Free 7 Day Trial RV GPS App RV Trip Planner RV LIFE Campground Reviews RV Maintenance Free 7 Day Trial ×
Old 11-26-2021, 06:41 AM   #1
Silvr_Bullet's Avatar
2017 16' Sport
Woodstock , New York
Connecting two separate Zamp Solar Suitcases
How would I go about physically connecting two separate Legacy Zamp Solar Suitcases routing them through the Zamp quick connect on the trailer tongue.
I now have a 120 watt suitcase looking to maybe purchase one equal or greater wattage used or new suitcase.
Ken
Hensley Hitch
2/100 Amp Hour Battleborn Lithium and upgrade
Silvr_Bullet is online now   Reply With Quote
Old 11-26-2021, 06:50 AM   #2
GLCMRANGER - Sue
2016 25' International
Littlestown , Pennsylvania
you can plug 1 suitcase into the ZAMP plug on your battery box and the other one: buy a pigtail that has the battery clamps on one end and the quick disconnect (that matches your ZAMP cord) on the other end.... hook this panel up to your battery.
glcmranger is offline   Reply With Quote
Old 11-26-2021, 07:33 AM   #3
2018 27' Globetrotter
Mooresville , North Carolina
Call AM Solar explain what you have and they should be able to get you the part you need.
I bought 2 Zamp Obsidian 100W panels from them. 1 has the controller and 1 doesnít. There is a pigtail where I just tie the non-controller into the 1 that has the controller. The 1 with the controller then plugs into your Zamp input to the batteries on your Airstream. Gives me 200W of portable solar in addition to my 250W on the roof.
This works for me as I can also use the non-controller panel to charge my Yeti Goal zero portable lithium battery that already has its own solar controller built in.
2018 GMC Sierra 2500HD Duramax
Equal-I-zer Weight Distribution attached to the Gen-Y Torsion Flex Weight Distribution Hitch
"Roadrunner"
GOUSC is offline   Reply With Quote
Old 11-26-2021, 07:48 AM   #4
2019 23' Flying Cloud
Allen , Texas
Do a search on amazon for "SAE Connector Splitter". Should be about $9. This will allow you to combine the two suitcases in parallel and plug into the Zamp SAE connector. This assumes each of your suitcases has it's own controller as that connector on the tongue goes directly to the battery (unlike the connectors on the roof which would go through a controller)
Meallen is offline   Reply With Quote
Old 11-26-2021, 07:54 AM   #5
Antsville , FUBAR
Welcome Aboard..👍
I used a two into one SAE harness.
POI the ZAMP polarity connector is required because of how Zamp wires the system. I charge thru the 7pin umbilical directly to the batt's.
ID:	408452   Click image for larger version
ID:	408454   Click image for larger version
Old 11-26-2021, 09:18 AM   #6
2017 16' Sport
Thank you everyone!
Ken
Hensley Hitch
Old 11-26-2021, 09:50 AM   #7
FloydCoVa's Avatar
2015 23' Flying Cloud
Copper Hill , Virginia
Hey Robert, I have a question for you. When you charge thru the 7 pin how does that effect the victron bmv 712? Will the monitor still read correctly? Thanks Scott
FloydCoVa is offline   Reply With Quote
Old 11-26-2021, 10:13 AM   #8
richard5933's Avatar
1994 25' Excella
Waukesha , Wisconsin
Generally speaking if all your connections to the negative side of the battery bank go through the shunt you can have as many sources feeding the positive side as you want. The Victron reads the current through the shunt, and if all power is flowing through it you should be good to go.
Richard
11018
1974 GMC 4108a - Custom Coach Land Cruiser
richard5933 is offline   Reply With Quote
Old 11-26-2021, 10:45 AM   #9
Antsville , FUBAR
It werks fine...the 'shunt' is on the negative buss bar, as are both neg cables from the batteries.
Todays reading. @ 31*f
Old 11-26-2021, 12:52 PM   #10
jamieb1086's Avatar
2016 25' Flying Cloud
Selbyville , Delaware
Just call Zamp, tell them what you have and what you
want to do.
