02-25-2018, 10:31 AM
2018 30' Classic
Traverse City
, Michigan
Propane Tank Gauge on 2018 Classic
It’s time to remove one of our propane tanks on our 2018 Classic. All directions are clear and simple EXCEPT no one talks about how you remove the attached fill gage. It’s connected directly to he tank. Can anyone explain?
Motorhomes were our choice for 40 years and decided to get rid of the stress and experience more flexibility in travel.
2018 30’ Classic
02-25-2018, 10:56 AM
mcdonough
, Georgia
Just curious if you are wanting to remove to fill, we have always just driven the airstream to have refilled without removing.
02-25-2018, 11:35 AM
Oswego
How about a pic. Mine has spade connectors about 6" from the gauge itself. If you don't have connectors already on the wire, you'll need to install them.
-Rich-
02-25-2018, 11:40 AM
2018 30' Classic
Traverse City
, Michigan
We’re parked for the winter. A lot easier to take it off (we think) and have it filled where we also get our grill tank filled. Some places won’t fill if attached to the trailer.
2018 30’ Classic
02-25-2018, 11:42 AM
2018 30' Classic
Traverse City
, Michigan
I think we found it Rich. A small, somewhat hidden, red connector snapped apart. Hopefully that was it.
Still trying to figure out how to post a picture. Technically challenged.
Thanks for your help.
2018 30’ Classic
Oswego
This is correct. I've never seen a place which will fill bottles on the trailer. Tanks on a moho, yes.
-Rich-
02-26-2018, 10:22 AM
Silver Star
1970 23' Safari
Victoria
, British Columbia
I know in some RV parks they have fill trucks come around, but otherwise you need to remove the tanks especially in western Canada were most tanks are filled by weight.
02-26-2018, 10:37 AM
2018 30' Classic
Thousand Oaks
Yup. It’s just a connector that unclips. The gauges stay on the trailer. Remove the aluminum case by uncrancking the large middle guy. The entire cover comes off over the top then you will see full access to the bottles.
BigSxyWhtGuy
Follow our adventures!
@airstreamvagabond on Instagram and YouTube
02-26-2018, 11:11 AM
Happy Camper
2018 30' Classic
Flat Rock
, North Carolina
After removing the propane tank cover, pull the red spade connector apart for the tank you want to have refilled. The gauge stays on the tank. The Classic has aluminum tanks so they are much lighter than the steel tanks—especially nice after they’re filled.
03-06-2018, 09:23 AM
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction
Actually a full aluminum 40 pound tank weighs about the same as a 30 pound steel tank when filled.....
At our Airstream only RV park during the summer in Lakeside, AZ, one of the local propane companies comes around and fills the tanks on the trailer from a truck just like they fill the tanks for a home using liquid measure. I do have to take the tank cover off so he has a straight shot at the propane filler fitting.
2014 31' Classic model 30 twin beds, 50 amp service, 900 watt solar system, Centramatics, Tuson TPMS, disc brakes, 16" tires & wheels
