Old 05-15-2023, 07:06 PM   #1
hbf
2022 19' Bambi
2018 16' Sport
Gilroy , California
Access to low point drain valves on 2022 Bambi 19cb
Anyone know how to access the values for the the two low point drains at the rear curbside under the hot water heater? I think I can barely see them from the rear storage compartment but I can not reach them from that location. They are also not accessible from the hot water heater area. Looking under the mattress I could find no access port. I must be missing something obvious. Thanks for any assistance.
hbf is offline   Reply With Quote
Old 05-15-2023, 07:34 PM   #2
The Aluminum Tent 3
pcskier's Avatar
2014 23' Flying Cloud
Park City , Utah
You should be able to reach them through the exterior storage. That’s what I do.
pcskier is offline   Reply With Quote
Old 05-16-2023, 04:37 AM   #3
2022 19' Bambi
Northeastern , Pennsylvania
On mine there’s an access panel under the mattress that goes to the area behind the water heater. I believe that’s where they are.
DarthBrader is offline   Reply With Quote
Old 05-16-2023, 09:53 AM   #4
hbf
2022 19' Bambi
2018 16' Sport
Gilroy , California
The water lines to the low point drains go across the back of my exterior storage, but then turn 90° into the area under the bed and behind the hot water heater. I can see the valves but I would need to either crawl into the storage space or have four foot arms to reach them. Is your Bambi configured with the valves in the storage area?
Old 05-16-2023, 09:56 AM   #5
hbf
2022 19' Bambi
2018 16' Sport
Gilroy , California
Pulled out the mattress there's no access panel. Airstream must have forgotten to put it in. I like the idea of accessing the valves from the outside storage so I'll see if I can relocate them where they can be reached.
Old 05-16-2023, 05:09 PM   #6
The Aluminum Tent 3
pcskier's Avatar
Park City , Utah
Mine is a 23 CB which is laid out exactly the same in the back. But yes my valves are in the storage compartment near the back wall on the right. I can reach in to turn them.
Old 05-16-2023, 07:23 PM   #7
2019 19' Flying Cloud
Apex , North Carolina
We have a 2018 19cb. We quickly became frustrated with the black low point drain valves due to both location and poor function.
For several years now we have left the original valves open and installed these push on cpvc valves under the trailer on the 4 low point drain pipes.
Easy to reach. No more lifting mattress or crawling into storage.
Amazon
HOMEWERKS WORLDWIDE 126-8-12-12B 1/2" Push Fit CPVC Valve
Bill n Rose is offline   Reply With Quote
Old 05-16-2023, 07:31 PM   #8
A better source for the valves:
https://hardwareandmoreee.com/produc...BoCPu4QAvD_BwE
Old 05-17-2023, 08:25 AM   #9
hbf
2022 19' Bambi
2018 16' Sport
Gilroy , California
Oops, turns out I do have an access panel under the mattress. I use a moisture prevention underliner beneath the mattress that is taped down to prevent sliding. I had only removed a section of the pad nearest the rear when I first checked. So I do have access to the valves if I lift the mattress and remove the underliner. Can't understand why Airstream doesn't make these valves easier to access in this model.
Thanks pcskier and DarthBrader for pointing me in the right direction. And thanks Bill n Rose, those valves look like they can easily be installed where the lines cross the back of the outside compartment.
Old 05-25-2023, 04:51 PM   #10
Boxite's Avatar
2008 22' Safari
Remote access would be a sensible thing for AS to provide. Simple push/pull rods connected to wherever the valves must be located by engineering/design should be a simple matter if electric solenoids frighten them….they work pretty reliably in washing machines and dishwashers.
? about 2 low point drain valves on '09 International 25FB... Opn Rd 2006 - 2010 International 3 02-13-2019 05:58 PM
Low Point Water Line Drain Valves Froze! Dwellstream Fresh Water Systems 25 11-21-2014 11:10 AM
How many low point drain valves on '08 23FB? bonginator Plumbing - Systems & Fixtures 6 10-01-2012 07:42 AM
Low point drain valves Gringo Fresh Water Systems 4 11-03-2011 09:13 AM
Replacing the low point water drain valves thecatsandi Fresh Water Systems 4 02-17-2009 11:32 AM
