Old 01-07-2023, 02:23 PM   #1
Sheridan , Wyoming
12 Volt Power Outlet
I have a 2017, 16' Sport and I'm considering installing a 12 volt power outlet
( cigarette type outlet) just below or near the battery disconnect under the front bench seat. See attached photos. Does anyone have a recommendation on how to wire it? What is inside the black box?
I was considering + wiring to the battery disconnect terminal but not sure what to use as the ground.
ID:	426909   Click image for larger version
Airabel-2 is offline   Reply With Quote
Old 01-07-2023, 07:45 PM   #2
Al and Missy's Avatar
2002 30' Classic S/O
Fleming Island , Florida
I am just guessing, but that box looks like the Bargmann junction box for the 7-way cable to the tow vehicle. There is a ground inside it, but a better choice would be to locate the bussbar where the negative cable(s) from the battery(ies) connect.
https://www.bargman.com/product/7875...y-junction-box
Old 01-08-2023, 08:04 PM   #3
Sheridan , Wyoming
I was going to try the battery disconnect posts ( off position ) for the red + wire and the grounding bus ( see photo ) for the ground.
Old 01-08-2023, 08:43 PM   #4
Is that where the negative battery cable(s) connect? If not, they are connected to chassis ground somewhere and this would work, but a direct connection to the negative side of the battery would be better.
12 volt
30 amp rv outlet to 50 amp rv outlet The Boot Electrical - Systems, Generators, Batteries & Solar 26 12-19-2021 04:38 PM
12 Volt Outlet in 2004 Bambi marchesi Electrical - Systems, Generators, Batteries & Solar 4 06-03-2009 01:54 PM
12 volt outlet not working M&M CAPECOD Electrical - Systems, Generators, Batteries & Solar 14 07-15-2005 10:25 AM
external 110 volt outlet door-curbside Kirby Stone General Repair Forum 0 01-21-2004 01:41 PM
Exterior 120 volt outlet cover thenewkid64 Electrical - Systems, Generators, Batteries & Solar 8 06-16-2002 08:54 AM
