RV News RVBusiness 2021 Top 10 RVs of the Year, plus 56 additional debuts and must-see units → ×
Old 09-08-2020, 07:41 PM   #1
Ray Eklund's Avatar
2019 27' International
2014 25' International
Fort Saunders , Wyoming
Propane Sensor Alarm- is set OFF- twice
Our Propane leak sensor is mounted below the clothes closet. It has a green light that glows when it is operating. When tripped... RED.
It woke us up in the middle of the night. You will understand when it goes off. It gets your attention. We smelled NO Propane... and reset the sensor. All was well.
A couple weeks later. Same thing. Geez... and in the middle of the night.
This time we FOUND the problem. Our Blue Heeler would lay on the floor and bump into the unit, tripping the test alarm. She would push against the wall hard enough I had to drop the door and push it back flush.
When it would go off... our Blue Heeler was not sticking around. She looks... innocent.
Problem Solved. If you have a 'mystery Propane Leak Alert'... do you have a pet?
Nancy is taping a plastic bottle cap over the TEST Button. Both problems solved!
Human Bean
Ray Eklund is offline   Reply With Quote
Old 09-08-2020, 08:04 PM   #2
2007 27' Safari FB SE
NW Oregon in a nice spot , Oregon
True story....my son was using the bathroom and forgot to turn the fan on......it went off.
bweybright is offline   Reply With Quote
Old 09-08-2020, 11:12 PM   #3
SuperTrouper's Avatar
2008 27' International FB
Petaluma , California
Certain types of aerosol sun screen will set them off.
SuperTrouper is offline   Reply With Quote
Old 09-08-2020, 11:41 PM   #4
2007 22' International CCD
Our ‘stealth’ Pomeranian really enjoys his meals and expresses his appreciation after he eats by loudly belching. Yup, we feed him well away from the propane detector.
rmkrum is online now   Reply With Quote
Old 09-09-2020, 11:19 AM   #5
Murfreesboro , Tennessee
Same for mine. I had an ever so slight leak under my gas cooktop. Just needed a slight tightening of a fitting. Could smell any gas but the sensor can pick it up. Gas is heavier than air so it will be lower inside the trailer. That’s the reason where it’s mounted. One way to stop it in the middle of the night and your hooked up to electric is to go outside and turn you gas bottle off.
dnsapp is offline   Reply With Quote
Old 09-09-2020, 06:21 PM   #6
mikesSE's Avatar
2007 23' Safari SE
ROSWELL , Georgia
Images: 14
ALSO, a propane gas detector is only good for 5 years or less.You need to check the date on it.
Mike & Nancy Gore WBCCI #2914 S E Camping Unit 012 Roswell,Ga.
mikesSE is offline   Reply With Quote
Old 09-09-2020, 07:47 PM   #7
Dan and Liz's Avatar
1987 25' Sovereign
Fort Collins , Colorado
Open but unlit range top pilot valve can do that too.
Alumacoot
“We are confronted with insurmountable opportunities.”
Dan and Liz is offline   Reply With Quote
HELP! Can't turn off propane alarm!! Lily&Me LP Gas, Piping, Tanks & Regulators 22 11-12-2018 12:25 PM
New MicroPulse Sensor and re-cal... post mortem on old sensor RFP General Repair Forum 10 10-25-2017 08:29 PM
A Grandpa Twice Again! Chaplain Kent Off Topic Forum 18 07-26-2006 08:49 PM
twice as nice fuzzywickle Member Introductions 3 01-06-2006 06:45 AM
