05-13-2017, 01:57 PM
Sheridan
New Sport Owner needs Advice
We bought a new 16' Sport last week and need advice. Every time I turn the battery switch to off, and then on again the radio comes on near full volume. Radio is in a cabinet so first time it happened I thought maybe the dealer left it on. Next time it happened took time to figure out where it was coming from.
Anyone know how to override radio coming on automatically when power is switched on?
05-13-2017, 02:03 PM
Biloxi
, Mississippi
Have you checked the owners manual for a solution?
MICHAEL
05-13-2017, 02:29 PM
Summit
, New Jersey
Mine does exactly the same thing. No idea why.
05-13-2017, 02:54 PM
Sheridan
I could not find anything in the radio manual.
05-13-2017, 02:56 PM
Princeton
, New Jersey
Yes that would be a nuisance but may I ask why you are turning the battery switch off to begin with? I had my trailer for 26 years and have not turned it off yet.
It would be easy to install a single pole switch in the power line to the radio to stop it from happening. Come to think of it I don't remember ever using the radio either.
2004 Excursion 4x4
05-13-2017, 04:54 PM
Sheridan
When we took deliver of the Sport they had turned the battery switch ( under the table ) to the off position . I always keep the battery switch in the off position when the trailer is not in use. There is drain on the battery even when not in use, unless the switch is off. Am I missing something particular to Airstreams?
05-13-2017, 05:44 PM
Retired.
, At Large
The radios in the Sport models will turn on when power is first applied. If this is something you find annoying enough to do something about, the single line switch to keep the power off is about the only solution, other than replacing the radio.
05-13-2017, 06:24 PM
Sheridan
It's not that annoying now that I know what's going on . And I'm not camped next to someone wondering where that loud music's coming from.
05-13-2017, 07:42 PM
2016 16' Sport
Miami
The face is removable and there is a storage case for it. You could try leaving in off.
05-14-2017, 01:25 PM
2013 16' Sport
Boulder
One caution: I have turned on the battery when the trailer was parked (not in use), had the radio go on without noticing it, and completely drained the batteries. So I find this more than an annoyance -- but I have managed to train myself to check and turn off the radio each time.
Overlander, can you give details on installing a switch?
Caroline
05-14-2017, 04:22 PM
:SPACE A" S/O 11 Air19745
2006 34' Classic S/O
Fort Worth
These radios are designed that way to preserve the internal memory. If you don't want to wire in a radio master switch just leave a nearby light on to remind you to turn off the radio when you turn on the battery switch. A poor man's pilot light.
guskmg
