Old 05-04-2019, 09:48 AM   #1
2016 19' Flying Cloud
Newtown , Connecticut
Travelling with extra propane tanks
We are planning our first long trip to Yellowstone and want to bring extra 20lb propane tanks in the back of the SUV for use with generator, coleman stove, etc. Is there any restrictions or safety issues with carrying 2 - 3 tanks in the back of an SUV? Thanks.
brundom is offline   Reply With Quote
Old 05-04-2019, 10:31 AM   #2
2007 27' Safari FB SE
NW Oregon in a nice spot , Oregon
It is not safe to carry propane tanks in an enclosed and sealed location...such as a vehicle. The gas is heavier than air and should a leak develop with the tank you and the occupants are at serious risk of breathing issues and/or fire.
There are plenty of places to get refills on propane at the campgrounds in Yellowstone. My suggestion is to use those. When we were there we would run one empty, then fill it while using the second.
bweybright is offline   Reply With Quote
Old 05-04-2019, 10:44 AM   #3
1986 31' Sovereign
Miami , Florida
No need. Propane is readily available both inside the park and in the gateway communities.
Middle-aged Safari SE
Young, lovely bride
Dismissive cat
Old 05-04-2019, 11:47 AM   #4
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
Propane is not to be kept in an enclosed area. So no, I would not do it. I think it would be a huge safety no-no. I think the tank will vent if it gets hot. They often seem to leak a little. You might look at putting a bigger or an additional tank on the trailer if you really think you will need more propane.
Old 05-04-2019, 02:22 PM   #5
"Cloudsplitter"
2003 25' Classic
FWIW....
"When transporting gas cylinders:
Do not carry a cylinder greater than 9kg in an enclosed vehicle.
You can transport up to 2 cylinders (of 9kg,(18.8lb) or less) at a time in an enclosed vehicle.
Secure each cylinder upright in the vehicle, preferably in the boot, with a plug firmly fitted in the POL valve.
Aug 2, 2017"
On the road, I've kept our generator's Type1 11lb pancake cylinder in the Classic's boot since '07, NP, boomless.🤯 No smells.
Old 05-04-2019, 02:32 PM   #6
1988 25' Excella
1987 32' Excella
Thanks Bob.
My mistake then. I actually did not know that.
So if you have the plug in it is okay? I apologize for jumping in. I certainly have carried the little torch cylinders and keep them in the garage.
Old 05-04-2019, 02:49 PM   #7
SeaLevel's Avatar
2016 25' Flying Cloud
Jupiter , Florida
We don't have a SUV, but we have carried an extra 20LB propane tank in the back of our truck, and they fit perfectly inside a milk crate. Transporting them that way keeps them both upright and in place, without using too much extra space.
"A good traveler has no fixed plans, and is not intent on arriving." - Lao Tzu
SeaLevel is offline   Reply With Quote
Old 05-04-2019, 08:55 PM   #8
2007 22' International CCD
The 20 pound tanks need to be in a ventilated area. The plug does not do anything other than keep dirt out of the valve threads. The problem is the relief valve and the fill valve screw can leak no matter what.
Carry in the back of a pickup truck, or in the Airstream tank rack. Note that any trailer tank rack is open at the bottom for a darn good reason.
Propane in a confined space, mixed with the right amount of air is also known as a “fuel/air explosive” as well as a breathing hazard. Don’t carry in the passenger compartment of any vehicle.
US rules are like I stated-no enclosed spaces. Dunno about Canada. Here the plugs are soft, cheap plastic covers for dust or the screw in ones are also cheap plastic that will not hold pressure at all. We had a valve fail and vent much of the tank. A plastic screw-in plug just blew right out when the tank warmed a bit. We carried it far away from the area downwind and let it vent until empty. Problem is super cold propane from a rapid venting situation turns to slush in the tank, and then takes a long time to boil off in that state. No fun with 3,000 Boy Scouts in the area.
Old 05-05-2019, 04:38 AM   #9
Sag Harbor , New York
Don't you already have a quick-connect low-pressure propane port on your FC19? Plenty of folks run gens, BBQ's and portable fire pits off these ports. Do you have 1 or 2 propane tanks onboard?
