Old 02-27-2021, 02:19 PM   #1
Nashvilleville , Tennessee
Exclamation Water leaking from mystery drain. Help!
Hey all,
I have a very fast water leak from a drain pipe that I do know about. I say a leak because the water consistently leaks from this pipe very fast. If this drain is operating correctly then I am wasting an incredible amount of water and need to figure out why it's happening. This leak happens when connected to city water. When I am just using the pump it still leaks but much slower drips.
I am pretty sure this is now the low point valve. When I do go and turn on the low point valve water starts rushing out a different drain pipe than the one I am seeing a leak from. There are 2 drain pipes next to each other by the wheel well. I attached a photo of the assembly where I the leaking drain valve is attached to. It is in line right after the city water regulator. Its like some sort of check valve filter something I do not know really. Its a small part I circled in yellow.
Anyone know what this part is and why it is leaking or draining water so quickly?
bhel is offline   Reply With Quote
Old 02-27-2021, 02:28 PM   #2
It is *not* the low point drain. I will also add it is not the fresh water tank drain. As far as I can tell the drain pipe that leaks is attached directly to that part I circled.
Old 02-27-2021, 02:52 PM   #3
1970 23' Safari
Marion , New York
It looks like the high pressure relief valve. If to much pressure builds in the plumbing system it's designed to open, relieve the pressure then close again. Yours has probably become defective and needs to be replaced.
DremStremer is offline   Reply With Quote
Old 02-27-2021, 03:10 PM   #4
GCinSC2's Avatar
2007 30' Classic S/O
Somewhere , South Carolina
Clueless but I do have a question. On the label the red printing what does it say? And is that pipe cold or hot?
And if you identify the model and year that can help too.
S/OS #001
2005 Dodge Ram 2500 5.9L 6 Speed
16" Michelins, Hi Spec Wheels, Max Brake, Dexter 4 Piston Disc Brakes, Carslile Actuator, Equal-I-Zer, Dill TPMS. Campfire cook.
GCinSC2 is online now   Reply With Quote
Old 02-27-2021, 03:31 PM   #5
This would make a lot of sense. When I first got this and hooked up to city water it wasn't leaking so crazy. I also had a 50psi regulator on the hose. I connected to a different water tap and did not have the regulator so the water was flowing in at whatever the well pump was pushing out to the tap. Maybe that prolonged exposure to the pressure increase broke something in there... being its a 40 year old part.
Old 02-27-2021, 03:33 PM   #6
All I can make out is "Webster No. 111 Set 125lbs". Its part of the old city water copper piping so cold.
Old 02-27-2021, 03:34 PM   #7
1978 Sovereign
Old 02-27-2021, 06:28 PM   #8
GCinSC2's Avatar
Post 3 is looking promising.
S/OS #001
Old 02-28-2021, 12:42 PM   #9
1988 32' Excella
Robbinsville , New Jersey
Yeah sounds like over pressure relief valve originally set to 125lbs.
40+ years later, no surprise spring holding it closed is less then 1/2 strength.
EDIT; Better then failing closed and causing other problems.
Old 02-28-2021, 01:57 PM   #10
1976 31' Excella 500
Chappell Hill , Texas
It’s this.
https://m.ferguson.com/product/watts...dFamily-232755
tbashin is offline   Reply With Quote
Old 02-28-2021, 05:20 PM   #11
2018 30' Classic
2004 30' Classic
1972 Argosy 22
Meridian , Idaho
Back in the 70's when Airstream used copper plumbing they include one or more pressure limiting valves to protect the rest of the coach plumbing. It was a measure of over engineering as you can see a pressure regulator plumbed in next to it. Historically the valve will age out and begins to leak as you describe it. Post #3 is correct. The common fix is not to replace it rather simply remove it and insure you use an external pressure regulator.
cbburke is offline   Reply With Quote
Old 03-01-2021, 10:35 AM   #12
That's an excellent point I would rather is leak than break valves haha.
Old 03-01-2021, 10:36 AM   #13
Thanks all! I will probably end just deleting it when I do some updating with my water pump in a few weeks.
Old 03-01-2021, 10:56 AM   #14
1970 23' Safari
Marion , New York
Before deleting it, check your water heater to make sure there is a relief valve installed there. As water heats up it will expand and because a trailer's plumbing is a closed system this water expansion will create pressure in the pipes. At least one pressure relief valve is needed in the system to prevent pipes bursting. I believe all water heaters have a relief valve installed, just something to verify.
'67 Overlander - Mystery water leaking thru new vinyl flooring Billyjchase Repairing/Replacing Floor &/or Frame 1 11-05-2020 09:48 AM
Water leaking when connecting city water- mystery hose nozzle Romelio Fresh Water Systems 1 11-16-2015 06:01 PM
A/C Drain ...leaking at drain hose connection Sav'h Steve Furnaces, Heaters, Fireplaces & Air Conditioning 5 08-01-2004 04:09 PM
water drain valve leaking - help! wayner1239 Fresh Water Systems 14 02-01-2004 04:10 PM
water drain valve leaking - help! wayner1239 Waste Systems, Tanks & Totes 0 01-31-2004 10:03 AM
