I've read all the threads and can't find a definite answer! Please take a look.
I filled the tanks on our 2019 FC. When I reinstalled everything the hoses started leaking, as luck would have it. I guess it's a wear item...
Took one of the hoses off:
- Cavagna, 350psi
- Seems to be 10" long (about 11-12 including the connectors)
- Has a connector on the regular side that resembles 1/4" NPT... yet the orifice is smaller
So what do I have? Should I order NPT, or the "reverse flare" type? Very confused. All the images of NPT I see have a larger hole in the middle. Note that the threads do taper, suggesting it is in fact still NPT.
Mine looks just like the one on the left, from this Amazon item
https://www.amazon.com/dp/B08KRMQ7VS...3-94bc9dc02768
However on a Camco hose they show NPT like this, note much bigger inside diameter
And here is mine. Some kind of hybrid? Yet it was Airstream OEM equipment.
No direct replacement parts available, of course!
