04-11-2007, 09:55 PM
#121
Sandy Sanders
2005 30' Safari
Green Valley
Stress Cracks Repair
My unit is going in for repair next week at Oasis RV in Tucson. Now I have to decide on whether or not to replace the square cornered door or go with no door and try to utilize the storage space by accessing it from the inside. I looked at some Classics which had "lift-up beds" with gas struts. I was disappointed tho since they allowed good access to only about 60% of the total storage space and to reach the other 40% you would have to crawl into the 60% area (after you unloaded it) and reach back into the 40% area. This appears to be unwieldy for the way I would like to utilize this space.
Safari SS: Since you did your own strut installation were you able to gain more easy access than the factory designs by placing the hinges on the platform farther toward the front? What would be the limit as to how far forward you could go with the pivot point and still have the gas struts function properly? This may not have been a problem for you since I think you planned to use the 40% area for glass mat batteries which would seldom need to be accessed. In any event I would like to hear from you as to how your situation is working out for you and any suggestions you may have as to my quandary.
04-11-2007, 11:57 PM
#122
2005 30' Safari
Chandler
Oasis
Hi Sandy welcome to the forums... wish I would have known you were in Tucson.. we hosted a Four Corners Unit rally two weeks ago at Gilbert Ray in Tucson Regional Park.... check us out Four Corners Airstream Camping Unitwe can use another 30BH in the group.
I would greatly appreciate a full report from your repair experience at Oasis on this front door item. I need to get a write up on mine for warranty and don't really want Dillon to do the job.
Thank you for your input,
Brent
AZstreamin
"Twenty years from now you will be more disappointed by the things you didn't do than by the ones you did do. So throw off the bowlines, sail away from the safe harbor. Catch the trade winds in your sails. Explore. Dream. Discover."- Mark Twain
04-16-2007, 08:04 PM
#123
2005 30' Safari
Houston Texas
Gas Strut under bed...
Sandy,
I installed the gas struts as far back as possible, and mine go up higher than the stock Airstreams as they are longer. As far as access to under the bed, most of what you will want to get to is the front 70% (that is, ease to get to). I could get to the very front if I chose to, as you had mentioned I am installing the glass mat batteries up there so the last 16" across the front I dont nessessarily need to access. I think even if I was not installing batteries that with the ample space in the back storage doors that I could utilize this as my "dirty" or hitch storage as well. Its just the access to anything long or large was just awkward anyway behind the propane bottles and combined that with the worry of leakage, future structural flex it just made sence to smooth it out. No regrets here.
If I was set on installing an access door, I would prefer a rounded corner door like the rears only wider. This would be stronger and less likely to crack the corners, however that door would be on your nickle as AS will not pay for that.
Let us know how your repair comes out, and maybe post some pics!!
04-16-2007, 08:43 PM
#124
2015 25' FB Flying Cloud
Greensburg
, Pennsylvania
Stress crack repair
Airstream has approved a repair that will replace my original door with one that is 49 inches wide and will stretch from the riveted seam on each side of the front lower panel. This size door was available on several other models at both the front and rear. Although the door is square cornered I hope that the fact it will be riveted at the front braces will take care of the cracking. I'll try to post the results.
04-17-2007, 09:15 PM
#125
2005 30' Safari
Houston Texas
hey pinto man...
Was yours cracked on both sides? or just one? How many towing miles??
Just kurious!!
04-18-2007, 12:00 AM
#126
2005 30' Safari
Chandler
two crack heads walk in a bar......
Actually no...not two I have three cracks....around the frame...two on one side one on the other... maybe it's time for a trip to Mexico.. 400 miles of wash board should set her straight.....or maybe turn three into five..
Sandy Sanders....what did you decide on the front door appreciate an update..
pintoman....new door 49 inches..What are the measurements of the original door? (She’s in storage I see her next weekend)
There appears to be different opinions on how to repair this prob.
what does Jackson engineering say?
If they repair the door and replace it with a new door what is the new warranty on the said repair?
I love the idea of the bed struts..
Right now I barely use the storage under the bed….but for extended living there is a lot of space under the bed…..
AZstreamin
04-18-2007, 12:55 PM
#127
Sandy Sanders
2005 30' Safari
Green Valley
My unit is in Oasis' shop now and repairs should start shortly--I will try to keep everone informed and post pics if possible.
