Free 7 Day Trial RV GPS App RV Trip Planner RV LIFE Campground Reviews RV Maintenance Free 7 Day Trial ×
Old 12-20-2021, 07:11 PM   #1
1999 28' Excella
Lake Mary , Florida
Recycle/Refill your 1 pound LP tanks
Using a 20lb BBQ LP tank to refill and reuse your small LP tanks for outdoor grills or heaters.
Saves lots of $$$
suncoasteng is offline   Reply With Quote
Old 12-20-2021, 08:49 PM   #2
2021 27' Globetrotter
Daytona Beach , Florida
I've converted most of my propane stuff to run off my trailers low pressure port and those that I can't convert, I'm using a hose extension and a 20lb tank. I won't use the 1lb green bottles anymore.
nitzo is offline   Reply With Quote
Old 12-20-2021, 09:36 PM   #3
2020 23' Flying Cloud
Sebastian , Florida
I got tired of dealing with regulators that failed at the most awkward times on my Q grill and converted it to run directly from the A-S supplied low pressure port. Most other campsite appliances use too much fuel to run off the green toy bottles.
There have been many amusing (for a vicarious reader) posts on this forum about what happens when the process goes wrong. And those are just from the members that lived to tell the tale...
Why take chances? There are 5 and 11 pound cylinders available at the big box stores. Our local RV dealer, as well as Tractor Supply, charges by the pound, regardless of amount put in the tank. More convenient and WAYYY safer.
-Don
(That man in that tiny can)
(Same man, Bigger can)
GetawA-S is offline   Reply With Quote
Old 12-21-2021, 01:28 AM   #4
2007 22' International CCD
If you take the time to read the label on ANY disposable propane bottle, you will note that it is against the law to refill the bottles. The reason is these cheap bottles are filled very precisely by automated machines to an exact weight.
Any slight overfill will lead to excess propane in the bottle, and put it at a higher pressure, which can cause the bottle to swell or burst. In other words, refilling creates a bomb. Not a wise thing to do.
Bottom line, it’s a totally stupid dangerous thing to do.
You want refillable small bottles, buy a real, properly designed refillable bottle with a proper fill valve or ‘ten percent’ valve built in to fill it properly. This practice is one of those that seems safe, until it isn’t, usually results in an explosion or a fire.
I really get tired of seeing d*mn fools espouse dangerous and illegal practices on assorted media….
rmkrum is online now   Reply With Quote
Old 12-21-2021, 11:13 AM   #5
DaveG's Avatar
Here and There , Pacific Northwest
The only 1 lb bottle I have seen claiming it is refillable is Flame King and I believe they are in recall for a welding problem. Flame King has an entire refill kit available (but not available - maybe do to supply chain issues?). We purchase the Coleman brand bottle and discard. Also using just any hose right off a tank without a regulator in front of it is another issue worth research. If you use an item like a ceramic heater the wrong hose will cause failure from oil getting squeezed out (hose expands then contracts with pressure) of the hose material clogging the heating unit. Let's also agree it is dangerous to run an air driven impact tool off a propane tank People suggest some crazy things on assorted media.
DaveG is offline   Reply With Quote
Old 12-21-2021, 12:14 PM   #6
1988 32' Excella
Robbinsville , New Jersey
Actually the labels say it's illegal to transport a bottle that has been refilled.
Still i agree not worth refilling those bottle.
Old 12-21-2021, 12:44 PM   #7
Antsville , FUBAR
I refill the one pounder's until they fail the bubble test, usually 3-4 times.
POI I've never had an overfill problem when bleed filling from our Barbecue tank, they usually fill to just under 3/4lb.
I think it may be impossible to overfill without a pump.🤔
BTW....The 'tank inspector shows up at my site and asks to see all my 'legal' 1lb tanks, how's he 'gonn'a know the ones I've refilled 3 times?
Old 12-21-2021, 01:35 PM   #8
Petaluma , California
So, let me see if I can follow the logic....spend $70-$100+K on an Airstream, $70-$80K on a TV and it's the best thing to do is refill $5 LP bottles and use scrap lumber for pads....gotta think on that....
TinShanty is offline   Reply With Quote
Old 12-21-2021, 01:57 PM   #9
Janet H's Avatar
1964 26' Overlander
1964 19' Globetrotter
OlyPen , Washington
Images: 90
FlameKing makes a dot compliant refillable 1 pound bottle (and refill kit)but the disposable tanks... no.
