I pulled out a three burner Princess Camper stove (Model 100) out of a
1959 trailer years ago. It was working the day I pulled it out. It came with a green regulator Model 349H by Progressive Dynamic of Michigan. I am new at gas stoves so the question I have: Is this old regulator a high or low flow? I plan on attaching it to an 80 lb LP tank.
I wrote Progressive and they could not retrieve any info on such an old item but said any regulator, 2 or 1 stage, will work. That doesn't sound right. I would like information on which modern regulator could I use and steps to install it properly.
This Princess stove is not returning into a trailer but a cabin. Any and all information would be appreciated. I have done some research but got to start with the right regulator. Probably needs to be tested, too.