I had a good visit with Joe (owner of Oasis). He advises to retain the existing rectangular door but round the corners of the cut-out where the door will be installed. In addition he said he would likely shore up the ends of the new front panel with angle iron anchored to the steel frame. He is presently doing that to another unit in his shop which he said Jackson Center had botched. He pointed to the horizontal line of rivets at the bottom of the panel that are covered with a moulding and said that the moulding looks bent and that possibly some rivets had popped. He also said that he uses a stronger rivet than the factory. I asked him 'if the stress cracks happen again after my warranty expires in Nov. '07 will it be repaired again under warranty?' The answer was NO--once the warranty expires there will be no more repairs under warranty.
AZstreamin: I am not willing to give up the front access to that storage area so I will go with Joe's recommendation to replace the existing front access door.
04-18-2007, 01:39 PM
#128
1968 17' Caravel
2005 30' Safari
Somewhere
, roaming America
Big crowd coming
In the first week of June we expect to be in the Las Vegas area and having guests in the Bunkhouse. It will be the first time we've ever tried to sleep five people in the trailer: 2 on the front queen, 2 on the rear double, and 1 on the dinette. Four adults, one kid. I love having a trailer that can do that!
We've had five or six people over for dinner at once, so we know how to do that, but never for an overnight. Anyone else packed five or more in at once? Any tips? This should be interesting ...
04-18-2007, 02:04 PM
#129
Greensburg
, Pennsylvania
stress cracks
just kurious!!
I had one crack starting on the lower right side of door. This after approx. 2500 miles. The new door that they are using will go from rib to rib.
04-18-2007, 02:53 PM
#130
Tom, the Uber Disney Fan
2006 30' Safari
Orlando
We've only had one overnight guest-that was my mom and she slept on the sofa. She didn't want the it opened. She said she needed to sleep on her side for medical reasons and thought the sofa back would keep her on her side. I think she was just trying to be of as little trouble as she could be. It's easy to open though.
We've never even lowered the dinette into the bed position. I know how to, just never needed to. Total we can sleep is 8. I'm afraid that would be crowded though. I think the sofa would touch the dinette and make and offset bed for four!
Family of Disney Fanatics
WBCCI# 4821
https://streaminacrossamerica.com/
04-18-2007, 03:20 PM
#131
2006 30' Safari
Orlando
BTW, I bought a FM modulator to route the aftermarket DVD player into the stereo system and it calls for plugging it in-line with the antennae. When I pulled the head unit last night, I couldn't find the juncture between the antennae and the antennae lead. It appears that the antennae lead may connect to the antennae wire inside the wall of the Airstream. Has anyone installed an FM modulator to add XM radio or iPod, if so, how did you plug it in-line with the antennae lead? Where is the juncture?
WBCCI# 4821
04-18-2007, 11:37 PM
#132
2005 30' Safari
Chandler
the guest house......
All those miles and no house guests Rich?
Ok so maybe I'm brave, dumb, or crazy....
Last year end of September...
We loaded up the F250 and the Tin Cabin..
4 Adults and 1 four year old
now you're thinking yeah so what..??
To clarify....
that is 2 in-laws
a married couple
and child...
The destination...Monument Valley...just like in the movies Clark....
750 miles round trip and 3 nights later I can say we own the best airstream on the market...
I gave the master bedroom to... our guests...
I slept on the dinette...which if you are less than 6 foot it is decent for 1 adult..A foam egg carton helps the cause out a lot...
also the dinette is fun to put down and put several kids or a few adults for watching movies...kind of feels like camp....
wife and daughter slept in the bunks....
so all the in-law jokes aside for a moment...
we basically took two people who have not been camping since god knows when on a road trip that was a lot of fun...I'd even consider doing it again...(or maybe I'll let them sleep in the tincabin on the next visit............in my driveway....teeeheee)
bottom line...this less than 200 sq ft of living space offers great flexibility that is more like a home than a camping trailer.... .
AZstreamin
04-19-2007, 05:08 PM
#133
2015 27' Flying Cloud
Caledonia
, Michigan
The thick black antenna lead should plug directly at the back, possibly plugging directly into the head unit. The connector should be no more than three inches behind the head unit.
Here is an example: Pelican Technical Article: BMW Radio Head Unit Installation
04-20-2007, 08:44 AM
#134
2006 30' Safari
Orlando
Originally Posted by Amsterdamer
I'll take a close look at it this weekend. It looked like the antennae wire was attached internally at the back of the head unit. That was the first place I though of being the juncture but it didn't come out when I pulled firmly. I'll try again with a little more force and if it doesn't turn out to be the connection point, I'll take some photos and post. If all else fails I'll post a photo of the schematics from the manual. I really can't make heads or tails out of it myself. If it is a standard for the manufacturer, it is a Sony unit if that helps.
