Old 04-01-2017, 09:08 PM   #1
sacramento , California
Propane piping around Axle
Just bought lift kit from Inland. Getting ready to do it but noticed propane tubing will have to be dealt with. 1974 Sovereign. Any suggestions?
calmacpher is offline   Reply With Quote
Old 04-02-2017, 08:50 AM   #2
sgschwend's Avatar
1986 25' Sovereign
2008 F350, 6.4L diesel , Oak Harbor, WA
Images: 13
You are saying the copper tubing needs to be replaced?
If you remove it you can use the original as a pattern to make new one and install it the same way.
Mine was flattened because it was routed under the A frame. I replaced it and shifted it away to the inside. Took about 10' of tubing.
sgschwend is offline   Reply With Quote
Old 04-02-2017, 08:59 AM   #3
The tubing is good. I know that I will have to disassemble the tubing in order to lift the body. I am trying to avoid adding piping, and was hoping someone had experience with this. Ideally I was hoping to disassemble the tubing, lift the unit, and reattach the piping to the body, not having it wrap around the underside of the axle anymore.
Old 04-03-2017, 02:42 AM   #4
1991 25' Excella
Stanfield , Oregon
I'm not really sure what your asking here. But when I installed new axles on my trailer it was easier to cut the copper pipe and remove just a section of it. Then when I reassembled I added a tee in. Then ran new copper piping to the rear curbside where I installed a propane quick disconnect. It's really nice for my propane fire pit.
SpletKay06 is offline   Reply With Quote
Old 04-03-2017, 06:33 AM   #5
I think you answered my question . Thank you!
Propane piping What is Airstream Tony S General Repair Forum 2 05-22-2016 04:08 PM
Propane Piping Sizing dbj216 LP Gas, Piping, Tanks & Regulators 13 06-23-2014 06:57 PM
PVC piping Devoman Fresh Water Systems 8 09-30-2005 07:46 PM
Water Pump Piping Navigator Water Heaters, Filters & Pumps 2 02-08-2004 10:16 AM
Hot water piping Pahaska 2002 - 2005 International 8 01-29-2003 07:19 AM
