Old 09-05-2018, 02:21 PM   #1
Durham , OR
Another Solar question....
I have a 120W portable solar panel which I haven't used yet but will soon. Is having a controller mandatory? For example, can we hook up the panel and then just periodically check the battery level indicator in the AS and unplug the panel when the battery level is showing at or near capacity?
PDXMike is offline   Reply With Quote
Old 09-05-2018, 02:31 PM   #2
Overkill Specialist
GMFL's Avatar
2014 23' International
Dadeville , Alabama
No, controller regulates voltage and amp out out to protect the battery. Most panels can run as high as 20 volts which would not be good for the battery.
Old 09-05-2018, 03:22 PM   #3
wulfraat's Avatar
2017 30' International
Broomfield , Colorado
You want a controller.
Without one the panels will put out 17-18v to the battery which is too high for lead acid batteries. Charging at 17-18v will damage your batteries.
wulfraat is offline   Reply With Quote
Old 09-05-2018, 06:11 PM   #4
Durham , OR
Thanks for the quick responses. Now follow up question: with a 120W panel, is there a specific spec controller I should get?
Old 09-05-2018, 06:22 PM   #5
Overkill Specialist
GMFL's Avatar
Dadeville , Alabama
VictronConnect 100/30 is what I have
Yet another Solar.....advice sought dznf0g Generators & Solar Power 14 11-17-2015 07:57 AM
Just another hello from another newbie nanaenes1 Member Introductions 7 12-16-2014 12:45 PM
Need another 65 Watt UNI-SOLAR kooshka Generators & Solar Power 5 09-13-2010 09:37 AM
Another trip, another repair swanky Classic Motorhomes 6 07-07-2009 03:24 PM
