Old 06-16-2021, 12:31 PM   #1
2021 27' Globetrotter
Malibu , California
Angry Tank Monitor Upgrade?
I am beyond annoyed by using the antiquated tank reader we have in our Airstreams. They could have just used a different display so that at least you can see tank levels without pressing on them, or add a visual / audible alarm when you reach 95% or so.
The constant anxiety of checking 3 times a day where you are at is painful.
Has anyone upgraded the monitor to something better?
CMHM is offline   Reply With Quote
Old 06-16-2021, 12:36 PM   #2
Dennis C's Avatar
2020 23' International
Evergreen , Colorado
SeeLevel sells an upgraded unit that has bluetooth connectivity. Perhaps this would suit your needs, and I would imagine that it's plug-and-play.
Dennis
2020 International Serenity 23 FB "Sparkle Plenty"
2018 GMC Denali 1500 Crew Cab 4x4
Airstream Club International #2805
Dennis C is online now   Reply With Quote
Old 06-16-2021, 02:21 PM   #3
Half a Rivet Short
Carlisle , Pennsylvania
Hi
The SeeLevel units (at least the modern ones) will interface over a serial bus to most of the fancy control / display gizmos. They likely would also talk to a PC / RPi or Arduino. As long as you don't mind fiddling a bit, the options for display and alarms are near endless.
uncle_bob is online now   Reply With Quote
Old 06-16-2021, 02:31 PM   #4
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
The difficulty is installing the SeeLevel sensors.
2019 Ford Expedition Platinum
Old 06-16-2021, 02:42 PM   #5
Half a Rivet Short
Hi
At least most (if not all) modern Airstreams already have the SeeLevel sensors and interface on them. That's even true of the "fancy" stuff with the touch panels and displays. All they do is hook into what appears to be the same setup everybody has.
Old 06-16-2021, 02:54 PM   #6
Wayne&Sam's Avatar
Images: 21
Hi
If by modern you mean 2015 and newer (which I see all of you have).
Old 06-16-2021, 02:59 PM   #7
2002 19' Bambi
Lafayette , California
Compared with tank level indicators previously in Airstreams, the SeeLevel is anything but antiquated. I suspect the reason they do not continuously give a readout is to avoid battery drain. Even a Bluetooth connection will probably require that you ask it to show the levels.
Tim
Tim A. is offline   Reply With Quote
Old 06-16-2021, 03:10 PM   #8
ITSNO60's Avatar
Tucson , AZ
"Hey Alexa, how much poop is in the tank?"
Brian
ITSNO60 is offline   Reply With Quote
Old 06-16-2021, 04:57 PM   #9
Wayne&Sam's Avatar
Images: 21
I think getting to know your system is better than a monitor. I have the old style which isn't all too accurate. But I don't find it to be a problem.
If I'm camping with hook ups, the grey tank valve stays open until the last 24 hours. Then it's closed to build up a bit for the flushing at the dump station.
If I'm boondocking, the tanks can't back up because the grey and waste tanks hols more than the fresh water tank.
For me, it's just not a problem. YMMV.
Old 06-16-2021, 05:53 PM   #10
Half a Rivet Short
Hi
.... and (judging by their info) so does the OP ....
Old 06-16-2021, 06:38 PM   #11
2019 30' Flying Cloud
Grass Lake , Michigan
I guess itís all relative. Most other RVs have the LEDs to indicate 1/3, 2/3, Full with the internal tank sensors that work for about 3 nanoseconds before failing. Iím happy to have the SeeLevel system. Pushing the buttons counts towards my daily workout.
oldenavy is offline   Reply With Quote
Seelevel II Tank monitor- reads 0 for Black tank waninae39 Electronics & Connectivity 2 08-07-2020 04:00 PM
12V converter/battery/monitor upgrade dznf0g Batteries, Univolts, Converters & Inverters 35 01-31-2016 07:49 PM
Does the Micropulse Monitor Panel Monitor LP? KJRitchie LP Gas, Piping, Tanks & Regulators 5 03-21-2013 02:20 PM
Tank level monitor suggestions for new black/gray tank redreefet Waste Systems, Tanks & Totes 5 06-28-2012 06:39 PM
Upgrade to a new system monitor? GoNomad Electrical - Systems, Generators, Batteries & Solar 7 10-27-2006 07:02 AM
