07-20-2020, 07:37 AM
Tifmartin109
1970 31' Sovereign
Dalton
, PA
Water Tanks
Novice here... the fresh water tank light is yellow on our 2010 flying cloud. We’ve only stayed at full hook ups sites. Not sure why the fresh water tank light is yellow???
07-20-2020, 07:47 AM
2009 25' FB International
2018 27' Globetrotter
Hanover
, Pennsylvania
First of all, welcome to the forum and greetings from PA!
What does "yellow" mean? Caution? Almost empty? It would help to diagnose the issue if we clearly understand the issue.
07-20-2020, 07:54 AM
CLOUDSPLITTER "Tahawus"
Zanadude Nebula
, Milky Way
Welcome Aboard 👍
The most likely cause, the FW tank is not completely full.
"Hooked-up" does not fill the tank, the FW tank is filled thru the FW tank fill, usually behind a small door on the curb side.
Do you have a manual for the AS? They are available on-line.
“It’s not the system thats the problem, think Circus, it’s not the car, it’s that the car is full of Clowns.”
John Turley
Tahawus
07-20-2020, 08:24 AM
Long Island
, New York
The check valve in your water pump may be bad, thus permitting your city water to flow back [through the pump] into the water tank IMO.
https://www.google.com/search?q=pump...=airforums.com
Follow suggestions in those threads to clear debris from pump, and always use an inline RV water filter in the hose -- both when hooked up to city water, and when filling the water tank.
Welcome to the forum.
"Let the Music Lift You Up!"
Peter
07-22-2020, 06:33 AM
Tifmartin109
1970 31' Sovereign
Dalton
, PA
Thanks all for your insight. I had the gray water tank valve open when hooked up at the camp site. I closed the valve and it turned green, opened it and it turned back to yellow, closed it again and back to green. I guess it just doesn't like being open.
07-22-2020, 09:10 AM
Long Island
, New York
Your first post referred to the fresh water tank light. Wazzup?
Peter
