Old 04-18-2021, 06:49 AM   #1
urnmor's Avatar
2012 25' Flying Cloud
Berlin , Maryland
Propane lines replaced
As I have done a lot of maintenance this year on our AS (new domestic fans, new
skylight new sealant, new jack) I decided to also replace the old propane lines. So I installed the the gas-stop propane shutoff values along with the new lines. It was a very easy installation.
urnmor is online now   Reply With Quote
Old 05-06-2021, 01:25 PM   #2
Eagle & Bear's Avatar
1976 29' Ambassador
Madison , Officially SD but are traveling full time.
I have a 1976 AS. Replacing the copper tubing for propane is way over due. I am surprised that the tubing has not worn through as they pass over the axles. Problem is that I cannot find a source for the 5/8 OD "L" rated tubing in anything less than a 60' coil. The 3/8" OD "L" copper is easier to locate but only in 60' coils. Where did you find the copper you used? Similarly, the flex that connects the regulator to the copper is not short enough. Any suggestions as to where to look for the Type "L" copper?
Eagle & Bear is offline   Reply With Quote
Old 06-12-2021, 09:07 AM   #3
1976 Argosy 26
Reidsville , North Carolina
76 argosy
I redid mine last week. I left the 3/4 (?) trunk line and replaced the 3/8 lines with new product. I had removed the furnace and stove and tried reusing the copper lines from them, mistake! The new lines bent easy and flared easy for this rookie.
76argosy is offline   Reply With Quote
Frustrated! Replaced antenna to Jack, replaced connections....still nothing. 09 27 jholder Audio, Video & TV 10 06-10-2018 09:05 PM
I've replaced all my gas lines, what type of bracket can i attach them with? Rofkrynn LP Gas, Piping, Tanks & Regulators 5 12-05-2012 07:42 PM
Anyone replaced Old Propane tanks with Clear Ones? Bob Thompson LP Gas, Piping, Tanks & Regulators 13 01-03-2010 07:40 AM
propane lines airtim LP Gas, Piping, Tanks & Regulators 18 03-26-2005 07:38 AM
Bleed lines after propane refill!!! Astrodokk On The Road... 4 12-01-2003 11:08 PM
