RV News RVBusiness 2021 Top 10 RVs of the Year, plus 56 additional debuts and must-see units → ×
Old 08-02-2013, 12:34 AM   #1
wichita , Kansas
Newbie
I left my fridge running for two days. When I came back to it the battery's were dead. I inadvertently left the pump on. Will the pump drain the batteries that fast? Second question. Can I plug my as into a drop cord from my house? I'm shyre I could find this information in the owners manual. I would rather hear it from someone who has been there.
tinner is offline   Reply With Quote
Old 08-02-2013, 07:32 AM   #2
Minno's Avatar
1972 31' Sovereign
Lexington , Minnesota
Hi Tinner,
Welcome to the forums!
No, the pump would not drain the batteries, unless it was running. Do you have any water leaks, or did you drain the fresh water system before you left the trailer? If the system were drained, and the pump left on, it'll run dry until it fails or runs the batteries down.
What mode did you leave the fridge in? If you have a 3 way fridge and you set it to 12 VDC (not propane), then yes, it will run the batteries down in 24 hours or less.
Other things to consider are the size of the batteries, their charge level, etc. All will impact how long they can last.
By a drop cord, do you mean an extension cord running from a 15 or 20 amp outlet in your house? If that's what you mean, then yes, you can do that. Just don't try to run the a/c. But, it'll run the converter/charger, fridge, lights, radio, etc.
Chris
