Old 10-17-2021, 09:40 PM   #1
2021 22' Bambi
Eugene , Oregon
22 FB 2021 - Low Point Valve
I have a 22 FB 2021 - I’m looking for the fresh water low point drain to winterize. I’ve looked at the specs and can’t find it near where it appears on the diagram. Any help is appreciated. Mark
Mark Koss is offline   Reply With Quote
Old 10-17-2021, 10:14 PM   #2
2019 22' Sport
High River , Alberta
If it’s like my 2019, in two places. Under the closet floor near the water pump, and under the bed right beside the water heater.
AlbertF is offline   Reply With Quote
Old 10-17-2021, 10:54 PM   #3
2021 22' Bambi
Eugene , Oregon
You were right. There was a hot and cold drain under the floor of the closet/pantry that drain to the general area of the grey and black water tank valves. I appreciate your help. I didn’t immediately find the one under the bed by the water heater but will look further tomorrow.
I’ll be adding a fabric “pull” tab to get the floor up easier next time. It was a tight fit.
Old 05-15-2023, 07:42 PM   #4
Boxite's Avatar
2008 22' Safari
Clean your water pump inlet screen too, next time your in there.
low point drain leaking at valve m.hony Plumbing - Systems & Fixtures 8 09-07-2016 01:19 PM
Low point valve leak john4170 Fresh Water Systems 2 08-29-2014 01:17 PM
Winterizing snafu - low point drain valve on FW tank stripped and won't opem bonginator Fresh Water Systems 12 09-29-2013 02:22 PM
Failure of low point drain valve? desidou Fresh Water Systems 8 12-24-2006 08:29 AM
