Old 07-11-2018, 08:33 PM   #1
waninae39's Avatar
2022 25' Flying Cloud
NCR , Ontario
does the as 22FB have an inverter (12vDC -> 120 ACC)
there is no mention of the inverter in the manual
i don't see it in an schematic.
there is no mention of it on the electrical panel.
does the 22FB have an dc -> Ac inverter
waninae39 is online now   Reply With Quote
Old 07-11-2018, 11:06 PM   #2
2011 22' Sport
Portland , Oregon
I am not aware of any Sport having an inverter unless you have a dealer install it.
SilverHouseDreams is offline   Reply With Quote
Old 07-12-2018, 07:20 AM   #3
waninae39's Avatar
NCR , Ontario
thank you
i am installing a Victron Energy Multiplus 12/3000/120-50 Inverter/Charger 120V. it will replace the existing power converter and also do the inverter job
it has two Ac outputs.
  1. The AC1 auto output( loss of ac turns on the inverter) will run all ac circuits-except AC
  2. The AC2 isolated output(loss of ac turns give no power to the circuit) will connect to the AC
it work with the other victron parts i have
i am leaving room under the bed for a 2nd BBy battery and have been thinking of getting 3x 90w slim solar panel for the roof
12v
Inverter - 2015 22FB Sport Frank&Mike 2005 and newer - Bambi all models 19 09-07-2021 07:47 AM
Sport 22FB 12vdc power outlet install Msherw 2005 and newer - Bambi all models 2 10-25-2017 06:49 AM
No 120 VAC w/ generator or inverter 73shark Sprinter and B-van Forum 7 07-17-2015 03:37 PM
No 120 but have 12v Dan S Electrical - Systems, Generators, Batteries & Solar 4 10-10-2013 08:30 PM
Why does front A/C have drain hose but back A/C does not? AccessMaster Airstream Motorhome Forums 9 06-22-2003 07:15 PM
