RV News RVBusiness 2021 Top 10 RVs of the Year, plus 56 additional debuts and must-see units → ×
Old 05-05-2019, 08:07 AM   #21
Mollysdad's Avatar
Originally Posted by majorairhead View Post
What about a 20 lb. tank in a pickup bed that has a cap on it?
I'd have no problem with that. Your tailgate is not airtight, so any leak will fall through the gap.
Old 05-05-2019, 08:40 AM   #22
Zil
Curtis Wright
Eyren Haven , South Jersey
It would be easy to search the hundreds of photos of propane gone bad. Propane gas is not much the threat over other gas such as NG. It is when the liquid propane should leak. Transporting from the local refill station to home is different than transport for days and weeks. Why even take the chance?
Zil is offline   Reply With Quote
Old 05-05-2019, 10:33 AM   #23
Married with Airstream
drbrick's Avatar
2004 25' International CCD
Vancouver Island , British Columbia
We carry 2x 20# LP tanks (generator + BBQ) in milk caartons in the back of our TV. Well vented. Would not travel long distance in an SUV without venting. I will add that LP is safer than gasoline which I have seen people carry in there SUV's "YIPES"
La Dolce Vita Brick & Mona
We're Married With Airstream dot com
2004 International 25CCD Registered Name "Blue Streak"
2013 F-150HD FX4 SuperCrew Lariart (MaxTow) "Red Dragon"
drbrick is offline   Reply With Quote
Old 05-05-2019, 01:24 PM   #24
Long Island , New York
Thumbs up
Originally Posted by Zil View Post
. . . Transporting from the local refill station to home is different than transport for days and weeks.
^^^^^^ x2
A 15 minute trip for us . . . a window or two open a bit.
[to clarify earlier post]
OTRA15 is online now   Reply With Quote
Old 05-05-2019, 01:51 PM   #25
Gainesville , Florida
would not travel anywhere in an suv, propane tanks or not. Saw somewhere on the web they were dangerous so it must be true. why would you want to put them inside an enclosed vehicle other than a truck bed?
Old 05-05-2019, 05:00 PM   #26
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Faulty Refers are one of the most common causes for RV fires, for real. 🤔
No tanks but plenty of LP.
Where is that ash tray?
Its not the system thats the problem, think Circus, its not the car, its that the car is full of Clowns.
John Turley
Tahawus
Old 05-05-2019, 07:57 PM   #27
2016 19' Flying Cloud
Newtown , Connecticut
Thanks, yes two 30 lbs... Just not sure how long these will last running a fridge, stove, etc. and then a generator and BBQ etc. Thought we'd need extra. Please advise.
brundom is offline   Reply With Quote
Old 05-06-2019, 09:48 AM   #28
SewStream's Avatar
Sanford , Arizona
Travelling with extra propane tanks
@brundom - you have 60#s of propane onboard your AS? You will be fine! We travel full-time and have boondocked/dry camped without ever running out of propane even when running the generator on propane. The bottles are easy to remove and take to be refilled. We do it all the time, as needed. Propane seems to be available everywhere, once you start looking for it. You can even search for it on GoogleMaps.
SewStream is offline   Reply With Quote
Old 05-06-2019, 09:50 AM   #29
2016 27' International
Anacortes , Washington
We used to carry the two 30# tanks on our 3 week road trips, but have found carrying one is more than we ever need. So we only travel with the one, no need to add the second one onto the tongue weight. We seldom use the furnace, just the heat pump as we don't travel in the cold months.
Pat Pierce is offline   Reply With Quote
Old 05-06-2019, 12:41 PM   #30
1986 31' Sovereign
Miami , Florida
Propane sources are also on the Allstays App.
Sorta new (usually dirty) Nissan Titan XD (hardly paid for)
Middle-aged Safari SE
Young, lovely bride
Dismissive cat
Old 05-07-2019, 07:21 AM   #31
Thanks, not having actual experience yet this info is very helpful.