WBCCI# 4821
04-27-2007, 09:00 PM
#135
2005 30' Safari
Pfafftown
, North Carolina
Hi All,
We have a 2005 bunkhouse. I've read through most of the postings and see that the cracks in the bottom corners of the front storage compartment are common. We noticed 2 inch long diagonal cracks at each bottom corner after about 10,000 miles of use. A month before our 2 year warranty expired, I took the trailer up to JC for repair. They cut out the cracked area, inserted new sheets of aluminum into the voids, and riveted everything together. No further cracks have developed. My wife, who is a biomechanist and lectures on material properties, says that the reason why the cracks develop is because of the sharp corners which act to concentrate stresses. Airstream needs to redesign the front compartment (on 25FB, 27FB?) and include rounded corners to stop the cracks from forming. I have said as much to management and repairmen at the JC service center. There comeback was that they only repair the trailers; they don't design them. Repair pictures will follow in later posts.
Here's a problem not yet discussed. The metal straps under the trailer retaining the gray and water tanks are inadequate. When viewed from the side, our trailer use to look like a pregnant cat ready to give birth when the tanks were full. I fixed the problem by welding up rigid stainless steel c-channel straps to replace the originals. I was worried the the added flexing of the tanks when going from empty to full would eventually lead to leaks, especially aroung the outlet piping. The fix added about 5 lbs. Again, pictures will follow.
Bye for now,
Paul
04-28-2007, 01:31 PM
#136
2006 30' Safari
Orlando
While we have filled our gray tank while camping, I empty it daily and save up the last day's contents for flushing the hose after dumping the black tank. I usually keep about 5-10 gallons at most in our fresh tank for those last minute potty flushes before we pull out of the camp ground and for use when we stop on the road.
There has only been one occasion that I have actually towed the trailer with the freshwater tank full and that was last weekend when we went to a rally about 150 miles from home. I had actually put about 2/3 cup of bleach in the fresh water tank and filled it so I could disinfect it and all of the fresh water lines before using it at the camp ground. We used the water in the tank for the showers, etc. for the first morning and switched to city water for the rest of the trip. That left about half a tank in the fresh water tank.
Now you have me concerned that I shouldn't carry any of the tanks full when traveling. Anyone else notice this issue with their 30 footer?
WBCCI# 4821
04-30-2007, 06:57 PM
#137
2005 30' Safari
Houston Texas
Mm......
I have noticed the swelling of the tanks, but only a little. I think they will buldge and it probably would not hurt to support them a little better. Airstream uses the same design on most of the safaris/internationals, but I am not sure the size of the tanks.
I would utimately like to put the tanks up between the frame rails and between the crossmembers for better clearance and to get rid of the "box trailer/ma and Pa kettle look". It seems that every picture I take of my rig out on the road the one think I always see is that gangly 1.5" pipe that runs aft. I am thinkin that it would not take much road debris to take the whole valve out and coat the freeway with blackwater suprise. Anyone know how the classics are done. I know some of them actually have a access door in the underbelly wrap that allows access to the main line.
This is a must do for me in the near future. I think a underbelly removal aft would quickly determine the feasibility/size of tanks allowed.
Interested in others thoughts...
04-30-2007, 09:44 PM
#138
1968 17' Caravel
2005 30' Safari
Somewhere
, roaming America
I don't think the bulging of the tanks is a real problem, nor do I have any reason to believe the supports are inadequate. The tanks are flexible and will bulge with a full load.
We've been full-timing for 18 months and we carry full fresh water every time we tow (because we rarely are sure where we'll be next) ... haven't had a tank fall off yet.
04-30-2007, 11:49 PM
#139
2005 30' Safari
Chandler
THANK GOD......that would be the blog I don't want to read Rich!
IMHO I think our 30 BH tows better when full it seems to balance the load...
I've noticed a very slight sag in the center of the tank...It doesn't seem to be isolated to just our model....so I'm not alarmed....yet....
thump....thump...
AZstreamin
05-01-2007, 08:48 AM
#140
2006 30' Safari
Orlando
When I towed ours with the fresh tank full, I could tell a difference at first. Maybe the added weight was the issue, but it seemed a little gangly (?). After a few minutes I didn't notice any difference though. I guess it was a tendency for the trailer to feel like it wanted to continue on a horizontal track as I was going around the corners in my neighborhood. But once I was on the highway, I didn't notice any difference. I can see the weight on the axles giving additional stability, though. However, I can also see that the additional weight between the axles might cause a little additional resistance to turning when backing in and making sharp turns...at least that is my story for the problems I had getting into a tight space (tree on either side of the site entrance and a retaining wall opposite the site) at 10:00 PM!
WBCCI# 4821
