Old 04-16-2023, 10:16 AM   #1
2011 16' Sport
Springboro , Ohio
Running copper propane through tight space
Replacing the hot water heater in our 2011 16’ sport and the propane line is about 6-8” short for the new dometic unit. I’m running a new line which shouldn’t be an issue. I got the old one out and the path is really tight. Hoping someone has an idea.
It runs vertically about 6” from the exterior, it is directly below the refrigerator box and makes a hard 90 for about three inches before having space to run vertical again. It really wants to kink and bind as I’m fishing it. I’m trying with and without a protective pipe around the copper.
Ideas welcome.
Thanks!
beckspeed is offline   Reply With Quote
Old 04-16-2023, 01:22 PM   #2
Cave Creek , Arizona
Ideas welcome.
Thanks!
Have you considered replacing the copper pipe with flexible propane hose? I was at Jackson Center recently and when they replaced an appliance they removed the copper and use the rubber (like?) hose. Not sure what the material is exactly but they said they are using on all trailers now and eliminating copper
Pete B55
2017 Classic
2017 F-250
Pete B55 is offline   Reply With Quote
Old 04-16-2023, 08:22 PM   #3
2011 16' Sport
Springboro , Ohio
We’ll that would be awesome. Thanks Pete! Any other info would be appreciated. Color etc. thanks
Old 04-17-2023, 05:53 AM   #4
Look at etrailer. They have 12/15/20 foot propane thermo rubber hoses. Might be able to find locally too
Pete B55
2017 Classic
2017 F-250
Old 04-17-2023, 08:06 PM   #5
2011 16' Sport
Springboro , Ohio
Thanks!
Old 04-18-2023, 09:17 AM   #6
1976 Argosy 24
1961 28' Ambassador
1968 26' Overlander
Lakewood , Colorado
Yep, flex hose, I go to my propoane guy and he makes me any custom hose while I wait. Price very reasonable. They also have every fitting you could imagine and then some.
Good luck, Mark D
mrdes8 is offline   Reply With Quote
Old 04-20-2023, 07:24 AM   #7
2011 16' Sport
Springboro , Ohio
Well that sure was easy.
Took 5 min to run the flex hose. Thanks for the tip. You guys rock.
Have to back up a very tight 150' driveway into a tight space... front hitch? starkruzr Towing, Tow Vehicles & Hitches 57 07-01-2020 10:38 PM
How much larger are 16's over 15's? Tight space! Mark Lem Tires 9 10-25-2016 06:43 PM
Brakes, How tight is too tight? rhutson Brakes & Brake Controllers 5 03-15-2012 12:48 PM
How tight is too tight? Alden Miller Awnings 16 06-01-2006 09:09 PM
