’s top edge. We size the frame and matting slightly larger than the screens. The pictures lie in the bed while traveling and any place handy while watching tv. The pictures are a much warmer presence than the gaping black maw of the tv screens.
12-30-2019, 10:01 AM
Stay CazuaL
2018 25' Flying Cloud
2014 19' Flying Cloud
Reseda
Alternatively, try
3M Dual Lock Reclosable Fastener SJ3560 250 Clear
They are better than Velcro IMHO because you don't need to worry about which half you have and they hold more firmly.
12-30-2019, 10:12 AM
2014 27' Flying Cloud
Stowe
, Vermont
We too remove pictures, clocks, etc. while on the road so that nothing will be damaged.
12-30-2019, 10:19 AM
Napa
We actually got a nice wall clock to stay using the picture command strips! We'd tried a bunch of other things and it was always either off or dangling...to the point that our first clock got ruined. Double command strips placed where they best balance on the curved frame and...perfection. 6,000 miles and is hasn't moved.
We often travel daily and having to take everything down and then put it back up again is not going to happen. If it doesn't stay where we put it, it doesn't get to go!
12-30-2019, 10:24 AM
Sag Harbor
, New York
You can always install small threaded fasteners into the structural frames/ribs, and hang stuff from them. A small truss-head SS screw would look OK IMO. If the fastener is no longer needed, just back it out and install an aluminum rivet in the hole. Most folks would never notice it.
For instance:
https://www.jamestowndistributors.co...ct.do?pid=1767
Probably best to put a little Loctite on the threads to keep it from backing out on the road.
https://www.jamestowndistributors.co...uct.do?pid=558
Happy New Year!
Peter
12-30-2019, 11:36 AM
2008 19' Bambi
2012 23' Flying Cloud
2016 25' Flying Cloud
Bandera
Originally Posted by trikdacy
Ditto!
12-30-2019, 01:26 PM
2018 25' International
chino hills
We had our favorite photos done on aluminum through Costco. Quite light. And style wise complement our airstream interior . Command works well, as they are quite light, easy to store while traveling .
Happy New Year to you all. Safe journeys . It is not the Destination but the time spent with family and friends that makes the journey amazing every minute of every hour of every day.
12-30-2019, 02:12 PM
2015 25' FB Flying Cloud
Grapevine
Mouse Pad Pix
My wife found a source online, and had a Groupon to use, so she had digitized photos emailed to the provider for printing onto standard custom-printed, flexible computer mouse pads.
Works great with double-sided tape since they are flexible to fit the curves of the Airstream and light-weight so minimal danger of falling off the walls. Over 6,000 mile this past summer with no failures!
And if they do come off, accidentally or deliberately, nothing is damaged. And easy to move to another location.
And.... if you forget your mouse pad, they serve as spares!!
12-30-2019, 02:13 PM
1976 31' Sovereign
Oswego
12-30-2019, 06:01 PM
Still Learning
2013 25' International
Benzonia
, Michigan
We cut foam board [office supply item] to fit the picture then mount the pic with spray adhesive to the foam board and then mount foam board to the alum walls with Command Strips. They weigh almost nothing, never fall off and we like the unframed modern look.
Also, we buy the vintage look post cards when we visit National Parks and mount those on the walls the same way for inexpensive, lightweight mementos.
The only thing we have to remove for traveling is our weather station/clock.
Kat
12-30-2019, 07:01 PM
Master of Universe
2008 25' Safari FB SE
Grand Junction
We had little aluminum wall space in ours, but maybe you have a bigger trailer or don't have panoramic windows. And we did enjoy the variety of colors reflecting off the aluminum. We have attached a poster to a wood wall with artist;s putty. You get a blob, roll it in a ball, attach it to the corners of a poster or photo and push and flatten it to the wall. Not good enough for a frame perhaps unless you use a lot of it, but good for posters and such.
Gene
01-04-2020, 12:23 PM
2018 22' Sport
Blue Sky Ranch
I tried everything on a digital clock/thermo to keep it on the bathroom wall facing the interior. When the summer heat sets in, velcro and other strips become soft and will eventually fall off the wall if any weight is involved.
Final: A simple, single screw into the bathroom wall with velcro on the bottom of the clock to keep it from swinging during travel. Figure the next owner will like both the clock and/or the screw.
I have successfully used the command strips on lightweight items. Like some said, it is wise to pull anything off the aluminum wall or dividers while in motion. Just cheap insurance.
M!ke
2019 Tiffin Wayfarer 24TW
Ham Radio Call sign K5FT
01-04-2020, 12:46 PM
Master of Universe
Grand Junction
There is another type hook that I used on a clock. It could release behind the $10 clock I put in the trailer, so I could change the battery and reset the time when the clock was wrong. I used it successfully for almost ten years, but I can't remember the name of the hook assembly. I think it started with a "H". There may be others—just two parts, one screwed to the wall with a couple of small screws, the other to the back of the clock. The parts lock together and can be separated. Those cheap clocks have some places to put screws, or just improvise with drilling some holes and using some short bolts and nuts. When you sell then trailer, this $15 at most (unless you want a fancy clock) investment goes with it.
Gene
