Old 05-20-2020, 05:11 PM   #1
drboyd's Avatar
1978 25' Tradewind
Metro Phoenix , Arizona
Propane hose unusual failure!
Coach is a 1978 Trade Wind with probably the original rubber propane hose from the regulator down to the copper line heading back underneath.
The rubber line just closed up - wouldn't let be a couple molecules of gas through an hour. The copper line headed back was blown out, but didn't contain more than a couple drops of oil.
Too weird.
I'm posting this just to give folks with elderly coaches a heads-up if the propane system seems to be taking a dump on you!
Old 05-20-2020, 05:45 PM   #2
2018 25' International
Slidell , Louisiana
Your experience is not that unexpected. Over the years as rubber ages and the molecules break down into shorter ones, the propensity to absorb trace oils into the voids swells the rubber to the point it collapses on the inside even if the outside looks okay.
Brian
Old 05-20-2020, 06:11 PM   #3
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
I had the propane hose do that on my trailer also. Not closed all the way but enough to short change the furnace.
A hose is a hose is a hose Vitaver Plumbing - Systems & Fixtures 38 09-23-2020 11:41 AM
Sewer Hose Coupling Failure swilly43 Sprinter and B-van Forum 11 07-22-2018 05:54 PM
Refrigerator drain hose failure SilverGate Refrigerators 7 01-26-2016 12:11 AM
Turbo Hose Failure c21 Sprinter and B-van Forum 1 11-04-2013 04:25 PM
Very long tow in BC - turbo hose failure! wayneskid Sprinter and B-van Forum 6 10-05-2011 05:29 PM
