Old 07-25-2019, 05:18 PM   #1
VetteGuy's Avatar
1966 17' Caravel
Greenville , South Carolina
What size..
Dear ladies and gents I'm having a hard time trying to find a adapter to fit this it looks like a half inch they don't have this at my local RV supply store.
This is for 1966 caravel. I bought a new gas regulator and two new bottles but I can't connect everything because I can't find a connector to connect the original Has Broken
Not sure what to use the people that vintage trailer supply have no clue either
ID:	347602   Click image for larger version
VetteGuy is offline   Reply With Quote
Old 07-26-2019, 03:20 AM   #2
Dingo Girl's Avatar
1967 17' Caravel
Cadillac , Michigan
Can you cut that fitting off & add a new one and flare the end?
Dingo Girl is offline   Reply With Quote
Old 07-27-2019, 02:06 AM   #3
VetteGuy's Avatar
1966 17' Caravel
My have too
Old 07-27-2019, 07:48 PM   #4
1965 28' Ambassador
Oviedo , Florida
I have a 65 Ambassador. Went through the same scenario. Had to cut off and move to modern connection.
Kwuser is offline   Reply With Quote
Old 07-27-2019, 09:15 PM   #5
VetteGuy's Avatar
1966 17' Caravel
Wow.. what size do you have for the line now. Do you have a picture..? What size fitting..
Old 07-27-2019, 09:22 PM   #6
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Looks like a standard flare fitting.
It most likely attached to a hose which connected to the regulator.
I would think either a hose made with a matching fitting.
Or a flare to NPT fitting which would connect to a hose with a matching NPT fitting.
Old 07-29-2019, 03:16 PM   #7
Dingo Girl's Avatar
1967 17' Caravel
Cadillac , Michigan
ID:	347965Click image for larger version
I redid my whole propane system last year. Its a 1967 Caravel
This is the new dual tank regulator and the hose that goes from it to the main gas line under the trailer.
The second picture is the hose and where it attaches to the copper main line.
Hope this helps.
Old 07-30-2019, 02:53 AM   #8
VetteGuy's Avatar
1966 17' Caravel
Yes it helps. Is it the Original copper pipe ? Do you know what size fittings.. I've gone to a few hose makers and they were not knowledgeable about to figure out how to make it.
I'm stuck in a rut.. I believe I'll start praying.
Something seems so simple.. I wish I had super powers ��
Old 07-30-2019, 03:10 AM   #9
Long Island , New York
Your copper tubing should be a standard size IMO. When you cut off that old fitting [edit -- with a tubing cutter -- see Wikipedia link below] to replace it, you will have a small amount of the tubing still attached to take into the supplier as a sample. Get a new flare fitting, and a flaring tool [as needed], plus the rest of the setup hose etc..
No need to pray . . . just yet . . .
Good luck,
Peter
PS -- The basics: https://en.wikipedia.org/wiki/Copper_tubing
OTRA15 is online now   Reply With Quote
Old 07-30-2019, 07:35 AM   #10
Dingo Girl's Avatar
1967 17' Caravel
Cadillac , Michigan
See the small piece that is between the hose fitting & the flare fitting on the copper?
That came from our local RV dealer.
The copper is new but the same size as the original. 5/8 OD
Old 07-30-2019, 07:35 AM   #11
Dingo Girl's Avatar
1967 17' Caravel
Cadillac , Michigan
Take the pictures to your rv dealer they will help.
Old 07-30-2019, 08:24 PM   #12
VetteGuy's Avatar
1966 17' Caravel
Lol..thanks
Old 07-30-2019, 08:27 PM   #13
VetteGuy's Avatar
1966 17' Caravel
Thanks for the info.. because I need all the info I can get I think this should do me. Trust me I have taken pictures and my whole RV up to my local RV Service Center and they were useless but I think I have enough ammo now start a fight thanks for your help
Old 07-31-2019, 02:56 AM   #14
Dingo Girl's Avatar
1967 17' Caravel
Cadillac , Michigan
Let us know if you get your part if not i can send you the tiny fitting.
Old 08-03-2019, 04:34 AM   #15
Dingo Girl's Avatar
1967 17' Caravel
Cadillac , Michigan
The rv store is a minute from my job. I'll go on Monday after work and pick it up then I'll get an address for you.
Happy to help.
Old 08-05-2019, 02:00 PM   #16
Dingo Girl's Avatar
1967 17' Caravel
Cadillac , Michigan
I went to Jensen RV. They were all out of that particular fitting.
He called it an Offset Union. One end has a 3/8 male flare the other a 1/2" male flare.
You should not have a problem ordering this or getting one at a local plumbing supplier.
I tried......
Class B-190 Vans - engine size joysjoy600 Sprinter and B-van Forum 19 08-27-2015 01:22 PM
Awning size; wheel lug nut size jaygoree 2011 - 2015 International 0 02-19-2015 04:18 PM
What size TT have the same size awnings LI Pets Awnings 11 07-19-2014 01:04 PM
Plug size and ball size for '66 Safari 22'? Jezibels Hitches, Couplers & Balls 3 08-13-2009 06:59 AM
Twin Size Size Over59 Upholstery, Blinds, Walls & Interior Finishes 5 08-20-2004 10:18 AM
