09-18-2020, 02:51 PM
Louisville
, Kentucky
What is this valve?
New to AS. Have 2017 27ft FC. we discovered a gas valve Just below the tongue of the trailer on road side. Anyone know why this is here and/or how to use it? I am adding a pic. Sure appreciate any help.
09-18-2020, 04:04 PM
2019 25' Flying Cloud
Park City
, Utah
External valve to run your camp stove or generator off of trailer propane.
09-18-2020, 04:10 PM
2014 25' Flying Cloud
Cuddebackville
, New York
Yup, what thezoltar said.
2019 Ford Expedition Platinum
09-18-2020, 04:50 PM
Retired.
, At Large
That's a Duesenphlopper valve. It's important to leave it in the position shown unless you're going to connect your Duesenphlopper.
09-18-2020, 09:21 PM
2007 22' International CCD
Corona
What is this valve?
Here’s another version. This one is a 3/8 inch Deusenphlopper valve I use to run a Champion dual fuel inverter generator.
Note that this is not a standard one, but it was installed courtesy of the Department of Overkill Engineering.
09-19-2020, 09:18 AM
Mike from Canmore
2018 27' Flying Cloud
Calgary
, Alberta
These are low-pressure outlets, so you'll have to remove regulators on any burners you want to use. I have a small propane grill, and a propane fire pit, and had to remove the regulators that came with them. But, they work great. I see other campers using separate propane bottles for their grills/pits, but with this outlet, you don't need to do that . . .
2019 27' Globetrotter
McKinney
It’s for a propane hose with quick connection to hook up an outside propane source saucy as a heater or grill.
09-19-2020, 09:28 AM
2017 28' International
Jim Falls
, Wisconsin
PS. Make sure you always replace the blue plug or you will get a stone lodged in it. I learned that the hard way
09-21-2020, 03:39 PM
:SPACE A" S/O 11 Air19745
2006 34' Classic S/O
Fort Worth
If you are going to use one of these valves get one that has a lockout and an on/off valve. It will not let you turn on the valve unless you have it plugged in securely. I have three in/on my trailer: one on the tongue for the generator, another near the steps under the awning for the fire pit or grill, and one inside for the catalytic heater. It sure make propane use handy.
guskmg
09-24-2020, 04:58 PM
1991 36' Land Yacht
West Paducah
, Kentucky
Hey! Hey! Hey! Don't we have a language monitor on this here massage board?
Keep your Duesenphlopper in your own Flappenhaggler.
Children could accidently access this Forumalgama.
09-28-2020, 01:25 PM
2019 27' Tommy Bahama
Foothill Ranch