Never carry propane tanks inside a vehicle, for the reasons already proffered. Upgrade the Airstream's propane system if needed, for a much better long-term solution IMO.
Peter
Old 05-05-2019, 05:28 AM   #10
"Cloudsplitter"
2003 25' Classic
Oh cr@p...I also remove the tags from my pillows.😂
I'm certainly glad we all have our own 'rules' here in the G O USA. 👍
I found mine on the interweb, they must be rite.🤔
Old 05-05-2019, 05:31 AM   #11
2019 30' International
Pennsylvania , Pennsylvania
What about a 20 lb. tank in a pickup bed that has a cap on it?
If you ain't havin' fun you ain't doin' it right
2017 Ford CCSB F250 XLT 6.2L Gas 4x4 4:30 rear Leer Topper Ruby Red
2019 International Serenity 30 Rear Twin
majorairhead is offline   Reply With Quote
Old 05-05-2019, 05:36 AM   #12
Adventure.AS's Avatar
2017 25' International
Niagara-on-the-Lake , ON Canada
I always carry my propane tanks in my vehicle to be refilled and follow the recommendations of Superior Propane. They are kept upright and lashed in place, with the windows open. It would be very impractical to tow the Airstream to the refill station every time I needed more propane. However, I wouldn't carry them in my vehicle for an extended trip.
Ray B.
Adventure.AS is offline   Reply With Quote
Old 05-05-2019, 05:41 AM   #13
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
I don't see the need for extra tanks. Ours last for weeks and we never had a problem finding a place to refill them.
YMMV.
2019 Ford Expedition Platinum
Wayne&Sam is offline   Reply With Quote
Old 05-05-2019, 05:45 AM   #14
Silvr_Bullet's Avatar
2017 16' Sport
N/A , N/A
forewarned is forearmed, you probably know the right answer about the enclosed area.
Silvr_Bullet is offline   Reply With Quote
Old 05-05-2019, 05:51 AM   #15
So you are saying no way you'd haul a 20lb tank in a pickup truck with a cap on it?
Old 05-05-2019, 05:59 AM   #16
2017 16' Sport
N/A , N/A
In my opinion your suggestion is a good option, practically we need to transport them to refill etc. I personally would not for long periods carry in my vehicle other than stated, that’s me.
Old 05-05-2019, 06:04 AM   #17
"Cloudsplitter"
2003 25' Classic
And you keep all the windows open at home with NG.
Your home is considerably more likely to blow than a properly secured LP tank. AMHIK
Old 05-05-2019, 06:10 AM   #18
2017 16' Sport
N/A , N/A
Your probably right, on the other hand I’am not a moving target. I really don’t want to argue everyone’s entitled to an opinion, I thought that’s what we’re doing here.
Old 05-05-2019, 06:41 AM   #19
Wayne&Sam's Avatar
Images: 21
And what are the millions of gas BBQ owners doing when they need a refill?
Old 05-05-2019, 06:45 AM   #20
eubank's Avatar
Airstream - Other
Bosque Farms , New Mexico
Back when we owned the RV park and I filled cylinders, people would come by to fill BBQ bottles all the time. If they were transporting in an enclosed area (inside a car, in a truck, in an enclosed cap, etc.), I asked them to make sure it was upright, to open a window or two, and to transport immediately home. On those occasions when people were planning longer trips immediately after filling (like going shopping or what have you), I simply kept the filled cylinder and had them pick it up on the way back home.
No sense dying a very painful death when you don't have to.
Lynn
ACI Big Red Number 21043
eubank is offline   Reply With Quote
Travelling with propane tank valves open Toutsi 1957 On The Road... 30 03-19-2017 08:19 PM
A way to create extra space for holding tanks. malconium Waste Systems, Tanks & Totes 29 10-22-2016 05:44 PM
Turn off propane while travelling? Belbein On The Road... 27 04-28-2014 11:24 AM
Extra water tanks: Bad idea 43,294? Boondocker Fresh Water Systems 11 03-04-2010 09:58 PM
Extra, Extra!! codybear Airstream "In the News" 3 04-16-2007 03:59 PM
