Old 09-02-2016, 04:29 PM   #1
Bellaire , Texas
battery power
I moved my 2006 25ft. safari to my indoor storage today. what button do I need to push to light up cabin off of batteries. Batteries seem to have a charge since power jack worked. Sorry for such a lame question.
Bigeddie58 is offline   Reply With Quote
Old 09-02-2016, 04:35 PM   #2
Master of Universe
Gene's Avatar
2008 25' Safari FB SE
Grand Junction , Colorado
The power jack is connected directly to the batteries and if you disconnect the battery elsewhere with the battery disconnect switch, the jack will still work.
I am guessing you used the battery disconnect switch, but I never have and many others don't either. Turn it back on and let there be light.
If you plug the trailer into shore power, the lights should work regardless. But if you charge the batteries with shore power and the single stage charger Airstreams come with, you will eventually overcharge them and dry them out. There's a lot more to learn about batteries and I suggest you look for threads on them.
There are no lame questions, though there are some dumb answers.
Gene
Battery Good No DC Power with shore power off. F Ross Batteries, Univolts, Converters & Inverters 18 10-25-2018 10:06 AM
Shore power but no battery power RogerLG Lights - Interior & Exterior 6 09-28-2012 01:53 PM
shore power/battery power wiring NavyDavesCvl Electrical - Systems, Generators, Batteries & Solar 0 10-13-2010 06:32 PM
Battery Power/City Power Question on Early 60's Airstream 63cloud Batteries, Univolts, Converters & Inverters 0 09-04-2009 08:07 AM
Shore power and battery power problems jfremstad Electrical - Systems, Generators, Batteries & Solar 5 05-03-2007 08:23 AM
