Old 04-28-2019, 01:02 PM   #1
2018 30' Classic
Arlington , TX
Propane tank readout on Firefly panel
Hi All,
Has anyone had the following problem? When we refill our propane tank and hook it back up the Firefly panel still shows empty even though it's full. Any suggestions on what's going on? The wiring seems to be ok so not sure where to go from there. Any help would be appreciated.
Thank you,
montanachick
montanachick is offline   Reply With Quote
Old 04-28-2019, 05:45 PM   #2
2018 33' Classic
Silverdale , Washington
Sounds like you have a poor ground between your propane cylinder and the associated position on the frame. If you have a poor ground, a full tank might indicate empty on the panel. Make sure the cylinder hold down is tight and no debris between the cylinder and frame such as excessive rust. Hope this helps.
CWO7241 is offline   Reply With Quote
Firefly and Propane readout Pete B55 Electronics & Connectivity 11 08-06-2020 05:25 AM
Refrigerator thermostat readout - wrong wrong wrong BoldAdventure Refrigerators 12 09-18-2015 05:02 PM
Firefly :: 1978 Airstream Excella 500 heather.rauh Airstream Registry Discussions 0 06-10-2013 06:13 PM
Dometic AC getting incorrect temp readout richinny Furnaces, Heaters, Fireplaces & Air Conditioning 5 08-03-2012 09:07 PM
"Firefly" 1960 Tradewind :: 1960 Airstream Tradewind 2vets Airstream Registry Discussions 0 08-19-2011 08:30 AM
