Old 09-16-2024, 12:08 PM   #1
farafield's Avatar
2018 16' Sport
Charlotte , Vermont
Leaks and flooring
A long strange journey...finding leaking, ripping up the floor, cutting a piece of the subfloor, replacing subfloor piece and then putting in an LL Bean waterhog mat, cut to fit, over the subfloor. After experiencing hidden leaking and a rotting floor, I no longer want to have permanent flooring that hides and seals in water. I am not especially handy like many here, but I am learning.
Don't let the sound of your own wheels drive you crazy...
Kim
Charlotte, VT
2010 F-150, 5.4l, V8, 3.55; Bramble: 2018 Bambi Sport 16
farafield is offline   Reply With Quote
Old 09-16-2024, 01:09 PM   #2
2019 22' Sport
High River , Alberta
I'm sorry to see you struggling with a relatively new trailer. What was the source of the leak?
AlbertF is offline   Reply With Quote
Old 09-16-2024, 04:09 PM   #3
farafield's Avatar
2018 16' Sport
Charlotte , Vermont
Thanks. It could have been much worse. At least I think, optimistically thinking that under the fridge and under the bathroom are OK. The leak was caused by a common problem with pre-2020 models with these plastic fridge side vents which let the rian in in about 3 possible ways. There may have been some other leaking--a bit of bad caulking around the door, and a bathroom window gasket that came out and I was bit lazy/unconfident about replacing it. I don't have a place to take her for maintenance so I am realizing I really have to do this stuff myself.
Kim
Charlotte, VT
Old 09-17-2024, 07:26 AM   #4
SuperTrouper's Avatar
2008 27' International FB
Petaluma , California
Hi Farafield, half of the issue is the reflectix under the floor (at least was for me). Check this thread out which may give you some ideas. https://www.airforums.com/forums/f39...ml#post1262866
Looking for adventure in whatever comes our way.
- Brad
SuperTrouper is offline   Reply With Quote
Old 09-17-2024, 12:40 PM   #5
2019 22' Sport
I wondered about that. The plastic vents seem to work fine on straight-sided conventional trailers, but not on curved Airstream walls.
I'm going to be working on the roof of mine again in the next week - time for a wash and complete wax before winter. I need to carefully examine the sealant when I'm up there.
Old 09-17-2024, 12:55 PM   #6
farafield's Avatar
2018 16' Sport
Charlotte , Vermont
Thank you for that. I've read A LOT of threads on this subject but not that one, squirreled away in the Safari section! Yes, I agree about the reflectix 100%. It just makes no sense to me that if the floor gets wet, and it's going to, the cards are stacked against it's drying out, especially when these kinds of leaks are not detected until things have gone too far.
Kim
Charlotte, VT
Old 09-17-2024, 12:56 PM   #7
farafield's Avatar
2018 16' Sport
Charlotte , Vermont
Yes, I am doing that too. Hope it all looks good!
Kim
Charlotte, VT
Leaks, leaks and more leaks vje1031 Leaks - Weatherstrips, Gaskets, Caulks & Sealants 4 09-28-2023 09:53 AM
Leaks, leaks, and more leaks da_lizard Leaks - Weatherstrips, Gaskets, Caulks & Sealants 15 04-11-2016 11:36 AM
Leaks, Leaks and more leaks Jim in Pima Leaks - Weatherstrips, Gaskets, Caulks & Sealants 5 12-12-2007 11:23 AM
Leaks, leaks, leaks jeffnjen30 Leaks - Weatherstrips, Gaskets, Caulks & Sealants 8 08-27-2007 11:03 PM
leaks leaks leaks Globie64 Leaks - Weatherstrips, Gaskets, Caulks & Sealants 10 12-31-2005 05:49 PM
