RV News RVBusiness 2021 Top 10 RVs of the Year, plus 56 additional debuts and must-see units → ×
Old 02-14-2021, 12:52 PM   #1
2017 19' International
Tallahassee , Florida
Rust under propane tanks
Took off one of propane tanks for a refill and found a lot of peeling paint and rust below, on the stand that holds the two tanks.
Other than sanding off and spraying on some Rust-Oleum paint, anything I could do to prevent another rust outbreak?
WhereStream is offline   Reply With Quote
Old 02-14-2021, 01:20 PM   #2
eubank's Avatar
Airstream - Other
Bosque Farms , New Mexico
Metal on metal is pretty hard on paint. Make sure your cylinders are not wiggling around. After repainting, if this continues to be a problem, I guess you could put a layer of rubber between holder and cylinders, but I suspect that's overkill.
Lynn
WBCCI 21043
eubank is online now   Reply With Quote
Old 02-14-2021, 01:49 PM   #3
RivetED's Avatar
2004 25' Safari
2018 26' Flying Cloud
2019 25' Flying Cloud
North Central Texas , USA
There's not much you can do. A thin rubber mat might help.
I made 2 wooden elliptical wedges. By using the tank bottom and tank holder you get the radius of each, offset the center points a little and end up with one end a little (~1/4") wider than the other. They are painted and when the tanks are set you can slide the wedges around until they lock/get tight.
This works fairly well keeping the tanks from moving and also helps with keeping the center weld on the tank from cutting into the aluminum tank cover. That also keeps the tanks from scraping off too much paint/powder coat. Rustoleum every couple of years.
Photo:
RivetED is offline   Reply With Quote
Old 02-14-2021, 02:28 PM   #4
jayseejay's Avatar
2015 27' FB Eddie Bauer
2011 25' FB Flying Cloud
Fernandina Beach , Florida
We use these; works well. They raise the tanks up a bit, but they still lock down with the AS cover.
Joe
https://www.tanktire.com/
jayseejay is offline   Reply With Quote
Old 02-14-2021, 10:05 PM   #5
StuartsDad's Avatar
2018 28' Flying Cloud
Chapin , South Carolina
I took 1/4" rubber hose, like fuel line. Cut 2" pieces and slice lengthwise. Slip 3 or 4 of these on to the bottom ring of the tank. Simple, cheap, and eliminates the metal to metal contact.
StuartsDad is offline   Reply With Quote
Old 02-14-2021, 11:32 PM   #6
Ahroc's Avatar
2003 25' Safari
Keizer , Oregon
Hi.
I'm slowly fixing up my 03 and the rust bothers me also. I haven't done it but I was thinking about spray on truck bed liner. I think it would be a good-durable-solution for the propane tank trays.
Ahroc is offline   Reply With Quote
Old 02-15-2021, 05:34 AM   #7
Interesting. Thanks for the tip.
I just threw away an old garden hose.
Maybe Iíll fish it out of the bin and cut off a section, split it and see if it will do the job.
Old 02-15-2021, 05:35 AM   #8
Joe
So, this must be a common problem.
Old 02-15-2021, 05:36 AM   #9
Photo:
Nice work!
Old 02-15-2021, 08:41 AM   #10
richw46's Avatar
Lexington , Kentucky
This looks like a very good idea. Did you try to just use enough hose to just go around the entire bottom ring as a single piece? I just repainted our LP base and haven't been on the road yet. I'd like to get something in place so it doesn't rust again. Tanks need to be replaced too so it would be great to start off with this solution.
-Rich
Rich & Yvonne
2006 Safari SE -Dora-
2004 4Runner SE
Most of us don't know exactly what we want, but we're pretty sure we don't have it. -Alfred E. Neuman
richw46 is offline   Reply With Quote
Old 02-15-2021, 09:53 AM   #11
dznf0g's Avatar
Oswego , Illinois
X2. 11 years on the AS and 17 years on the old sob. Works well.
-Rich-
Old 02-15-2021, 10:26 AM   #12
MSL
2019 22' Sport
Sharon , Massachusetts
Corrugated Wire Protector
I used this after repainting:
https://www.homedepot.com/p/Gardner-...8C10/205588197
MSL is offline   Reply With Quote
Old 02-15-2021, 10:30 AM   #13
Married with Airstream
drbrick's Avatar
2004 25' International CCD
Vancouver Island , British Columbia
Yep, scrape and paint ... with metal on metal you get rust. I had an old rubber floor mat from a car cut it into circles for under the tanks - problem solved...after I painted.
La Dolce Vita Brick & Mona
We're Married With Airstream dot com
2004 International 25CCD Registered Name "Blue Streak"
2013 F-150HD FX4 SuperCrew Lariart (MaxTow) "Red Dragon"
drbrick is offline   Reply With Quote
Old 02-15-2021, 10:32 AM   #14
2018 30' Flying Cloud
Fort Myers , Florida
Herculiner
The next time I have to repaint tank tray Iím going to try Herculiner. Itís a truck bed liner spray and seems like it would hold up.
Wheelestate is offline   Reply With Quote
Old 02-15-2021, 10:51 AM   #15
2018 27' International
Truckee , CA
I got the Mopeka tank monitor that comes with a plastic riser. Works perfect to prevent rust and I like the monitor function via an app on my phone
dhaven is offline   Reply With Quote
Old 02-15-2021, 11:22 AM   #16
jamieb1086's Avatar
2016 25' Flying Cloud
Selbyville , Delaware
I just got the Mopeka Halo Rubber rings for the bottom of the LP tanks. https://www.amazon.com/Mopeka-Tank-C...7HQZRR9F&psc=1
Jamie
2016 25' RBT Flying Cloud "Bullseye"
2016 Chevy 2500 High Country Duramax Diesel "Red Bull"
WBCCI #9026 Watchung NJ Unit
jamieb1086 is offline   Reply With Quote
Old 02-15-2021, 01:04 PM   #17
Steamy1's Avatar
2015 23' FB International
2007 19' International CCD
Steamboat Springs , Colorado
I use these as well. Sanded the tray and sprayed with Flexseal, then placed the rubber ring and tank. I think this will do the job.
Steamy1 is offline   Reply With Quote
Old 02-18-2021, 07:50 PM   #18
StuartsDad's Avatar
I just used three short pieces of rubber hose. My concern with running hose all the way around the tank bottom would be it holding water from road spray, etc. causing the tank ring to rust again.
Old 02-19-2021, 04:46 AM   #19
Good point ó*that makes a lot of sense.
Old 02-21-2021, 10:18 AM   #20
2019 20' Flying Cloud
Placerville , California
Mopeka
Mopeka 024-5002 LP Check Tank Halo
On Amazon. They also have a kit that “sounds” the tank and relays fill% to readout in trailer I really like this setup, including halo. I sanded mine first, primed, then painted, then installed Mopeka system.
Dwen is offline   Reply With Quote
Want to Trade my 30lb Propane Tanks for your 20lb Tanks WEBOPS LP Gas, Piping, Tanks & Regulators 43 01-23-2021 11:38 AM
Tanks, Tanks, Tanks PSU1981 Plumbing - Systems & Fixtures 8 09-02-2019 10:34 AM
Dealing with Rust Under LP Tanks Llando88 LP Gas, Piping, Tanks & Regulators 13 11-18-2018 01:54 PM
Rust? What rust?? Black tank? What black tank??!? gadgetgeek Repairing/Replacing Floor &/or Frame 2 08-08-2018 11:20 AM
Rust and Frames Por 15 Zero Rust Tony S Repairing/Replacing Floor &/or Frame 10 02-20-2013 04:45 PM
