Old 06-08-2020, 01:50 PM   #1
1990 29' Excella
baltimore , Maryland
What is this?
groundhogy is offline   Reply With Quote
Old 06-08-2020, 01:52 PM   #2
1990 29' Excella
Ok, that worked. Lol. My first picture upload.
Anybody know the details on this hose?
Im getting symptoms of the oil clogged propane line. Weak range top.
Changed out the range top regulator already.
This hose looks like it might be a low spot where oil and stuff might accumulate.
Old 06-08-2020, 01:53 PM   #3
1990 29' Excella
1990 excella 29’
Old 06-08-2020, 01:54 PM   #4
1990 29' Excella
Outside regulator changed about 4 yrs ago
Old 06-27-2020, 03:39 PM   #5
Ultraclassic's Avatar
2000 30' Excella
GTA , Ontario
Ok I will bite
Your having Flow problems, and you have replaced the Low pressure regulator at the tanks already? And now you suspect the hose under the tank bracket connection from copper to the reg is restricted or plugged ?
I guess it's possible, can you flow test it?
Remove it and blow it out?
Not a licensed gas guy so can't help you.
But you could make a water column gauge and test flow in the system up stream and then work back from the tanks.
#4286 Stella the 2000 30ft Excella/Classic - Tow Vehicle - 2012 Mercedes Benz GL350d - CanAmRv.ca hitch Reinforcement EZ-Lift WD with 2 Anti Sway Bars. previous tow vehicle 2005 Ford F150 Lariat 367,000Kms 5.4L
Ultraclassic is offline   Reply With Quote
Old 06-27-2020, 03:43 PM   #6
2000 30' Excella
GTA , Ontario
Originally Posted by Ultraclassic View Post
Ok I will bite
https://images.app.goo.gl/nQ8xH1HfF5JCutLb9
RV article on manometer (water column) pressure tester, how to make a home built tester.
Old 06-27-2020, 03:46 PM   #7
2000 30' Excella
GTA , Ontario
Also this post on the rubber hoses swelling closed, hope this helps
https://www.airforums.com/forums/sho...d.php?t=208745
Old 06-27-2020, 04:37 PM   #8
2007 22' International CCD
10 year old rubber in the propane system? Time to replace. Pigtails and hose from regulator get old and cracked. My ‘07 just got a new full set this year as a precaution.
rmkrum is online now   Reply With Quote
Old 06-27-2020, 11:18 PM   #9
1990 29' Excella
OP:
I was kind of asking “what is this” because I want a new one.
Anybody know the specifics of this propane hose?
BTW, i did disconnect the low end and a few tablespoons of oil fell out. Its not pipe thread on that end. Its the other one... flare? Rounded face iirc.
Pulled it apart a couple weeks ago.
Old 06-27-2020, 11:25 PM   #10
1990 29' Excella
Yes Ultraclassic, I am chasing a propane loss of pressure without owning a meter. Although i have discovered one plumbed in behind the refrigerator.
The tank regulator is only like 4 years old. So after i drained the hose and kinda blew out the lines (canned air. Lol) and that didnt work, I started eye-balling the tank regulator.
So I whacked it.
I opened the cap where the spring adjuster is and jazzed that up and smacked it around.
Pressure came back. Lol
Old 06-27-2020, 11:48 PM   #11
What is this?
“Percussive tuning” as we used to refer to this practice in the Navy technical rates.
A properly delivered kick using a heavy steel-toed boot to deliver the right impact to just the right spot on a recalcitrant computer could do wonders when delivered by a smart tech. I was the only one that could reliably pull this off. (I also knew EXACTLY where the loose cheap connector on the core memory was lurking)
True story, got a brand shiny new computer system on board the ship that even came with all the tools, spare parts, and test equipment. I opened the tool box on the first day and found 7 different kinds of fancy hammers of all kinds, from a soft rubber one to a two-pound sledgehammer. Used every darn one of them to maintain the mechanical and electrical bits of the system.
Old 06-28-2020, 11:20 AM   #12
1990 29' Excella
Yes. Lol. I got a little percussive.
Things are breaking too fast for me to fix them.
