Old 09-18-2023, 03:32 PM   #1
2023 25' International
San Angelo , Texas
Propane Tank Cover Rubs
Our 2023 25FBT International came with the aluminum cover over both tanks.
It is sandwiched between the tongue jack and the tanks, rubbing on both. Is this normal? There was a piece of rubber stuck to the back side of the jack I guess to keep it from rattling.
Only fix that I see to space things out a little would require welding...don't want to do that...Ideas? Click image for larger version
Jubba is offline   Reply With Quote
Old 09-18-2023, 03:47 PM   #2
2022 25' Flying Cloud
Tualatin , Oregon
Ours is exactly the same. I keep some extra rubber weatherstrip in case the existing strip comes off. Lack of attention to detail from Airstream.
Steve
TitusNW is offline   Reply With Quote
Old 09-18-2023, 04:21 PM   #3
2002 19' Bambi
Lafayette , California
Our 2002 came new with a manual jack which has always rubbed on the aluminum propane-tank cover. The cover is a snug fit over the tanks.
So, if it is lack of attention to detail, it has gone on for at least 21 years. I suggest it is planned to be that way.
Tim
Tim A. is offline   Reply With Quote
Old 09-18-2023, 06:14 PM   #4
2019 30' International
Pennsylvania , Pennsylvania
Yep, that's often the norm. I've seen some older models with more clearance.
I just replaced our jack. Many here like the Husky Super Brute, but I opted for the Stromberg Carlson 4500.
If yours is the Barker VIP 3500, you can turn the head sideways, but I don't know if that gains clearance or not. Some jacks allow you to turn the entire jack, they have double sets of holes in the jack flange. Other folks on here have marked off and drilled holes in order to turn the jack....primary reason being clearance to get the tailgate down on the truck.
If you ain't havin' fun you ain't doin' it right
2017 Ford CCSB F250 XLT 6.2L Gas 4x4 Ruby
2019 International Serenity 30 Rear Twin
majorairhead is offline   Reply With Quote
Old 09-18-2023, 07:23 PM   #5
San Angelo , Texas
Sure appreciate your info. I thought about drilling new holes but there’s a second plate welded to the underside of the frame that the jack run’s thru. Will probably just let it be.
Thanks again.
Jubba
Old 09-19-2023, 02:21 PM   #6
Life is a Highway's Avatar
2018 25' Flying Cloud
2019 25' Flying Cloud
2021 30' Flying Cloud
Lady Lake , Florida
Turn the jack head sideways switch to the left curb side
On the propane tank cover place a piece of rubber self stick removable Tech Specs padding
Tech Specs .com
Life is a Highway is offline   Reply With Quote
Old 09-19-2023, 02:29 PM   #7
2020 30' International
Wilmington , North Carolina
I had the same situation with mine. I bought some 6" 3M rubber non-abrasive "Safety-Walk" tape to put on the outside of the take cover behind the jack. I also put it on the inside of the tank cover where the LP tanks were rubbing. It worked so well that I might have gone overboard and put it on the inside of my hatch covers to reduce scratching when moving items in an out. Did it when unit was new and haven't replaced yet.
Seagate04 is offline   Reply With Quote
Old 09-19-2023, 06:22 PM   #8
2010 25' FB Flying Cloud
Davenport , Iowa
I found it TOO late, have a hole about the size of a dime in the cover. This was AFTER rotating the jack head. One piece of DUCK TAPE on each side of hole, didn't last
Mike
Airtandem is offline   Reply With Quote
Old 09-20-2023, 03:25 AM   #9
davidz71's Avatar
1986 25' Sovereign
Southern Middle , Tennessee
Tim
My '86 Sovereign with jack head turned sideways rubs on the cover also. I put a felt pad on the cover where it rides against the back side of the jack and also at the bottom where the cover rides on the frame.
Aluminum Propane Tank Cover for 30 lb Propane Tanks - Tennessee solar-stream Airstream Classifieds 6 03-23-2023 06:26 AM
Battery box lid rubs against front panel gzvette61 General Repair Forum 19 09-06-2022 01:17 PM
Propane tank cover.... drboyd LP Gas, Piping, Tanks & Regulators 2 07-29-2003 03:42 PM
Propane Tank Cover 74SovereignInt. LP Gas, Piping, Tanks & Regulators 13 02-27-2003 10:37 AM
