02-10-2025, 07:09 AM
2004 25' Safari
Fort Collins
Propane Tank Cover Replacement
We have a 2004 Airstream Safari SS. We lost the lid to our propane tank cover on the highway due to high winds. Ripped right off. Can the lid be replaced or do we need to buy the entire cover? If so, where or through which website? Anyone selling a used tank cover out there? We will be in the Arizona area for a couple of months.
02-10-2025, 08:06 AM
2010 30' Classic
Warren
, Manitoba
Woodland Airstream parts dept, is good, a little pricey, but you can look up product on their website. Another good site is Airstream Trailer Parts.com. They have a lot of parts and a good website.
ACI #7394
2012 GMC 2500 HD Duramax Denali
2010 Classic Limited 30' ,1994 Excella 34'
1987 Limited 34', 1976 31' Sovereign, 1976 Argosy 22' Gone to new homes
Hensley Hitch
02-10-2025, 08:19 AM
2004 25' Safari
Fort Collins
Thanks. I’ll give those a try.
02-10-2025, 08:25 AM
2015 23' FB International
2007 19' International CCD
Steamboat Springs
You may want to consider a replacement from AirBoardShop. It is higher and allows you to store a few handy items when used with the storage shelf.
"Keep your eyes on the road
Your hand upon the wheel"
02-10-2025, 09:32 AM
2004 25' Safari
Fort Collins
Thanks! I found the lid and hardware at AirstreamTrailerParts.com. Problem solved.
02-10-2025, 11:03 AM
1994 25' Excella
Waukesha
, Wisconsin
Make sure that when you put the new lid on that the cover is facing the proper direction - it should be pushed closed when traveling down the highway, not pulled open.
I added a lightweight chain to the inside of the lid to keep it from opening too far when we're working in the propane area. This keeps the lid from being over stressed when it's left open.
Richard
11018
1994 Excella 25 'Gertie' Follow the build on Gertie!
1999 Suburban LS 2500 w/7.4L V8 'Bert'
1974 GMC 4108a - Custom Coach Land Cruiser 'The Bus' (Sold)
02-10-2025, 01:45 PM
2021 23' Flying Cloud
Raleigh
, North Carolina
We actually ditched our 30lb tanks as we never ran them dry. We use two standard 5 gal bbq tanks and bought a black plastic cover. Actually I like the black look anyway. I cut a lot of weight off directly above the hitch. I’m happy with the results
02-10-2025, 09:30 PM
Still Learning
2013 25' International
Benzonia
, Michigan
When the latch on our cover failed (the latch itself was fine, the latch ripped out of the plastic cover) we were at JC for other service. We bought a replacement cover and had the tech put 2 strips of aluminum on the inside of the cover. One to reinforce the hinge and one to reinforce the latch attachment. Now those are riveted through the plastic into metal, not just riveted to the plastic lid itself. We later added a keeper chain ourselves. Rivets attached to rather thin plastic-destined to fail.
02-11-2025, 12:41 PM
1988 32' Excella
Robbinsville
, New Jersey
I think that's a great idea for anyone who doesn't use a lot of propane.
Added bonus you no longer need to get the propane cylinders re-certified, just go to an exchange place when they get close to that age.
02-16-2025, 10:52 AM
2016 30' International
redondo beach
"We actually ditched our 30lb tanks as we never ran them dry. We use two standard 5 gal bbq tanks and bought a black plastic cover. Actually I like the black look anyway. I cut a lot of weight off directly above the hitch. I’m happy with the results"
And those big tanks are heavy!
Great idea.
Randy and Beth 15 F250, 16 30' International, ProPride, Dexter 3" lift, Michelin 16, Dill TPMS, Centramatics, Battleborn x4, Victron BMV and 1.2KW inverter, Orion DC/DC, BlueSolar MPPT, 300W solar, Alpine iLX, Polk MM1, Samsung smart 42"
02-18-2025, 02:13 PM
2013 20' Flying Cloud
minneapolis
cover 4 sale
we have an extra cover we can sell. we are in Austin tx. send me a DM.
-Charles
02-18-2025, 04:29 PM
Moderator Emeritus
1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna
RE: Propane Tank Cover Replacement -- An Alternative
There is also an alternative to replacing the cover, and that is to go with Aluminum LP Tanks and have them polished to compliment your Airstream. There is a modest weight savings over the steel tanks and you don't have a cover to worry about. I have 40-pound tanks on my 1964 Overlander Land Yacht International, and 20-pound tanks on my 1978 Argosy Minuet 6.0 Metre (they are painted on the Argosy and came that way from the factory).
Kevin
Kevin D. Allen
WBCCI (Lifetime Member)/VAC/Pride Streamers/Wisconsin-UP Unit (Primary)/Missouri Greater Ozark Unit (Affiliate Member) #7864
AIR #827
1964 Overlander International
