07-24-2017, 10:01 AM
2016 22' Sport
Leesburg
Dometic warning signal 22FB Bambi
The accoustic signal is going off for 20 seconds every 2 minutes. Nothing else is flashing. On shore power electric, l.p. is fine, it is level. The door is shut. Any ideas?
07-24-2017, 10:32 AM
2016 22' Sport
Leesburg
Light is off inside when door is shut (used phone on video).
07-24-2017, 01:26 PM
2018 30' International
Nashua
, New Hampshire
Could be the internal batteries of the control/display unit need to be replaced.
07-24-2017, 02:00 PM
2016 22' Sport
Leesburg
I can't figure out how to open control panel.
07-24-2017, 02:06 PM
Nashua
, New Hampshire
Turn the refrigerator off. Open the door and look under the bottom edge of the control panel . There should be a square button there. Depress the button and pull the display panel toward you at the same time. It should slide right out. Replace the batteries with brand new ones. It takes 8 AA batteries.
07-24-2017, 02:57 PM
2016 22' Sport
Leesburg
There are no batteries in it. RV shop called Dometic. If it is door sensor it will take a month for part. If it is the control board it is $500. OMG. This isn't even 2 yrs old yet!!!
07-24-2017, 04:50 PM
The Tin Man
2017 27' International
SoCal
Then it's under warranty, right?
2017 Serenity 27FB
Registry Name
"Rivets for the Tin Man"
WBCC #4913
07-24-2017, 04:54 PM
2016 22' Sport
Leesburg
No. I bought it from original owner, although he had never had a chance to use it. Appliance warranty does not transfer with the warranty. It has been used less than 6 months. It is a 2016 model.
07-24-2017, 05:17 PM
2019 27' Flying Cloud
Kansas City
, Missouri
Are you talking about the refrigerator making a beeping sound about once every minute or so?
There is a door ajar sensor that *thinks* the door is not closed all the way, even though it is.
Google dometic refrigerator door beeping to find out more.
Solution for us was to shove a very small wad of (of course) duct tape into the hole the the door latch presses into. Thus allowing the door latch to press the tape to press the sensor, so that it "knows" the door is shut.
Piggy Bank
07-24-2017, 05:46 PM
2016 22' Sport
Leesburg
I will try that.
07-24-2017, 06:12 PM
2016 22' Sport
Leesburg
No luck yet. Did you do was at top or bottom of slot opening?
07-24-2017, 06:18 PM
2016 22' Sport
Leesburg
I found where someone said to take off the plastic cover and dry out the wires. How to get cover off without breaking it?
07-24-2017, 06:52 PM
2016 22' Sport
Leesburg
I wadded up duct tape but that doesn't stop it either.
07-25-2017, 11:16 AM
2016 22' Sport
Swedesboro
, New Jersey
Dometic Beep
Been there: For me the Dometic needed to be reprogramed..... turn off the fridge.....turn off the battery power switch... wait 5 minutes... restart both battery power and fridge... Good luck.... worked for me !
07-25-2017, 11:24 AM
2015 22' FB Sport
Selinsgrove
, Pennsylvania
I found where someone said to take off the plastic cover and dry out the wires. How to get cover off without breaking it?[WE experienced the same problem with our 2015 22' Bambi.
I removed the plastic cover (snaps off) from the door latch (Inside right wall of frig), removed the circuit board (two screws), blew out the circuit with Radio Shack contact cleaner, allowed the frig to defrosted for several hours and restarted while on 110 volt house power. Several weeks now with no issue.
Good Luck
07-25-2017, 12:25 PM
belen
, New Mexico
Light
U just answered that age old question about the fridge light !
07-25-2017, 12:29 PM
2016 22' Sport
Leesburg
I tried to get that cover off to no avail. Do you pull it to the front or to the left toward the interior of the fridge?
07-26-2017, 05:57 AM
2015 22' FB Sport
Selinsgrove
, Pennsylvania
You pull up and forward from the back towards the front of the frig while lifting the back upper corner up and the back lower corner down and it will pop off.
When replacing make sure to align the white tab with the slot in the plastic cover.
07-26-2017, 07:27 AM
2016 22' Sport
Leesburg
Ok got it off. I had defrosted it for a full day then started it again. Same issue. Now that I have the sensor apart, did you try that diedetic gel on it? I have some for my 7plug for TV.
07-26-2017, 09:26 AM
2016 22' Sport
Leesburg
Ok, got it off, took it apart, dried it, used electrical protectant & lube. Nope. Still beeping. Is it okay to just leave the sensor off? I just don't have a light.
I contacted the Mothership through website 2 days ago. No answer.
