01-19-2022, 04:36 PM
2008 27' Safari FB SE
Mission
, British Columbia
Propane Quick Connect Advice
2008 Safari, looking to add a quick-connect outlet (either near the tanks or connected to them - see picture). Any advice on what / recommended parts to use? I have no doubt I may blow myself up, but I'm ok with that.
01-19-2022, 09:09 PM
2007 22' International CCD
Corona
See the pictures below for how I did it.
I used parts from Amazon (Dozyant brand) 3/8” quick connection system parts and assorted plumbing from the big box stores.
Please note, that unless you know exactly what you are doing, don’t mess with modifying propane systems. Get some expert help.
Being in a front row seat inside a rapidly expanding fireball is not a place to be…
01-19-2022, 10:19 PM
Mission
, British Columbia
It wouldn't be the first time, lol. I appreciate the pictures - it seems you've moved or have the battery box elsewhere? Your run seems to be where this ones battery box is - so something i'll need to work around.
01-19-2022, 10:24 PM
Corona
Propane plumbing for the quick connect is located just forward of the white battery box and aft of the propane tank cover. The black things are the power-operated jacks for my Propride hitch system.
Propane quick connection in use running my dual fuel Champion inverter generator. This is why I added the quick connect system.
Simple hint: use YELLOW propane-rated Teflon tape with propane. The thin white stuff will leak…hard to see, but all the joints are sealed with that yellow stuff.
01-20-2022, 06:47 AM
2002 30' Classic S/O
Fleming Island
I put mine where the flexible hose from the regulator connected to the copper tubing right where the A-frame joins the body of the trailer. As others have said quick disconnect from Amazon and miscellaneous plumbing parts. Use gas-rated teflon tape (yellow, more expensive) or joint compound.on all joints and test for leaks with soapy water.
01-20-2022, 09:35 AM
Corona
Yup. Exactly. I installed a couple shut-off valves, one on the quick connect and one at the end of the flex hose to make it easy to shut stuff off quickly. Generator requires a shut off valve to stop it when it’s running on propane. It’s a design feature to bleed propane pressure out of the hose to the generator for safety.
01-20-2022, 10:30 AM
1976 Argosy 24
1961 28' Ambassador
1968 26' Overlander
Lakewood
Good project, be aware that there are female quick connects with built in ball valves. Have a great local propane company that carries all these parts in stock and will build custom combos of hoses or valves while you wait. I'm happy to pay for that service.
Good luck and be safe...
Mark D
01-20-2022, 09:33 PM
2020 19' Caravel
Ammon
, Idaho
No one else has mentioned this so I will chime in.
Not all quick connect fittings are the same. Ensure you use the style for a low pressure gas system.
