10-14-2020, 06:30 PM
2022 25' Flying Cloud
NCR
, Ontario
new 110v power outlets added
there are never enough power outlets in the As trailers
i added three more
easy to do if you are handy, know AC power and have the tools
- facing the fridge
- under the table
- by the front entrance
10-14-2020, 07:23 PM
2019 22' Sport
Port Coquitlam
, British Columbia
Nice job!
You are right about the outlets. I would really like another one on the outside.
Peter.
"Live Long and Prosper \\//" - Spock
12-06-2020, 06:52 AM
2024 23' International
South of Austin
This is done to prevent people from over loading the rated circuit load carrying capacity. If AS and various MFG did not do this, dummies would over load the circuit and trip the breakers. This, would cause silly question problems for the MFG where they would have to tell people to stop over loading it. By limiting the plugs, theres fewer things plugged in and fewer dumb questions for AS to answer.
12-06-2020, 07:05 AM
2009 25' FB International
2018 27' Globetrotter
Tavares
Certainly good points! But I agree with the shortage of outlets. And some are at difficult to access locations. Like the one under the table on our GT. It requires getting on your hands and knees and crawling to get to it. It could have easily been located to a more accessible location.
We use a small electric heater in the aisle way and the closest outlet is above the sink in the kitchen. So we are adding an outlet for that specific purpose.
12-06-2020, 07:21 AM
South of Austin
Oh believe me, every time I plug in my coffee pot I grumble that its too far away
Though once I plug that in, that draws darn near the max power for the whole circuit
Example, why is there not a plug over the rear bed on mine? I think because the MFG assumes you will plug something in over there that will set the bed on fire. And frankly I believe they are correct!
12-06-2020, 08:05 AM
2018 30' Flying Cloud
Springfield
, Ohio
I find that I have fewer and fewer items that require 120 volts. More and more items are battery powered which only require 5 volts to recharge from a USB outlet. Many of the other items I plug into 120 outlets actually run on 12 volts or less through a transformer in the power cord. I can plug a power strip into an outlet and run my laptop, power my phone and several other items off of it. I have two USB outlets on each side of the rear bed that I use and a 120 volt outlet on each side that have never been used. My coffee pot and toaster set on the counter by the stove and there is an outlet for them. The TV's are permanently mounted on wall mounts with electric outlets - no problem there. Maybe I'm one of the lucky few that have no need for more outlets.
12-06-2020, 08:34 AM
Evergreen
I added an additional USB outlet in the bedroom, and I’m in the process of adding another under the dinette. I haven’t found a need for any additional AC outlets.
Dennis
Past:
Airstream International Serenity 23FB
Newmar Ventana 3715
Thread |
Thread Starter |
Forum |
Replies |
Last Post |
No power to some 110v outlets
TxDave |
Electrical - Systems, Generators, Batteries & Solar |
10 |
10-21-2015 04:16 PM |
Lost 110v power in new Classic
Jcimral |
11 |
10-07-2015 08:48 AM |
110v Power Cord Configuration
bevman |
11 |
04-11-2011 01:33 PM |
110V outlets
cookeville34 |
2 |
09-17-2006 07:15 AM |
Replacing 110v main power line
gr63air |
7 |
07-12-2006 02:42 PM |