Good reading here: https://www.rvtravel.com/why-you-sho...ane-cylinders/
1964 Overlander | 2020 Mercedes GLE
AirForums Custom Search
Janet H is offline   Reply With Quote
Old 12-21-2021, 02:06 PM   #10
davidz71's Avatar
1986 25' Sovereign
Southern Middle , Tennessee
I use Flame King 1 lb. refillable bottles on my Weber Q grill by using the Flame King kit and I am having no problems at all. I kept having problems with hoses and the 20 lb. tank on the Weber but 1 lb. tanks work fine. I got tired of the rising prices on Coleman lb. bottles and went the other route. I do use a 20 lb. tank with a Buddy heater/filter or an Olympian Wave 6 heater without problems. I also use a 6" x 6" x 12" chunk off a barn post under my trailer jack with perfect results. These work for me.
Craig
AIR #0078
3.73 rear end
Mag-Hytec rear diff cover
Amsoil synthetics all around
Old 12-21-2021, 02:08 PM   #11
2017 25' International
West Lake Hills , Texas
Originally Posted by GetawA-S View Post
...converted it to run directly from the A-S supplied low pressure port.
...Tractor Supply, charges by the pound, regardless of amount put in the tank.
^1 on TS and AS low pressure port.
A 20-foot propane hose (as previously mentioned) replaced the 20# propane tank.
There was a Tractor Supply in about every moderately-sized town we passed through this fall.
Fungus is offline   Reply With Quote
Old 12-21-2021, 03:26 PM   #12
jcanavera's Avatar
2004 30' Classic Slideout
Fenton , Missouri
Images: 143
I ditched the 1 lb bottles when I bought my Q, Instead I carry a small 11 lb bottle with a long hose. Works great with the Q and gives me a lot of flexibility as to where I cook!
Jack
Jack Canavera
STL Mo.
AIR #56 S/OS#15
Old 12-21-2021, 03:32 PM   #13
DonRich7878's Avatar
2013 30' Classic
Key West , Florida
I think RMKrum wants to speak with a manager...
DonRich7878 is offline   Reply With Quote
Old 12-21-2021, 04:02 PM   #14
Antsville , FUBAR
Don't hurt the brain locker...TETO.
The Airstreamers Credo...
“If you’re happy with what you’re doing…it’s good.
If other people are unhappy….it’s not”
RLC
Old 12-21-2021, 04:08 PM   #15
Jeff7176's Avatar
2018 25' International
Full-time , Traveler
+2...the low pressure port is great and we are big fans of Tractor Supply.
Jeff7176 is online now   Reply With Quote
Old 12-26-2021, 10:40 AM   #16
Mollysdad's Avatar
I looked into a 5 pound tank and the price was $115!
I can go through a lot of green bottles for $115.
Old 12-26-2021, 11:37 AM   #17
Lost in America
mojo's Avatar
2015 27' FB International
2004 19' International CCD
Santa Fe , New Mexico
You actually read directions?
This is the strangest life I've ever known - J. Morrison
2015 Airstream International Serenity 27FB
2017
Chevy Silverado 2500HD Duramax Diesel
mojo is offline   Reply With Quote
Old 12-26-2021, 12:27 PM   #18
Rich W's Avatar
I'm In , Kentucky
My 30 lb. cylinders have both expired but one was still full. I looked at buying a new one a couple years ago and the price wasn't much above a 20 lb. Now the price is about 50% higher plus the tank needs to be purged before filling, which is an extra charge. I took the empty one to our local LP gas place and they did a swap out, like Blue Rhino does. The guy said "are you sure it's expired?" because the tank looked in good condition. He checked the date and agreed. I got another one that was full but it looked like it had been through the wringer. For $39 I'm not complaining... too much, but I'll be using that one first.
-Rich
Rich & Yvonne
2006 Safari SE -Dora-
2004 4Runner SE 4.7L V8
Rich W is online now   Reply With Quote
Old 12-26-2021, 02:06 PM   #19
It’s been known to happen in a moment of weakness. I still keep my ‘man card’ handy.
Old 12-26-2021, 06:08 PM   #20
jcanavera's Avatar
Fenton , Missouri
Images: 143
If you look at different outlets I found some as low a $50. I think I paid about $20 for my 11 lb tank many years ago. Average I have seen in this part of the country is about $65. Funny that the 20lb tank actually is priced as low as $32. I've save a lot of $$ over the years cooking with that tank rather than the disposables.
Jack
Jack Canavera
STL Mo.
AIR #56 S/OS#15
Recycle, Sell, Repurpose or Trash? Paddledipper Brakes & Brake Controllers 9 10-20-2014 10:28 PM
Recycle that old copper pipe idroba Fresh Water Systems 1 08-03-2012 03:59 AM
About to Recycle my Reese Dual Cam thecatsandi Hitches, Couplers & Balls 11 11-30-2011 08:31 PM
Old LP tanks vs. new Aluminum, refill? cuyeda LP Gas, Piping, Tanks & Regulators 4 12-04-2006 04:08 PM
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
