Old 07-03-2020, 08:42 PM   #1
2021 25' Flying Cloud
Tabernash , Colorado
Propane regulator and an empty tank
Had an unusual problem. I usually open both of my tank valves so that my propane will continuously flow and the valve will switch between tanks automatically. This is the first time that I actually "drained" a tank. The hot water heater sputtered a couple of time and the indicator went from green to red and I just switched the valve.
The strange thing is that my propane monitoring system (Mopeka) said I had 20% left in the tank. (It was 70 degrees or so at 9000 ft). My initial guess is that the indicator was bad. Today when I went to the local ACE for a fill up, there clearly was 20% left in the tank.
Had I closed the full tank and forced the appliances to try and really empty the low tank, would that have worked? I didn't want the fridge and potentially the furnace or fridge to sputter, so i switched. Is this common for a tank not to completely empty? Was altitude a potential issue?
Not earth shattering...... just curious.
JeffCross is offline   Reply With Quote
Old 07-03-2020, 10:44 PM   #2
SSquared's Avatar
2013 25' FB Flying Cloud
Longmont , Colorado
I have never noticed any appliance sputtering due to low propane or the change-over happening. I have camped as high as 10,000 feet. I'm sure I have had change-overs happen while camped in the Colorado mountains but I don't specifically remember anything about those changeovers.
Having it leave 20% in the tank at change-over time is not normal. When I have a tank filled after a change-over, the fill amount is usually within 0.1 or 0.2 pounds of the expected amount.
SSquared is offline   Reply With Quote
Do you empty propane before polishing tanks? Becky B. Cleaning, Stripping & Polishing 22 11-01-2022 09:31 AM
Black tank pull handle screw head broke off underneath and can’t empty tank. HabitatGuy Classic Motorhomes 18 06-21-2020 07:35 PM
oily propane regulator/ blowing out propane line Lumatic LP Gas, Piping, Tanks & Regulators 2 02-29-2020 10:57 AM
Knowing when propane tank is full or empty Judypetrick LP Gas, Piping, Tanks & Regulators 31 06-10-2015 09:40 AM
When are Propane Tanks Empty? woodedareas LP Gas, Piping, Tanks & Regulators 8 02-02-2007 11:26 AM
