Old 04-23-2017, 09:03 AM   #1
Growing old but not up
1972 29' Ambassador
St. Louis , Missouri
Propane Lines
I am replacing the old with new copper lines for the propane on a '72 Ambassador. Is there a substitute for copper? I will stub up with new copper to each appliance but would like to replace the main line with the white tubing I'm seeing on the newer AS. Manuals for the new AS indicate E-Pex but I'm finding little info on the product.
Thanks in advance.
riskstl is offline   Reply With Quote
Old 04-23-2017, 09:14 AM   #2
A W Warn's Avatar
Two Places , Sticks & Bricks
Thanks in advance.
PEX is for water lines. If it is being used in newer trailers for propane, that a new one on me!
I have seen yellow plastic pipe being used for natural gas, but I do not know what material it is (PVC? PEX? ABS?)
On my trailer PEX is slid over the copper propane lines as a protector.
You can use a combination of copper and black iron pipe for propane, but personally I would not do that due to corrosive action between different metals. You would have to buy special fittings for the transitions.
I feel homeless
Alan
Former Airstream Owner
(1973 31' Excella, 1978 31' Excella, 1987 32' Excella, 1999 30' Excella, 2000 25' Safari)
Old 04-23-2017, 11:15 AM   #3
Lakes Region , New Hampshire
I do believe you may be looking for Gas Flex
RandyNH is offline   Reply With Quote
Old 04-23-2017, 11:39 AM   #4
68 TWind's Avatar
1968 24' Tradewind
Oxford, , Mississippi
I've got the original copper lines on my Trade Wind and they have been working fine for 49 years. Copper is easy to work with. Sometimes newer isn't always better.
Bruce & Rachel
68 Trade Wind
2001 Toyota Tundra
Old 04-23-2017, 04:31 PM   #5
AlinCal's Avatar
1991 25' Excella
2011 19' Flying Cloud
Santa Ynez , California
I would use copper. The material other than black iron or galv. Pipe used in home construction is Trac Pipe and would not be a good choice for an rv, besides being expensive it does not come in sizes under 1/2".
FYI. Trac pipe is a flexible corrugated stainless steel tubing with a plastic outer shield in either yellow or black.
AlinCal is offline   Reply With Quote
Kinked propane lines to stove imeynstein LP Gas, Piping, Tanks & Regulators 17 12-21-2008 05:50 PM
Propane tank, lines, regulator question Lothlorian LP Gas, Piping, Tanks & Regulators 16 02-27-2008 09:02 PM
Running propane lines Safari Tim LP Gas, Piping, Tanks & Regulators 7 07-01-2007 03:45 PM
propane lines airtim LP Gas, Piping, Tanks & Regulators 18 03-26-2005 07:38 AM
Bleed lines after propane refill!!! Astrodokk On The Road... 4 12-01-2003 11:08 PM
