RV News RVBusiness 2021 Top 10 RVs of the Year, plus 56 additional debuts and must-see units → ×
Old 02-21-2021, 10:42 AM   #21
Hans627's Avatar
2009 25' FB International
2018 27' Globetrotter
Hanover , Pennsylvania
I also use the Mopeka system. Works well with halo.
Old 02-21-2021, 10:44 AM   #22
1999 28' Excella
Lake Mary , Florida
After cleaning the rust off the tank bottom and tank support plate, paint both with epoxy primer, two coats. Then just use an old bicycle inner tube, split open, as mentioned by others do not make it continuous but leave gaps between the pieces for water/moisture to drain out. I support the bottom of the tank four short segments of inner tube.
suncoasteng is offline   Reply With Quote
Old 02-21-2021, 11:39 AM   #23
David Logue's Avatar
2008 25' Safari FB SE
Allen , Texas
rust in propane area
With what you found in the propane bottle area will be nothing to what you fine in side the battery box.
David Logue is offline   Reply With Quote
Old 02-21-2021, 05:09 PM   #24
1972 23' Safari
troup , Texas
I keep old inner tubes from bicycles that I repair. find one that you can slip over the spacer on bottom. if you cant find the exact fit double it over. so like a 16" tube will become a 8" when doubled. like a big rubber band.
72sahara is offline   Reply With Quote
Old 02-22-2021, 05:20 AM   #25
2017 19' International
Tallahassee , Florida
OK, I've got a bunch of old bicycle inner tubes!
WhereStream is offline   Reply With Quote
Want to Trade my 30lb Propane Tanks for your 20lb Tanks WEBOPS LP Gas, Piping, Tanks & Regulators 43 01-23-2021 11:38 AM
Tanks, Tanks, Tanks PSU1981 Plumbing - Systems & Fixtures 8 09-02-2019 10:34 AM
Dealing with Rust Under LP Tanks Llando88 LP Gas, Piping, Tanks & Regulators 13 11-18-2018 01:54 PM
Rust? What rust?? Black tank? What black tank??!? gadgetgeek Repairing/Replacing Floor &/or Frame 2 08-08-2018 11:20 AM
Rust and Frames Por 15 Zero Rust Tony S Repairing/Replacing Floor &/or Frame 10 02-20-2013 04:45 PM
