Originally Posted by hbf
The water lines to the low point drains go across the back of my exterior storage, but then turn 90° into the area under the bed and behind the hot water heater. I can see the valves but I would need to either crawl into the storage space or have four foot arms to reach them. Is your Bambi configured with the valves in the storage area?
Oops, turns out I do have an access panel under the mattress. I use a moisture prevention underliner beneath the mattress that is taped down to prevent sliding. I had only removed a section of the pad nearest the rear when I first checked. So I do have access to the valves if I lift the mattress and remove the underliner. Can't understand why Airstream doesn't make these valves easier to access in this model.
Thanks pcskier and DarthBrader for pointing me in the right direction. And thanks Bill n Rose, those valves look like they can easily be installed where the lines cross the back of the outside compartment.