Jamie
2016 25' RBT Flying Cloud "Bullseye"
2016 Chevy 2500 High Country Duramax Diesel "Red Bull"
WBCCI #9026 Delmarva Unit
jamieb1086 is offline   Reply With Quote
Old 11-26-2021, 01:12 PM   #11
2021 16' Caravel
Fullerton , California
Ken
You simply need a ďYĒ parallel combiner cable adapter (female to 2 male). You can get from Zamp, but probably cheaper from AMSolar.com ($25). Female connects to charge controller, each solar panel connects to the male ends. I leave the adapter with the panel with the charge controller, and simply plug/unplug in the non-controlled panel. I have two Obsidian 100w panels which have zippered pouches to hold the charger and cables, which is very convenient.
If you donít have one (or two) yet, I would also suggest getting an 15í extension cable while youíre at it, cheaper at AMSolar ($33). Zampís 15í extension is twice as much, coming with a fuse which I donít need with my panel setup.
Hope this helps
NeahBay is offline   Reply With Quote
Old 11-26-2021, 02:30 PM   #12
2018 19' Flying Cloud
Eugene , Oregon
Using Y connector with 2 solar suitcases
So is it better to keep both controllers working when plugged into a Y connector into the batteries? I have the option of disconnecting one of the suitcase controllers and then having both suitcase panels funnel into just one controller , then into the battery.
tjwoods1 is offline   Reply With Quote
Old 11-26-2021, 03:47 PM   #13
Antsville , FUBAR
I left mine as delivered...that way I can easily deploy just one 180w panel if I want.
Old 11-26-2021, 04:42 PM   #14
dznf0g's Avatar
Oswego , Illinois
I am not a fan of multiple controllers in one system. So, my suitcase was modified with connectors at its controller. I bypass it. My AS was modified with a pigtail to the onboard victron controller. The suitcase controller is hooked up only when I use the suitcase for a stand alone battery...like a boat, etc.
-Rich-
Old 11-27-2021, 08:02 AM   #15
Ridgecrest , CA
1+1 <> 2 when it comes to solar panels
If the Zamp suitcases are different models definitely contact Zamp for a recommendation. Connecting different PV panels in series or parallel can potentially impact the overall efficiency dramatically, in some cases almost negating the fact that you have two. Zamp can provide a wiring recommendation based on the characteristics of the models you have.
cloudlesssky is offline   Reply With Quote
Old 11-27-2021, 08:58 AM   #16
Antsville , FUBAR
Before getting my second 180, I pared the 140 I already had, worked fine.
Old 12-01-2021, 10:30 AM   #17
Dick tracy's Avatar
camas , Washington
Ken
I'm guessing your first panel has a controller, just buy the second without and plug the one without into the one with the controller and plug the one with the controller into the trailer plug.
2017 FC 23 FB - 2002 Range Rover
2021 International 27 FBT - 2019 F150 Harley Davidson
Dick tracy is offline   Reply With Quote
Old 12-01-2021, 11:27 AM   #18
2017 16' Sport
What if both suitcases have controllers? I am looking at a 140 watt and I now have a 120 watt. To further complicate I have a Zamp 90 watt on the roof ( 3 plug-in adapter on the roof and Zamp plug by the propane bottles ) I believe that there isnít a problem with the roof mount , because the portable will take precedence if it receives more sun. Thanks.
Hensley Hitch
Old 12-02-2021, 12:23 AM   #19
Dick tracy's Avatar
camas , Washington
You are fine if they both have them, some may say they will "fight" each other, but i dont believe that is the case.
If you are buying a new panel, it doesn't need a controller.
Old 12-02-2021, 12:30 AM   #20
Dick tracy's Avatar
camas , Washington
I have a single ZAMP 260w portable, love it. Powers all the normal chargers, TV, stereo, movies, lights, furnace fans, no issues. Eight nights boondocking in N Idaho last September
using instlled Zamp system with non Zamp products. mdlemieux Our Community 32 07-21-2021 10:46 AM
Airstream SUITCASES? Toddnazus Airstream Lifestyle 13 08-11-2020 06:15 PM
Can Two Solar Suitcases be used at same time? tjwoods1 Generators & Solar Power 7 02-07-2020 01:46 PM
Using 2 Solar Suitcases tjwoods1 Generators & Solar Power 6 01-09-2019 10:56 PM
Connecting Renogy Suitcase to Zamp connection on 2017 Flying Cloud D44 Electrical - Systems, Generators, Batteries & Solar 2 01-18-2017 12:43 PM
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