Old 05-07-2019, 08:06 AM   #32
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
We travel with 2 30 pound tanks. We use the gas stove a lot, gas WH all the time, propane heat and run the fridge on gas while we travel. We end up buying 1 tank of propane about once a month when in full travel and usage mode. It is very easy to find and buy propane on the road. We do not use it for barbecue grill or generator. I do not know how much a generator takes but I bet you do if you had it converted? I keep one tank open and one closed and switch manually and fill as soon as one bottle is empty so I know I always have about a months supply on board. I would suggest going with just the tanks on the trailer with one closed and one open. Watch how long it takes too empty. Then decide if you will need more tanks. I am betting you will be surprised at how long a tank lasts.
Old 05-07-2019, 08:10 AM   #33
Well said, Bill.
Keep It Simple, Stu.
One tank open, one closed.
Refill when needed.
Happy Trails!
Peter
Old 05-07-2019, 08:25 AM   #34
Adventure.AS's Avatar
2017 25' International
Port Dover , ON Canada
Originally Posted by Bill M. View Post
... I keep one tank open and one closed and switch manually and fill as soon as one bottle is empty so I know I always have about a months supply on board.
That system doesn't work for us living/travelling during the cooler months. The furnace often runs at night. I don't fancy getting up to manually switch tanks, so I prefer to use the automatic switch over valve that came with our AS and just open the tank lid and check everyday to see if has switched over. I move the valve lever over to indicate the new full tank and remove the empty one and take it for refilling. That one now becomes the reserve tank.
Ray B.
Adventure.AS is offline   Reply With Quote
Old 05-09-2019, 07:24 AM   #35
Thanks, good to know your usage experience. Another question is, how to connect to the AS quick connect port? Our generator regulator has the screw on connection that fits the threads on a standard tank. Are there adaptors available? If so, where to purchase?
Old 05-09-2019, 07:53 AM   #36
rideair's Avatar
And to think hot air balloon pilots travel with balloon baskets inside of vans all over the country to events with 40-60 gallons of propane in the basket all the time. Rule has always been, "Show up full of fuel, leave full of fuel".
Now that I've read this thread, guess I'll never be attending another balloon event in my life.
The rules of life that others provide.
Enjoy,
Paul Waddell
rideair is offline   Reply With Quote
Old 05-09-2019, 08:32 AM   #37
1988 25' Excella
1987 32' Excella
Do they carry the basket with the fuel in it home in a closed SUV? I would think while in flight a balloon basket is better vented than a Escalade.
Old 05-09-2019, 08:42 AM   #38
As your generator has a regulator it won't work from the low pressure port on the Airstream. You would need to check with the generator manufacturer to see if they have a kit so you could remove their regulator and run a hose with a quick disconnect to the low pressure port.
Ray B.
Old 05-09-2019, 08:47 AM   #39
UncleBad's Avatar
2018 27' Tommy Bahama
Marana , Arizona
Which generator do you have?
2018 27FBQ Tommy Bahama - "Indecision" w/Blue Ox SwayPro, Centramatics, Dual EasyStarts, Airstream Connected, Airtug Trailer Tug HD
2012 F250 6.7 Powerstroke King Ranch - "Earl", Centramatics, Viair On Board Air
UncleBad is offline   Reply With Quote
Old 05-09-2019, 09:10 AM   #40
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
Doing some checking for our tip this summer, I discovered that many ferries and tunnels have restrictions on the number and size of propane tanks you can travel with. We had planned to travel with an extra 30 lb tank, but will leave it home to be in compliance with the rules.
Richard
Travelling with propane tank valves open Toutsi 1957 On The Road... 30 03-19-2017 09:19 PM
A way to create extra space for holding tanks. malconium Waste Systems, Tanks & Totes 29 10-22-2016 06:44 PM
Turn off propane while travelling? Belbein On The Road... 27 04-28-2014 12:24 PM
Extra water tanks: Bad idea 43,294? Boondocker Fresh Water Systems 11 03-04-2010 10:58 PM
Extra, Extra!! codybear Airstream "In the News" 3 04-16-2007 04:59 PM
